Toymods » Tech & Conversions » Supercharged a 5/6me/ge?
ReQuieM
Supercharged a 5/6me/ge? Thu, 08 August 2002 08:29 Go to next message
has anyone supercharged a 5me 5mge or a 6mge? was thinking of using a toyota stock SC like off a 4agze or 1ggze, (prolly the 1g) any ideas?
tar.
Re: Supercharged a 5/6me/ge? Fri, 09 August 2002 06:54 Go to previous messageGo to next message
I doubt many people have done it because it's ten times easier to bolt on a 7M-GTE manifold and turbo. Results will be way better too!
SUPRAGTE
North Sydney
Re: Supercharged a 5/6me/ge? Fri, 09 August 2002 14:07 Go to previous messageGo to next message
yep do that, it'll go faster
Z1Soarer
Townsville
Re: Supercharged a 5/6me/ge? Fri, 09 August 2002 23:56 Go to previous messageGo to next message
very true, BUT
how possible/viable would it be?
Re: Supercharged a 5/6me/ge? Sat, 10 August 2002 00:45 Go to previous messageGo to next message
The turbo 5M/6M thing has been done HEAPS of times. Subscribe to the Mk2 Supra Yahoo group or the Mk2 forum and supraforums.com, there are plenty of people there who will tell you all about it. The 7M-GTE manifold literally bolts on, you just have to sort out inlet plumbing and fuelling and you're away! Smile
ReQuieM
Re: Supercharged a 5/6me/ge? Sat, 10 August 2002 01:59 Go to previous messageGo to next message
I realize that norb, but i preffer super chargers, turbos a flex able easier yadda yadda but a super chargers different and it has constant boost! Smile was looking at this option cos my ultimate goal atm is and SC'd 1UZ-FE (tho the 7m is still a thought) but i would settle for a good sc'd 5-6m (cheap but still fast)
anyone done it? ideas?
Z1Soarer
Townsville
Re: Supercharged a 5/6me/ge? Sat, 10 August 2002 05:03 Go to previous messageGo to next message
Yep I realise that Norb, I'm currently in the workings of rebuilding my 6M & then I plan on doing just that. only other thing that seems a problem at the mo is that the dizzy looks as though it will be in the way of a 7M Turbo manifold
But what i was asking before, was if the SC 5/6M Idea would be possible
Re: Supercharged a 5/6me/ge? Sat, 10 August 2002 06:19 Go to previous messageGo to next message
Sure it would be possible, but I don't think the 1G blower would be up to the task. I suppose you could overdrive it to buggery to get some decent boost, but it wouldn't last long!
Once you start pricing blowers, you might find yourself re-evaluating your plans. With the exception of second-hand Toyota blowers, they are NOT cheap!
ReQuieM
Re: Supercharged a 5/6me/ge? Sun, 11 August 2002 14:31 Go to previous messageGo to next message
doesnt the 1g blower run 8psi? 10 with an oversized pully thingy. 8psi is 8psi, like i said cheep speed, true thats theres no additional potential but that wasnt my point.
any one with a 1ggze?
kevz0r
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 04:43 Go to previous messageGo to next message
Let me know how u go with this dude, I wouldnt mind giving it a go....
Much prefer a s/c, I dont like to rev my motor that much
Anyone know where the inlet/outlets are on the 1G SC? They have electric clutch like the 4A?
ReQuieM
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 05:12 Go to previous messageGo to next message
will do if i do it! thinking maybe runnin a stock 5m-e even with 8psi might be a bad thing! Smile u should know! btw what was the head gasket set up u ran on ur 5me again?
i heard that it does have an ele clucth might be wrong tho, would be cool to hook up a switch to turn it on and off, mad max style! Smile
kevz0r
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 06:06 Go to previous messageGo to next message
heh 5m-e with boost is bad! hehehe
I found that the 5M-E headgasket used to keep curling up at the metal that surrounds the water jackets. 4M has no metal, and that worked well.
I also ended up using two 1.5mm head shims. However, that was because my head was below the minimum usable size and used to ping like a mofo.
However, once it was all back together fine it held the boost no problem.
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 07:21 Go to previous messageGo to next message
ReQuieM wrote on Mon, 12 August 2002 12:31 AM
No, it doesn't work like that. Boost is a function of blower displacement and engine displacement. An SC14 will deliver 8psi on a 2 litre engine, but bolt it to a 3 litre engine and all that changes!
Theoretically you would need to overdrive the blower by a factor of 50% to deliver sufficient volume to get 8psi on a 3 litre engine, but if you try that you will take the blower way past its redline and way out of its efficiency envelope. The 1G blower is simply too small for a 3 litre engine, there's no getting around that fact. Sad
[Updated on: Mon, 12 August 2002 07:21]
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 07:25 Go to previous messageGo to next message
eh, you beat me! Freak
Too small, you need 2 or a bigger one
ReQuieM
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 12:51 Go to previous messageGo to next message
2?? is that possable? sensably possiable that is! Smilei dont know how the 1g SC is set up but seems more trouble then its worth. any larger stock toyo sc's? OR cheap SC's?
ReQuieM
Re: Supercharged a 5/6me/ge? Mon, 12 August 2002 12:52 Go to previous messageGo to next message
ALSO what then is the difference between teh SC13 and the SC14 then? what disp. is the 4agze? 1.8-2? cant remember! Smile
Re: Supercharged a 5/6me/ge? Tue, 13 August 2002 08:46 Go to previous messageGo to next message
Two superchargers would get messy in a hurry. A turbo setup would be a lot cheaper and easier to install.
