Toymods » Tech & Conversions » Bosch Coil with ballast resistor...
Green_Comet
Victoria, Melbourne
Bosch Coil with ballast resistor... Wed, 11 February 2004 10:04 Go to next message
Hi guys,
Well just got myself a Bosch GT40RT transformer ignition coil
today and i seem to have run into a bit of a problem... Confused
It says that the coil needs to b used in conjunction with a ballast resistor.
Did the Aus Spec ae86 come with a ballast resistor or do i need to install one?
If so what type of ballast resistor?
If i knew i was going to run into a problem like this i would have got the GT40R and just slapped it in!! Very Happy
Any info is much appreciated!
Ryan
sideshow
Re: Bosch Coil with ballast resistor... Wed, 11 February 2004 10:13 Go to previous messageGo to next message
the r in gt40 stands for
use with a resisotr
u need a gt40 if u want to run no resistor
unless things have changed over past 5 yrs
its been awhile sine ive bought coils
Re: Bosch Coil with ballast resistor... Wed, 11 February 2004 12:32 Go to previous messageGo to next message
Depends what engine you're using - if you're using a 4AC with stocky point ignition( Embarassed ), then yup, there's a resistor there.
clubagreenie
1st street on the right
Re: Bosch Coil with ballast resistor... Wed, 11 February 2004 20:45 Go to previous messageGo to next message
You can just get rid of the resistor and use a gt40. Just remove the res and wire direct to coil. I've done this in more things than I care to remember without porblems. Just sends 12 volts to coil instead of 8 (which some get fed at startup anyway).
Re: Bosch Coil with ballast resistor... Thu, 12 February 2004 06:24 Go to previous messageGo to next message
GT40 or GT40R??
do not use these GT40 coils with elec ignition. they will die.
i give them about two weeks with the jaycar HEi kit Wink (well didn't give but thats what they take Rolling Eyes )
ps, they are fine for points tho, they just can't deal with the higher dwell of elec.
Green_Comet
Victoria, Melbourne
Re: Bosch Coil with ballast resistor... Thu, 12 February 2004 06:29 Go to previous messageGo to next message
oh ok, yeah coz im installing a 4age next week, so im going to install the gt40rt with a ballast resistor i picked up 2day!!
thanks for the help. Smile
Ryan
clubagreenie
Re: Bosch Coil with ballast resistor... Thu, 12 February 2004 10:33 Go to previous messageGo to next message
Stewart, Can you elaborate on how it's affected by increased dwell? No disbelieving you, just furthering my ed. As I understand, the resistor allows 8 volts to the coil (why?) but checking a 5me elec setup I have here with resistor it bypasses at startup and feeds 12v.
Best prior experience I've had is on range rovers which don't have a resistor but a resistive wire as the feed to the coil. This burns out and we just replaced the wire with std and ran a non resistive coil, elec or points.
Pls explain
M.W.P.
Rocky Mountains, Canada
Re: Bosch Coil with ballast resistor... Thu, 12 February 2004 12:32 Go to previous message
Reduced dwell (longer charge time) can possibly cause a non-suitable coil to overheat and die.
Most ballast restitors drop 6-8V to the coil during running, again, to stop overheating.
It gets bypassed at startup, supplying 12V to allow for easier cold-starts (rich mixtures).
Previous Topic:Ecu wiring diagrams
Next Topic:MA70 head unit swap-over (making it look neat)
Current Time: Fri Oct 23 03:01:59 UTC 2026
Total time taken to generate the page: 0.005763053894043 seconds
