Toymods » Tech & Conversions » t series axle?
bman
melbourne
t series axle? Tue, 10 February 2004 06:08 Go to next message
hey, this may sound like a silly question, on t series diff (T292), is there a difference between right and left hand axle's? and are they interchangeable?
thanks in advance, john.
ra23celica
Re: t series axle? Tue, 10 February 2004 07:04 Go to previous messageGo to next message
Not that I easily saw in the t-series axle I pulled apart, but you may encouter problems when the teeth mesh 'in reverse' back inside the central pumpkin.
gold28
Madrid - Spain
Re: t series axle? Wed, 11 February 2004 02:00 Go to previous messageGo to next message
They will definitly bolt in OK.
"Supposedly" it is not a recommended thing to do though as they work harden at the shear plane of the spline. Changing axle sides reverses the load on this work hardened area and "supposedly" makes them brittle. I say supposedly because this is what I have been told and I have never bothered looking any further into it.
bman
melbourne
Re: t series axle? Wed, 11 February 2004 07:44 Go to previous messageGo to next message
thanks, yeah i have heard that changing axle's weakens them a little, considering it's only a 2TG up front, i don't think that there should be too many issues with strength.
the main problem i have now is getting the bent axle out, tried putting the drum on backwards and using it for leverage and also a slide hammer both to no avail, i don't really want to pull the centre out, are there any other suggestions?
gold28
Madrid - Spain
Re: t series axle? Wed, 11 February 2004 20:43 Go to previous messageGo to next message
Don't worry, if you can't get the axle out, you definitly won't get the centre out.
Keep persevering with the slide hammer....get violent is need be Evil or Very Mad
I am assuming that you did undo the axle retaining plate first???
Re: t series axle? Thu, 12 February 2004 01:12 Go to previous messageGo to next message
Last time I had to remove a T series axle, I bashed at it for hours with a slide hammer before giving up. I was pretty pissed off by then so I chained the axle to a tractor and ripped it out that way. Yes the car got dragged for a bit but the axle came out eventually. Very Happy
bman
melbourne
Re: t series axle? Thu, 12 February 2004 04:28 Go to previous message
got it out this morning with some force, and put in the new one, went for a drive and no noises or anything, so hopefully it should be ok.
thanks for the help.
Previous Topic:18R sump on a 21R ?
Next Topic:help needed, friends 3sge has used all oil and coolant within 12 days!
Current Time: Mon Oct 19 15:49:31 UTC 2026
Total time taken to generate the page: 0.025602102279663 seconds
