Toymods » Members Rides » 1986 Toyota Soarer GZ20 with 1JZ-GTE
Danish
icon4.gif  1986 Toyota Soarer GZ20 with 1JZ-GTE Wed, 11 February 2004 09:06 Go to next message
1986 Toyota GZ20 with 1JZ-GTE conversion.
This car is now sold.
http://www.users.bigpond.net.au/soarer/
Scroll down for new pictures.
  • 1JZ-GTE
  • 3" Exhaust from y-piece with high flow cat & APEXi Megaphone Dunk Muffler
  • Hiperboost controller
  • Stainless steel intake pipe with HKS airfilter
  • W57 standard 5 speed gearbox
  • JZA70 Torsen LSD
  • Hybrid 600*300 FMIC
  • JZA80 water pump
  • MicroTech LTX12
  • MicroTech Handset
  • Autometer water temp gauge
  • 2 electric thermo fans
  • Heavy duty organic clutch
  • Greddy gearknob
  • Cusco Comp 2 height & damper adjustable coilovers
  • Pioneer deck and speakers
  • Aftermarket alarm
  • Bosch 979 fuel pump
  • Oil filter relocation kit & oil cooler
  • Supra MA70 brake upgrade
  • 300ZX 16x7" Wheels, 225x50 Rubber
210kw at the wheels with 13PSI.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2451.JPG
Engine bay without oil cooler, oil filter relocation kit and black box to contain the boost controller.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2462.JPG
The interior before I took the oil pressure gauge out.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2614.jpg
The interior as it is now.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2616.jpg
The latest picture of the engine bay with oil relocation kit and box for the boost controller visable. Also with electrical work.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2617.jpg
The new updated grille with the new oil cooler behind it.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2618.JPG
Oil filter relocation kit adapter.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2619.jpg
Oil filter relocation kit.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2620.jpg
Latest picture of the car at dusk.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2621.jpg
[Updated on: Thu, 20 October 2005 14:23]
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Wed, 11 February 2004 09:39 Go to previous messageGo to next message
Looks cool dude!
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Wed, 11 February 2004 11:05 Go to previous messageGo to next message
Thanks mate, it still has a lot of work do to. The top picture was taken before it was lowered. It's all time and money. I'd like to get it out on the track!
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Mon, 16 February 2004 17:45 Go to previous messageGo to next message
Well it's 99% completely rewired courtesy of Gary at Eddies Auto-electrical. It looks so much cleaner than previously and I can now trust it to be entirely reliable in the electrical department. The air-conditioner is running better than standard after many new relays and fuses were added, along with some modifications to the compressor fittings and power steering sensors.
It's going into Fours N More soon to have the Torsen LSD put in and most importantly the gearbox and diff seals looked at. Later down the track the MicroTech will be modified to allow for an idle device to allow for the a/c and p/s and also to maintain a standard idle on cold start up. On the other hand there is no problem with it at the moment, even when the above are operating. It currently idles at 1000RPM when warm and 700RPM with the a/c on.
I have found some JZA70 front calipers from a friend and will be eventually buying some DBA MA70 slotted front rotors along with it. However, some 16" or 17" wheels will have to be found to clear the larger disc's.
It may be a while before Exhaust Technology can put on my Hybrid inter-cooler with stainless steel piping though.
[Updated on: Tue, 17 February 2004 02:34]
STR8 2.8
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Tue, 17 February 2004 01:55 Go to previous messageGo to next message
Danish wrote on Tue, 17 February 2004 04:45
It currently idles at 100RPM when warm
Shocked
are you sure
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Tue, 17 February 2004 08:25 Go to previous messageGo to next message
Unfortunately it has overheating problems at the moment in very hot weather. I think I'll have to look into a thicker aluminum racing radiator. Sad
bbaacchhyy
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Wed, 18 February 2004 03:59 Go to previous messageGo to next message
You should only need 16's, as that is what the std MA70's are so they should fit.
Arn't the JZA70 calipers the same as MA70's ?
