Toymods » General Car Talk » Odd sized coilover springs?
Odd sized coilover springs? Tue, 10 February 2004 22:24 Go to next message
Hello, my coilover springs are apparently an odd-ball size. They are somewhere around 70mm internal diameter. Where most coilovers seem to be 60.
Does anyone know who might carry these springs? Kingsprings can custom make them, but i'd prefer to find an off the shelf item if possible.
Joel
IRA11Y
Club Member
Re: Odd sized coilover springs? Wed, 11 February 2004 04:40 Go to previous messageGo to next message
try looking around some of the jap sites... thats where they came from... sorry cant really help you any more than that? is there a problem with them??
Re: Odd sized coilover springs? Wed, 11 February 2004 04:47 Go to previous messageGo to next message
They are fine, just springs too stiff.. Trying to get a set of 280lbs/in or around about that.
lumpy
Adelaide, SA
Re: Odd sized coilover springs? Wed, 11 February 2004 04:52 Go to previous messageGo to next message
Industrial Engineers and Springmakers in Adelaide can make just about any spring to your spec, or reset your current springs.
Ph (08) 8346 2276
I know they're not local to you, but will probably be reasonably priced compared to most other places. Just tell them what you need and see what they say.
Youngy
Eskilstuna, Sweden
You might have to go Custom Joel, especially if you want a special rate.
It should not be that expensive
IRA11Y
Club Member
280?? you sure you want to go that low??? im using 300Lb
lovells do custom springs at $110 each
[Updated on: Wed, 11 February 2004 04:53]
Re: Odd sized coilover springs? Wed, 11 February 2004 05:17 Go to previous messageGo to next message
I am not experienced enough to pick a good spring rate, but i've been asking a lot of people..
Everyones reponses so far (suspension shops, people involved in motorsport) seem to range from 250lbs up to 300lbs. So I kinda figured 280 is half way on the high side.
Another debate is linear vs progressive. A lot of mixed answers on this one so confused as hell what one to go for.
I figured it would be good if I could find off the shelf springs for the coilovers as then I could change them as needed. But looks like might have to go custom which is cool.
M.J.H
Re: Odd sized coilover springs? Wed, 11 February 2004 08:36 Go to previous messageGo to next message
You can buy 65mmID springs as an off the shelf item.
So here is a thought,do you have enough room to machine 5mm off the spring plate so you don't have to get the springs custom made?
Re: Odd sized coilover springs? Wed, 11 February 2004 22:49 Go to previous message
MJH, thats a good idea mate. Should have thought of that. The top hat might be a bit harder as the spring will be quite loose in there, but either a collar of some sort or maybe just get a whole new top hat turned up the right size.. sweeeet...
Joel
Previous Topic:Special Horn Idea!!!
Next Topic:shipping to gold coast
Current Time: Thu Nov 19 14:35:46 UTC 2026
Total time taken to generate the page: 0.0085039138793945 seconds
