Toymods » Tech & Conversions » LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE
StyleSkillSpeed
Seven Hills
LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Mon, 09 February 2004 23:51 Go to next message
HEY GUYS...
Dont know if anyones asked this question could not find anything yet.
what is the difference, and how many class did the ae-86 come in?
and what is the highest and lowest?
can anyone fulfill my curiosity??? please...
Thank you
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 10 February 2004 00:12 Go to previous messageGo to next message
Brought to you by the SEARCH feature: http://forums.toymods.org.au/index.php?t=msg&t h=19608&rid=162&S=00c495c8d593fe29f7f92421 c96554c3&pl_view=&start=0#msg_161586
StyleSkillSpeed
Seven Hills
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 10 February 2004 00:18 Go to previous messageGo to next message
thanks justcallmefrank
much appreciated.... u are a legend^^
well curiosity fulfilled....
regards,
ae86drift
sydney.au
The AE86 Lowdown. Models, Types and Grades. Tue, 10 February 2004 00:31 Go to previous messageGo to next message
All the information here-in is based on the Japanese Domestic Market
1. AE86 came in 2 models types:
> Corolla Levin (Fixed Head Lights) (also known as 'Toyota Sprinter in Australia)
> Sprinter Trueno (Popup Head Lights)
2. now each of these 2 model types came in either:
> coupe (2 doors with a 'boot'. usually called a '2-Door')
> hatchback (2 doors with a lift hatch. usually called a '3-Door')
3. now each model and model type has 3 major model grades. these 3 grades came with 'Lasre' 4A-GE as the standard engine.
> SR - lowest base model, usually with crapy seats and interior trim (same as the ADM 'Toyota Sprinter' Interior). Suspension and differential are lower grade with no LSD as standard. Drum Brake Rear end. Pretty boring model, not as many sold.
> GTV - sports model with weighty items shaved off. comes with the same grade "Lasre Pegasus" suspension, diff and interior trim parts as the GT Apex grade without the 'luxury' components. Bodykit (mentioned below) is also an option as well as Power steering, sunroof and Aircon. All disc brakes as standard, front discs are vented (not slotted or drilled.. VENTED)
> GTAPEX - luxury model with the most options. Comes with everything the GTV does but with lots of optons such as : Power windows, power steering, cruise control, sunroof, power mirrors, climate control, (Aircon is standard), digital gauge cluster, better pioneer stereo, body kit (front lip, sideskits + rear spoiler 'lip')
(there are a few others such as GT, SE, XL and XL Lisse i wont menion these as they are sub grades usually with a 3A-C engine )
4. AE86's were manufactured from early 1983 to mid 1985 and from late 1985 to late 1987 (AE86's were only sold in australia between 1983 to 1985 Under the name 'Toyota Sprinter')
each of these two periods have names:
> cars manufactured between 1983 - mid 1985 are called "Zenki" loosely meaning "first" in japanese
> cars manufactured between late 1985 - 1987 are called "Kouki" loosely meaning "after or 'second'" in japanese
there were many changes in the exterior and interior apprearance (notably the front bars and lights and the rear taillghts) and some in the changes of the differential (larger, stronger axle splines for the 'kouki') and engine specs between "Zenki" and "Kouki" but very minimal changes overall.
Some Information on thse changes badly translated from (http://www.fzr.jp/nii/garage/car/ae86data/)
Quote:
May of 58 - January of 59
AE86-0000001 - 0044198
AE86-5000001 - 5031663
Generally 58 year system and 1 type, it is the type which is called the super previous term.
By your are this type. (With, almost there is no trace of 58 year type, but...)
There is no setting of the sport package.
Super the color which such as blue metallic becomes minor is set afterwards.
Rearview mirror spring return system.
The rear wiper when stopping has been side. As for GTV, with clock and set option. As for the rear window ぅ heat wave and the set option which have been written in the certain book lack of confirmation.
Single horn. (There is no either wiring for double and, there is no either mounting hole of suicide seat side)
By the way, horn of the previous term (only after the January of 59 of radiator light/write and radiator left of light/write rear) is attached to position.
As for レビン, only GT-APEX having become the grille of the working air intake, as for the other things the lateral stripe (? ) It has become grille form.
The windshield has become the tempered glass.
The high metal two ton of GT-APEX (silver black) the glass has stopped being the bronze glass (the red っ ぼ) with with the body curler other than.
Interior, are three types of red, blue and brown the body color, depending upon the grade.
As for setting color, as follows (only the color which verifies)
White 038 (GTV and GT)
Lead-lead 3D7 (GTV and GT)
Silver metallic 147 (GTV and GT)
High-tech two ton 2N2 (black and white, GT-APEX and GT)
High flash two ton 2M9 (it is dark red, GT-APEX and GT)
High metal two ton 2M8 (silver black, GT-APEX and GT)
Blue metallic 8A9 seems 85 private colors.... (Lack of confirmation)
February of 59 - May of 60
AE86-0044199 - 0160183
AE86-5031664 - 5061954
Generally 59 year system and 2 types, it is the type which is called the previous term. Improvement of the place where (disrepute) there is an inconvenience mainly with 58 year system and correction and the addition with legal amendment it is main. Don't you think? it is the person, generally known small improvement.
