Toymods » Tech & Conversions » Powersteering Leak
-=NiGz=-
Compton.Sydney
Powersteering Leak Tue, 10 February 2004 04:12 Go to next message
Got a leak with my powersteering. Theres a rip on the zig zag thing on the left could this be the cause of the leak?
http://www.woc.co.il/tipul/docs/powersteering/image005.jpg
bbaacchhyy
Re: Powersteering Leak Tue, 10 February 2004 04:20 Go to previous messageGo to next message
Afraid not. The 'zig zag thingy' that you refer to is one of the outer boots, and they are there to keep the dust out.
If you have a leak, it is more than likely one of the seals is worn and needs to be replaced by rebuilding the rack, or having a s/hand unit fitted
Michael B
dingaling
tas
Re: Powersteering Leak Tue, 10 February 2004 05:30 Go to previous messageGo to next message
you need to find where the leak is comming from, that in itself ain't easy sometimes.
Mine had been leaking for about 6 months before i found out where it was leaking. Try to clean up all the leaked power steering fluid, then take it for a drive and then check to see if you can spot the highest point where its leaking from.
mine turned out to be the power steering pipes. Let me tell you fixing that was a major pain in the ass, getting the bastard off and getting a replacement hose made up at enzed then putting it back on is not a job i'd like to do again.
twincam_ke20
Castlemaine Vic
Re: Powersteering Leak Tue, 10 February 2004 06:40 Go to previous messageGo to next message
another ma70 failing?!
just notoiced that iv got a power steering leak also! Mad and i cant seem to find where its coming from!! tho there seems to alot of oil around the bottom of the I/C theres no hoses that are leaking ect so i dunno Sad
-=NiGz=-
Compton.Sydney
Re: Powersteering Leak Tue, 10 February 2004 06:44 Go to previous messageGo to next message
Well i know where its leaking from. That "zig zag" thing has a rip there and bottom of the "zig zag" thing theres hole heap power steering fuild and shit. To mention doesnt leak straight away sometimes after 2 weeks month depends not sure Crying or Very Sad
ae92 rolla
Re: Powersteering Leak Tue, 10 February 2004 06:49 Go to previous messageGo to next message
Bro, I'd do a 1-8-7 on it and bust a cap in its ass.
Very likely an end seal has failed. Reco the unit.
dingaling
tas
Re: Powersteering Leak Tue, 10 February 2004 06:51 Go to previous messageGo to next message
you have the red fluid on you IC? perhaps it's leaking from those steel power steering lines that go infront of the radiator? try cleaning it all off and seeing if it gets on there again, perhaps you spilt some on the IC by accident, i did that and thought it was another leak, but it wasn't.
by the way in your signature it sounds like you have modded your 7m abit, but how come your only getting 135rwkw? isn't that abit low? stock 7mgte should get 135rwkw if not abit more?
nigz, i think you will find the zig zag rubber boot things arn't leaking, there just collecting power steering fluid which is comming from somewhere else. Both my rubber boots are ripped in half too i need new ones.
-=NiGz=-
Compton.Sydney
Re: Powersteering Leak Tue, 10 February 2004 06:53 Go to previous messageGo to next message
BRO i already did on tha nigga' didnt help Mad
Yeah thinking the same. The previous owner said he took it to a mechanic and he was told a valve was busted.
You can get new rack from jap wreckers ay?
-=NiGz=-
Compton.Sydney
Re: Powersteering Leak Tue, 10 February 2004 07:00 Go to previous messageGo to next message
dingaling wrote on Tue, 10 February 2004 17:51
Ah ok fair enough. prob a valve what the pervious owner said. Its still smooth steering not like hard or anything
twincam_ke20
Castlemaine Vic
Re: Powersteering Leak Tue, 10 February 2004 09:00 Go to previous message
uh huh, thats where it must be coming from, those pipes up in there, only lines i could see are the ones to the oil cooler, and then i cant see up in behind that, may have to check that out Rolling Eyes
as for the power out put, thats just what came with the car when it was rebuilt in `03, so im guessing it was straight after they rebuilt, since iv had the car it hasnt been dynoed, but soon will and i'll slap the lexus afm in too.
what would a rough power out put be atm?
Previous Topic:18rgeu into ta23 gearbox question
Next Topic:AE92 to AE94 difference - please help!
Current Time: Tue Oct 27 10:14:56 UTC 2026
Total time taken to generate the page: 0.031413078308105 seconds