Michael B
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Wed, 18 February 2004 07:42 Go to previous messageGo to next message
Yes you are right bbaacchhyy, but If I can find 17" standard JZA80 wheels they will look a lot better, fill the arch of the wheel space and be pimpen! However, 16" will do as they are hard to find. They will also raise the car slightly higher which I want.
There are variations of sizes of MA70 rotors and possibly calipers. One variation is the same as the JZA70. I am actually getting them from a JZA70 though (thanks Caelum).
Very Happy
T APLUS 22
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Wed, 18 February 2004 08:26 Go to previous messageGo to next message
Danish wrote on Wed, 18 February 2004 18:42
How will 16" wheels raise the car? The overall diameter should be the same mate.
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Sat, 21 February 2004 04:21 Go to previous messageGo to next message
It will if the profile is the same as the 15".
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Tue, 13 April 2004 09:29 Go to previous messageGo to next message
I recently added an oil cooler and remote oil filter kit. There are also pictures of my MA70 brakes which will go on as soon as I can find a set of 16" or 17" wheels.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2622.jpg
APEXi Dunk Muffler.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2623.jpg
Soarer MA70 rotors and calipers.
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2624.jpg
[Updated on: Sat, 17 April 2004 09:13]
HKS_TRD
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Tue, 13 April 2004 10:15 Go to previous messageGo to next message
Looks nice,
so will you be at the next cruise with it then? I think I may have spoke to you at the last one.
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Tue, 13 April 2004 10:44 Go to previous messageGo to next message
HKS_TRD: Thanks mate, who are you, and what do you drive? Smile
I work Friday and Saturday nights, so I'm not sure if I'll be able to make it. I'd like to though.
The car seems to be running very well since I put my undertray back on and had the oil cooler installed.
The only other thing I've noticed is that the power steering is making hellish noises, clunking and cracking sounds on full lock at low speed.
I'm dying to get my intercooler and brakes on with bigger wheels though. Has anyone got any Supra or Soarer 16" wheels for sale?
HKS_TRD
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Tue, 13 April 2004 11:02 Go to previous messageGo to next message
If you are after some wheels try the guys down at D1 garage they have just had a new container come in. I drive a black MA70, the one in this link
http://www.turbosupras.com/pages/members/dannyc.ht m
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Tue, 13 April 2004 11:28 Go to previous messageGo to next message
That is one staunch 7M Dan. I thought it would be up around the 300kw mark with those mods? Very nice! What does your car weigh? Would be good to go on a cruise with you.
HKS_TRD
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Wed, 14 April 2004 02:20 Go to previous messageGo to next message
OK, I guess it wasnt you that I was speaking to at the last Toymods cruise starting point at harbourtown:-) Whoever it was did own or had owned a Soarer. 300+kw at the wheels is my goal and everything is there to do it but the hi flow turbo is at its limit to make 250kw at the wheels. I have a wastegate and manifold waiting to go on, just gotta decide on what turbo to go with. Nice conversion on the Soarer don't think many people have done that yet, I've always liked those early Soarers myself
[Updated on: Wed, 14 April 2004 02:22]
Chris Davey
sunny coast, qld
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Thu, 29 April 2004 11:50 Go to previous messageGo to next message
looks great Danish!
Would have loved to have done what you have to my old gz20 but then the Corona came along Smile
keep up the good work!
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Mon, 23 August 2004 14:00 Go to previous messageGo to next message
Some recent pictures.
Latest dyno tune:
http://www.users.bigpond.net.au/soarer/Soarer%20Dyno.jpg
Intercooler:
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2711.jpg
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2713.jpg
http://www.users.bigpond.net.au/soarer/enginebay/DCP_2714.jpg
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Thu, 21 October 2004 08:45 Go to previous messageGo to next message
Some recent pictures with the 300ZX 16" Wheels replacing the JZA80 wheels.
http://users.bigpond.net.au/soarer/Exterior/GZ201.jpg
http://users.bigpond.net.au/soarer/Exterior/GZ202.jpg
Adam_Rolla
Sydney, NSW
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Thu, 21 October 2004 19:05 Go to previous messageGo to next message
nice car m8
looks sweet
Jag7799
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Thu, 21 October 2004 20:58 Go to previous messageGo to next message
Danish wrote on Tue, 24 August 2004 00:00
Latest dyno tune:
Intercooler:
i like the power curve.. im guessing thats with celicamads wastegate controller turned up?