Setting of the sport package adds. (The front spoiler, the ria jauntily Ra and the leather volume steering wheel, the leather volume shifter)
Rearview mirror yes falling down system of crane crane.
The rear wiper when stopping has been length.
It has become double horn.
May of 60 - October of 60
AE86-0160184 - 0195584
AE86-5061955 - 5066625
Generally 60 year system and 2.5 types, latter-term previous term (? ) With it is said, it seems. It is generally known minor change.
The bumper, modification to the form where lovely the front spoiler which seems is attached. As for トレノ, around turn signal cornering lamp (only GT-APEX) for installing, enlargement.
Form modification of grille. トレノ it meaning that the bumper center rises became small. レビン to be designed standardized, only GT-APEX the fog internal organs.
The light/write, only yellow valve conversion and レビン modifies to the shape where the black line is attached to the top and bottom. Only GT-APEX cornering lamp standard equipment.
The rear bumper, the plural side lines entering, is corrected to shape, in order the mudguard to be able to make a little the arch part of the rear tire, form is modified.
As for the tail lamp, way vertical width is felt thinly, modification of design. Modification to the shape where the vicinity of number is surrounded with the plastic.
Interior, was modified to all black systems.
The rearview mirror modifies to surface roughly type.
4th gear AT were added to GT and GT-APEX.
The power window option was set to GT-APEX.
デジパネ of 3 doors GT-APEX became option setting.
The rear wiper of GTV standard equipment.
Installation position of horn moves to radiator upper.
The windshield, modification to glass laminate.
The bronze glass only of GT-APEX became black seductive.
The front spoiler was gone from the sport package, side mad guard was added.
Also wiring is modified various types.
Setting color is, as follows
White 041 (GTV and GT)
Lead-lead 3E6 (GTV and GT)
Medium grey metallic 159 (GTV and GT)
Silver & metallic 148 (GTV and GT)
High-tech two ton 2T7 (black and white and all grades)
High flash two ton 2T6 (it is dark red, all grades)
High sonic toning 2X1 (black silver, all grades)
October of 60 - April of 62
AE86-0195585 - 0280985
AE86-5066626 - 5079480
Generally 61 year system, 62 year system and 3 types, it is the type which is called the latter term 'Kouki'. Trouble measure (? ) It is the small revised model.
The drive shaft diameter which is while hoe singing becomes thick, also the diff. is modified simultaneously
January of 61 (lack of confirmation) from, special specification car BLACK LIMITED (black 204) was added to トレノ.
so thats about it. then theres the AE85 which is the same thing just lower grade parts/lesser power engine. ive missed a lot of specifics out which i can answer if you ask.
Maybe Sticky this for all the New members we have asking the same questions?
[Updated on: Tue, 10 February 2004 00:39]
NickAE86
Brisvegas
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 10 February 2004 02:09 Go to previous messageGo to next message
well done garth...rather comprehensive Smile
where did you find the info in quote?
i second the motion to sticky this...mods?
ae86drift
sydney.au
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 10 February 2004 02:30 Go to previous messageGo to next message
StyleSkillSpeed
Seven Hills
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 10 February 2004 02:49 Go to previous messageGo to next message
thanks garth...
i saw you at the cruise.... i think...
thanks for the detailed info...
much appreciated..
regards..
ae86drift
sydney.au
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 10 February 2004 03:24 Go to previous messageGo to next message
you did? well i did organise it! Very Happy
what ae86 were you driving?
ae86drift
sydney.au
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Wed, 18 February 2004 02:46 Go to previous messageGo to next message
bump up the list for the newbies PM'ing me about the trueno/levin 86/85 differences
(all thanks to CLG and his trueno ae85 ... BASTARD! Wink )
shcao
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 24 February 2004 11:10 Go to previous messageGo to next message
The SR i think is an ae85 3 door,
the SE is the 2 door.
They also came in RHYME, and LISSIE models.
RHYME is a model specifically aimed at girls!!!! and I am bloody serious Smile.
It's got the plush GT Apex interior including the wheel. It's got power steering and aircon aswell Smile. But obviously chicks dont need the performance of a 4gae and an LSD.
Lissie is similar, as it caters for another niche market Smile.
ae86drift
sydney.au
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 24 February 2004 11:14 Go to previous messageGo to next message
yeah
the brochure is fuckin classic
THE SEATS!! HAHAHAHA so funnnay
i didnt mention ae85's and lesser models although on my new ae86 site it will all be there!
Smile
im getting the original brochures translated too Very Happy
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 24 February 2004 12:05 Go to previous messageGo to next message
Ahhh, I just want to see the brochure in all it's Japanese glory... although a translation wouldn't be half bad, either!
ae86drift
sydney.au
Re: LEVIN OR TRUENO GT? GTV? GT APEX? WHATS THE DIFFERENCE Tue, 24 February 2004 12:16 Go to previous message
http://www.club4ag.com/faq%20and%20tech_pages/Scra pbook.htm
its crappy but youll get the idea!
Previous Topic:4A-GE 20 valve power?
Next Topic:4age/4agze into ke20
Current Time: Thu Nov 19 00:31:04 UTC 2026
Total time taken to generate the page: 0.0069859027862549 seconds
