Toymods » Tech & Conversions » Cressida 1JZ-GTE Conversion
Supra_Man
Perth, Australia
Cressida 1JZ-GTE Conversion Wed, 11 February 2004 07:31 Go to next message
hey guys i need help on finding a wiring diagram. i did the whole engine and loom conversion from gx-81 mark II. into a 1990 cressida glx. i swapped the digital dash over as well.
now my car wont change gear and the speedo doesnt tell me how fast im going.
so if u can help on a wiring diagram
i would really appreciate it
sideshow
Re: Cressida 1JZ-GTE Conversion Wed, 11 February 2004 09:39 Go to previous messageGo to next message
fuk u did it the hard way
anyway
make sure u have 12v ign
earth and signal
from the electronic speed sensor on back of gbox
the signal goes up to the speedo head and drives the speedo
then the signal goes from out back of speedo to the
ecu and makes the gears change
another lil trick is make sure the tiny pin for the speedo sensor hasnt fallen out
it slides into the speedo drive then it spins the sensor
Chris Davey
sunny coast, qld
Re: Cressida 1JZ-GTE Conversion Wed, 11 February 2004 09:54 Go to previous messageGo to next message
he did it the same way i did then and had the same problem as me Smile
sideshow
Re: Cressida 1JZ-GTE Conversion Wed, 11 February 2004 10:02 Go to previous messageGo to next message
hehe maybe he has lost that lil thingy tooo
i might be able to get one if u need one
im goin to melbourne in 3 weeks to wire up
a 1jz into an mx83
and to get auto running tooo
shouldnt be too hard just long
and while im there i might check out the f1 Smile
[Updated on: Wed, 11 February 2004 10:12]
1JZ.747
Osama's hideout
Re: Cressida 1JZ-GTE Conversion Thu, 12 February 2004 00:54 Go to previous messageGo to next message
i used everything from the JZX81 chaser and i never had a problem.
stripped everything from the seats forward. put everything from the halfcut in my cressida plugged the rear harness to the front harness, (plug is next to drivers right foot behind kick panel) turned the key and drove away, speedo worked everything worked other than my climate control and my fuel guage.
i dont see how its the hard way, but every one has there opinion.
Supra_Man
Perth, Australia
Re: Cressida 1JZ-GTE Conversion Sun, 15 February 2004 06:28 Go to previous message
cheers guys ill tell my mechanic that and see how it goes. if that doesnt work ill be back Razz
Previous Topic:problem with TA23 hilux/pug/corona brake upgrade
Next Topic:Choices
Current Time: Sat Nov 21 04:07:43 UTC 2026
Total time taken to generate the page: 0.021020889282227 seconds