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Fri, 22 October 2004 03:54 Go to previous messageGo to next message
Nah actually it was just a good power tune by Tim Possingham. He really does know his MicroTech's.
I put the Hiperboost controller on afterwards, so imagine how it goes now.
Jag7799
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Fri, 22 October 2004 06:23 Go to previous messageGo to next message
Danish wrote on Fri, 22 October 2004 13:54
i see why it looks so peaky now.. urs goes up in increments of 20 where as my dyno goes up in 10
for the same spacing
this was mine before hiperboost squashed to give the same incremented curve as yours
http://members.optushome.com.au/jag7799/squashy.jpg
just looking at it.. mine eclipses yours at every point at the same speed..but ur curve is a lot nicer and doesent have the weird stupid hump mine had
how many psi was it on?
i was on 11
[Updated on: Fri, 22 October 2004 06:26]
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Fri, 22 October 2004 07:08 Go to previous messageGo to next message
That picture doesn't work. It was set to roughly 12-13PSI.
Jag7799
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Fri, 22 October 2004 07:13 Go to previous messageGo to next message
Danish wrote on Fri, 22 October 2004 17:08
pic does work.. try refresh it
Danish
icon14.gif  Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Wed, 27 October 2004 09:22 Go to previous messageGo to next message
The web site is up to date with the latest information and pictures!
http://www.users.bigpond.net.au/soarer/Exterior/DCP_3063.jpg
http://www.users.bigpond.net.au/soarer/Exterior/DCP_3072.jpg
http://www.users.bigpond.net.au/soarer/Exterior/DC P_3066.jpg
http://www.users.bigpond.net.au/soarer/Exterior/DCP_3071.jpg
http://www.users.bigpond.net.au/soarer/Exterior/DCP_3066.jpg
[Updated on: Wed, 27 October 2004 09:25]
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Wed, 27 October 2004 09:24 Go to previous messageGo to next message
The new idle control device is in, so the car now idles like factory at cold start, and when warm. It also idles up with the airconditioner. Courtesy of Brenton from Fours N More.
http://forums.toymods.org.au/index.php?t=msg&t h=49653&start=0&rid=2416&S=83089b7e873 367a9a6e665f5a6daf573
Very Happy
[Updated on: Thu, 09 December 2004 05:18]
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Thu, 09 December 2004 05:14 Go to previous messageGo to next message
The JZA70 Torsen LSD is now in courtesy of Boss Racing Differentials: 8387 0178.
After taking out the diff myself, I had to get Steve at Japanese Motorsport to put the new one in. I ended up dropping all 50kgs of the thing on my hand in the process.
The car now handles a lot better. I've also purchased a set of Cusco fully adjustable coilovers which will go in soon.
MR 1JZ
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Sat, 11 December 2004 03:41 Go to previous messageGo to next message
well actually they wiegh 43kg's dude Razz Laughing
Lookin good time for some dorifto me thinks Wink
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE *New Pictures* Sat, 11 December 2004 04:16 Go to previous messageGo to next message
Well... If you want to get technical, the Torsen is noticeably heavier! Dorifuto a-go-go.
MR 1JZ
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Sat, 11 December 2004 04:23 Go to previous messageGo to next message
7 kgs heavier?
really?
Danish
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Thu, 13 January 2005 08:49 Go to previous messageGo to next message
Cusco's are in all corners now, and it gets loose very easily.
MR 1JZ
Re: 1986 Toyota Soarer GZ20 with 1JZ-GTE Thu, 13 January 2005 13:37 Go to previous message
Danish wrote on Thu, 13 January 2005 19:19
DORIFTOOOOOO! Laughing
Previous Topic:Dylans AE86
Next Topic:PICTURES OF MY JZA70 - TYPE R SUPRA
Current Time: Sat Oct 24 16:17:32 UTC 2026
Total time taken to generate the page: 0.0072929859161377 seconds
