Classifieds » Parts Wanted » wanted: bluetop 4AGE crank
BadFunkStripe
wanted: bluetop 4AGE crank Wed, 11 February 2004 04:52 Go to next message
in need of a bluetop (86kw) either FWD or RWD 4AGE crankshaft, rebuilding my bottom end and one journal on mine is too stuffed to repair.
dorikin
NE Melbourne
Re: wanted: bluetop 4AGE crank Wed, 11 February 2004 05:42 Go to previous messageGo to next message
i got one in melb that isn't doing me any good, only catch is that its in a short block. if this helps you at all???
TerryOBeirne
Redbank Plains,near Ipswi...
Re: wanted: bluetop 4AGE crank Wed, 11 February 2004 21:19 Go to previous messageGo to next message
I have a good 4AG crank. dont know exact model, but it prob came out of one of the 4A engines I put billet cranks in for racing. appears fine but can measure it. $50 + post (about $25-$30 depending where you are). let me know & I'll check
BadFunkStripe
Re: wanted: bluetop 4AGE crank Thu, 12 February 2004 03:31 Go to previous messageGo to next message
Terry
i'm in adelaide so not sure how much the postage will be but if it is the early model 40mm big end (later model 42mm) and in good nick ill take it.
let me know
Shane
TerryOBeirne
Re: wanted: bluetop 4AGE crank Thu, 12 February 2004 06:28 Go to previous messageGo to next message
bugger, i forgot, this is a 42mm crank for sure. I have another older short engine that will be 40mm. I'll check that + post costs in a day or so. if you are in a panic, call me direct on 07-38143762 and we can confirm. knocked out big ends are a sure sign of over-revving!!.
BadFunkStripe
Re: wanted: bluetop 4AGE crank Thu, 12 February 2004 11:20 Go to previous messageGo to next message
cheers terry
it spun a bigend bearing at about 6500 rpm and scored the journal pretty badly. the other bearings were all pretty worn, i think the engine is a bit older than the 100,000ish km the importer assured me it had. just get back to me when you can about the other crank.
shane
GZE-STYLE
Camden
Re: wanted: bluetop 4AGE crank Fri, 13 February 2004 01:55 Go to previous messageGo to next message
i have one here. Only prob is im in sydney...50 bucks plus freight?
BadFunkStripe
Re: wanted: bluetop 4AGE crank Wed, 18 February 2004 05:05 Go to previous messageGo to next message
terry have you had a chance to check that other crank yet?
GZE-STYLE what condition is the crank in? how many kms?
TerryOBeirne
Re: wanted: bluetop 4AGE crank Thu, 19 February 2004 05:03 Go to previous messageGo to next message
shane, In luck, I have found another good rear drive early crank. no marks etc but have not yet measured it (but can do). it is a cast steel and came with a pile of engines I bought from a local impoter that went bust. same price as before. let me know
BadFunkStripe
Re: wanted: bluetop 4AGE crank Thu, 19 February 2004 06:54 Go to previous messageGo to next message
terry thanks measure it up, should be 40mm if its rear drive. if it is ill take it.
BadFunkStripe
Re: wanted: bluetop 4AGE crank Mon, 23 February 2004 06:48 Go to previous messageGo to next message
*bump*
TerryOBeirne
Re: wanted: bluetop 4AGE crank Mon, 23 February 2004 11:07 Go to previous message
sorry for delay. i'm away for work. will try to measure it this thursday as soon as I get home. it looks OK, but will give you accurate results. terry
Previous Topic:MX83 Cressida towbar [Melb]
Next Topic:4ac
Current Time: Fri Oct 30 15:50:58 UTC 2026
Total time taken to generate the page: 0.006417989730835 seconds
