Toymods » Tech & Conversions » RA28 & KE70 ignition barrel interchangeable?
RA28 & KE70 ignition barrel interchangeable? Tue, 10 February 2004 21:46 Go to next message
Does anyone know if they are interchangeable? I'm going to be fitting a KE70/AE71 steering column to my RA28 Celica and would like if I can swap the ignition barrel's so I can keep my original key. Well I actually don't even have a key for the KE70 one so really hope I can swap em over.
Thanks!
Joel
IRA11Y
Club Member
Re: RA28 & KE70 ignition barrel interchangeable? Wed, 11 February 2004 04:50 Go to previous messageGo to next message
maybe.. if you want to try it out ( mines easy to pull out at the moment ) pop over on the way home one night Joel
Re: RA28 & KE70 ignition barrel interchangeable? Wed, 11 February 2004 06:26 Go to previous messageGo to next message
i have a locksmith buddy who could probably supply a new barrel, keyed to whatever key you want (+ new keys with same pattern?) for a very decent price.
CelicaRA45
nth ringwood, Victoria
Re: RA28 & KE70 ignition barrel interchangeable? Wed, 11 February 2004 06:45 Go to previous messageGo to next message
wont fit but as old corolla said can be rekeyed you need the the wiring as well for the start up with the different column
Re: RA28 & KE70 ignition barrel interchangeable? Wed, 11 February 2004 08:43 Go to previous messageGo to next message
Oldcorollas, wouldn't mind taking you up on that generous offer. Whats required to get the ball rolling?
Joel
Re: RA28 & KE70 ignition barrel interchangeable? Wed, 11 February 2004 09:43 Go to previous messageGo to next message
Does anyone know if you have to have the key to get the barrel out?
I know you push that little tab in on the side, but from memory you need it in accessory position before it'll slide out?
Re: RA28 & KE70 ignition barrel interchangeable? Wed, 11 February 2004 10:47 Go to previous messageGo to next message
pm me with the exact models of the cars key bits you have.. any numbers on the keys you want to keep (for the profile code) etc, and what it is exactly you want to achieve.
then i'll pass this on and see what he thinks is the best way to go about things and if bits swap across (good to have key catalogues Wink )
alex_ta22
Newcastle, Hunter Valley
Re: RA28 & KE70 ignition barrel interchangeable? Thu, 12 February 2004 08:02 Go to previous message
TurboRA28 wrote on Wed, 11 February 2004 20:43
I ""think"" i had to turn the key to accessories before i pulled the ta22 one out
Previous Topic:removing fan controls on AE92
Next Topic:TA22 springs into RA23?
Current Time: Sun Oct 18 02:28:36 UTC 2026
Total time taken to generate the page: 0.0044000148773193 seconds
