Toymods » Tech & Conversions » AW11 handbrake WILL NOT work
Adsport
Perth WA
AW11 handbrake WILL NOT work Wed, 11 February 2004 01:12 Go to next message
damn thing, i tensioned it up to about 20mm from the end of the adjustment, seemed to work OK but not the best, changed my pads for newys and it ceases to work once more, its now adjusted up to 100% of the adjustment , feels like its working but simply refuses to co operate.... ive had a look at the system and the way its setup and adjusted and wiggled everything maybe ive overlooked something little?
._T_.
Re: AW11 handbrake WILL NOT work Wed, 11 February 2004 01:42 Go to previous messageGo to next message
put the car on stands. apply foot brake. see if friend can turn the rear wheels - if so piston/s siezed.
otherwise check if the cables are rusted up (back off and see if they move)
T
86twinky
Re: AW11 handbrake WILL NOT work Tue, 09 March 2004 06:47 Go to previous messageGo to next message
when you replaced the pads did you wind the piston's back in properly? or were they simply pushed back in with a g clamp?? may seem like a stupid question but i have seen it done before.
feral4mr2
Bundaberg, Qld.
Re: AW11 handbrake WILL NOT work Tue, 09 March 2004 11:14 Go to previous messageGo to next message
Freak as in T's post, check your cables. mine where seized up, i pulled them off an slowly worked (and cleaned) the inner cable back and forth in the outer with Inox. works fine now. Smile
old_mr2
Re: AW11 handbrake WILL NOT work Tue, 09 March 2004 14:22 Go to previous messageGo to next message
My handbrake is limp at the moment. Both cables are broken. Sad
I have to park on flat ground.
adamb131
Re: AW11 handbrake WILL NOT work Wed, 10 March 2004 03:39 Go to previous message
Ha ha... me too... maybe we need a group buy on AW11 handbrake cables Laughing
But seriously 'handbrake freeze' is a common AW11 problem.
See www.mr2.com for info on this!
Previous Topic:Freakin' 7M head gaskets!!!!!
Next Topic:vapour lock
Current Time: Thu Nov 19 00:31:22 UTC 2026
Total time taken to generate the page: 0.010644912719727 seconds