I don't think Toyota makes anything bigger than the SC14. As for other OEM stuff, about the only common one I can think of is the Commodore blower as fitted to their 3.8 litre V6. This would be about the right size for your engine, but from what I've heard they're not exactly cheap as all the Commodore-driving bogans want them.
The difference between the SC12 and SC14 is their displacement, which is 1.2 litres and 1.4 litres respectively. The 4A-GZE is a 1.6 litre engine, the 1G-GZE is 2 litres.
ReQuieM
Re: Supercharged a 5/6me/ge? Tue, 13 August 2002 14:28 Go to previous messageGo to next message
Norbie wrote on Tue, 13 August 2002 6:46 PM
yeah i figured so.
thought so, pitty
haha again it figures! Smile
arr the 4agze is 1.6 litres feh nuf wasnt sure!
doesnt matter was a thought something different to a turbo, might find out a price on the commy one tho, could be alright priced.
Re: Supercharged a 5/6me/ge? Tue, 13 August 2002 22:56 Go to previous messageGo to next message
5MG, 7MGTE exhaust manifold and CT26. Happy, healthy, uncomplicated, relatively inexpensive. There's even a Yahoo group that are devoted solely to doing exactly this.
ReQuieM
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 03:44 Go to previous messageGo to next message
ar but there u have it been done before! Very Happy plus i dont have a 5mge atm and if i'm gonna swap in another m engine it'll be a 7mgte, save all the problems, but i'm still interested in super charging it tho.
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 06:27 Go to previous messageGo to next message
So are you saying you're prepared to invest much more money and effort to get the same result, just to be "different"?
Whatever floats your boat dude!
ReQuieM
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 07:06 Go to previous messageGo to next message
yeah but not the same results tho! SC'd would get power the whole way through the rev range, that low down power is what i like! Very Happy
mr supra
Wollongong
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 07:57 Go to previous messageGo to next message
you could always go to a truck or tractor wrecker see if they have any off the supercharged 2 stroke cummins or perkins or whatever they are....
I'd imagine you could get something like a 4/71 "relatively" cheap, having never done it though I don't know...It will look shitty and weigh a heap but it will give you boost....
a 4/71 is for a 4652cc motor though so you would probably have to underdrive it..I don't know how much boost they push though...
ReQuieM
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 08:14 Go to previous messageGo to next message
how heavy would that sucker be?
mr supra
Wollongong
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 08:19 Go to previous messageGo to next message
I dunno..they are pretty chunky as they are a GMC or something like that, I mean they are made for trucks so you can imagne the rest!
but on the other hand they should be nice and understressed and there are probably smaller ones that will drain less power than that big sucker does.
ReQuieM
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 08:29 Go to previous messageGo to next message
hmmmmm.... thanx for the tip off! might have to check it out!
mr supra
Wollongong
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 08:34 Go to previous messageGo to next message
if you wanted to be really reeaallly individual you could always use the entire motor.....theres nothing quite like the noise of what is essentially a 4.5L chainsaw at full song Razz hehehe
keeping the front end off the tar could be a problem there though...
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 10:44 Go to previous messageGo to next message
A PD supercharger will deliver nearly full boost at idle, but they become very inefficient at higher rpm. Why do you think the Mk1 MR2 boys upgrade to turbo when they want more power?
Also, a supercharged engine will always produce less power than a turbocharged engine at any given boost level, all else being equal. One of those big GMC superchargers would probably take at least 50hp to turn!
Allan
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 11:01 Go to previous messageGo to next message
the blower off a 1g-gze can be fited to a 3.8ltr commonwhore for mild boost i see no problem with a 2.8ltr! finding somewhere to mount the big sucker maybe tho!
supercharging is defeintly a different fun to a turbo its like displacement on a switch Smile and with the 5m-e the ecu should handle it with out to much drama with a risen' rate FPR.
I say go for it!
Allan
ReQuieM
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 13:09 Go to previous messageGo to next message
hey allen what are the results like on a commy? much hp nm difference? or even seat of pants difference? if the results are truly decent i might give it a crack! Smile exactly how big is the SC14?
I realise this norbie but as i've said many times already i want constance boost not heaps of it. its a bit of a jump not ment to be a super hp monster. Mk1 mr2 boys change to turbos cos turbos are as a said more flexable and easier to turn up sc are basicaly set at one boost level.
Allan
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 13:16 Go to previous messageGo to next message
take a drive down to shepperton and see Andrew down at centeral vic auto parts hes got a few there you can look at, there was a big artical in an old Zoom mag ring em up get a back issue!
Allan
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 14:21 Go to previous messageGo to next message
The article failed to go into the severe limitations the SC14 had on the 3.8l V6. It's just a bigger Turbozet, relatively speaking. The general consensus from the Commodore boys is "don't bother".
ReQuieM
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 14:30 Go to previous messageGo to next message
http://www.autospeed.com/A_0872/page1.html
XF running 2 SC14's 15psi of boost if i remember right.
Allan
Re: Supercharged a 5/6me/ge? Wed, 14 August 2002 14:32 Go to previous message
it will make a bigger difference on a 2.8ltr i think a crummy puts out about 80kw something at the wheels and my good example of a stockish 5m put out 63!
Allan
Previous Topic:MAP ECU pickup when using quad throttles with trumpets
Next Topic:Custom Inlet Manifold (4AGTE)
Current Time: Thu Nov 19 21:54:19 UTC 2026
Total time taken to generate the page: 0.0096678733825684 seconds
