Toymods » Tech & Conversions » 1jzgte 5 speed -> VN ('91 holden ute)
teq-
1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 12:45 Go to next message
has anyone ever attemped a conversion from a v8 to a straight 6?
My main concern is the lenght of the engine, and obviously not fitting into the engine bay..
I'm kind of hoping someone might have specs on the length of the actual 1jz.. im also chasing the length of the 304.
I bought the halfcut this morning, I'm getting the ute tomorrow, its going to the shop next week to have the cross members done, god willing.
someone help me, im worried it wont fit :/
Re: 1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 13:20 Go to previous messageGo to next message
Definitely has been done. There was someone on these forums who had done it.
teq-
Re: 1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 20:23 Go to previous messageGo to next message
Yeah I found this, http://www.cardomain.com/id/96jet
Slept a bit better after finding that.
Grega
melbourne.victoria.austra...
Re: 1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 20:51 Go to previous messageGo to next message
yep, common
folks also put the rb30et and the rb2x variants in them
so you'll be fine.
the engine bay on the vn onwards is pretty cavernous anyway!
Re: 1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 22:37 Go to previous messageGo to next message
If you want to be a slackarse and use a Nissan RB 6, bolt in a VL crossmember and the fabrication is then done Evil or Very Mad
teq-
Re: 1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 22:55 Go to previous messageGo to next message
nah, I already have the 1JZGTE halfcut sitting in my back yard
plus, the 1j is a better engine (imo)
Skip
Re: 1jzgte 5 speed -> VN ('91 holden ute) Wed, 11 February 2004 23:27 Go to previous messageGo to next message
mrshin wrote on Thu, 12 February 2004 06:37
I don't think a VL crossmember will bolt into a VN Smile
Im pretty sure there are a few early commodores running around with 1J's, id say the VN would have an even larger engine bay. Definitely an interesting conversion, will be the smoothest VN ute around.
teq-
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 00:14 Go to previous messageGo to next message
standard the ute had 165kw, now its going to have "208kw" (japanese law thing), then add a haltech system.. so yeah, should haul.
lots of people are saying "what the" when i tell them, they keep telling me to leave the 304 in it, but meh.
The 1jz will go harder, and its unique.
I'm also offing the 304 with 5 speed box for the same price i paid for the 1jz halfcut, so all in all its not too bad
Skip
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 01:50 Go to previous messageGo to next message
250 kW 1JZ = Cheap and easy
250 kW 304 = Not so easy, not so cheap
Should go pretty darn hard, it makes me laugh that you can buy a 1JZ manual halfcut for the same price as you can sell your 304 and 5 speed Laughing BTW, how many km's does the 304 have? Probably alot more than the 1JZ.
teq-
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 03:23 Go to previous messageGo to next message
249,000k's on the 304 $3500 - 1991 model
90,000k's on the 1jz $3800 - 1992 model
both 5 speed
Grega
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 06:00 Go to previous messageGo to next message
a VL engine crossmember 100% bolts into a VN.
hence why the rb2x series motors go in very easy - only custom gearbox crossmember required.
BlackSupra
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 06:37 Go to previous messageGo to next message
gianttomato wrote on Thu, 12 February 2004 00:20
"quick 6"
Skip
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 07:12 Go to previous messageGo to next message
Grega wrote on Thu, 12 February 2004 14:00
Well there you go, Holden dont really make a habit of updating things very often do they. Would a VL crossmember bolt into a VS?
teq-
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 07:17 Go to previous messageGo to next message
well VN-VY are all the same enine mounts, so it should
Grega
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 19:49 Go to previous messageGo to next message
yes a VL engine crossmember goes into the VS, but, not the VT onwards
Skip
Re: 1jzgte 5 speed -> VN ('91 holden ute) Thu, 12 February 2004 23:16 Go to previous messageGo to next message
How similar are the struts and brakes between VK, VL, VN, VR etc?
Grega
Re: 1jzgte 5 speed -> VN ('91 holden ute) Fri, 13 February 2004 20:40 Go to previous messageGo to next message
almost identical up to the VP, the VR onwards changed dramatically with a hub style setup that the rotor bolts to, whereas the earlier ones VB-VP the hub is integral to the rotor.
why for you ask?
i know you can use the struts from a VS on a VB a dude is doing this now the control arms are the same (cast alloy on VS) and Z bar mount points are also different but the only issue is the strut top bearing plate (which you could make a custom one if it bothers you that much.
with the brakes the caliper mounting holes didn't change - therefore if you're keen with a hub adaptor you can fit VX rotors and calipers onto your VB. you can fit them to (i think VR) and VS using a special rotor from DBA for this purpose, otherwise you need the adapter. the VT onwards use a twin piston sliding caliper design, then VN V8 and VL turbo have a single pot alloy finned caliper which is also OK, the std commodore brakes from VB on are pretty dismal.
if you're going the 1J option, use the VT calipers. get yourself a pair of VS struts, use the custom DBA rotors and get a top bearing plate made to suit the top of the strut. i can help you here with bits and pieces let me know.
Re: 1jzgte 5 speed -> VN ('91 holden ute) Sat, 14 February 2004 06:09 Go to previous messageGo to next message
teq- wrote on Thu, 12 February 2004 11:14
Best part is that most of the people you say this to will go 'nah mate, it's a 308, no such thing as a 304...' You'd be amazed how many times I've heard this said! I'll be silly enough to speak up and remind them the 308 died with the VH, and get 'nah, bullsh!t mate, 308. And that Chev thing in them new ones is a 350 smallblock'. Funniest part is, the GEN3 DOES displace 350 cubes!
Plus: It'll be the first VN to ever idle on the correct number of cylinders!
Grega
Re: 1jzgte 5 speed -> VN ('91 holden ute) Sat, 14 February 2004 06:48 Go to previous messageGo to next message
shinny - oi you dissin the vn? Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
you KNOW the don needs one... Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
i've heard the EXACT same thing SO many times, nah, its a 308, until you mention 304 and you get shouted down. pha why bother.
beerfart
adelaide
Re: 1jzgte 5 speed -> VN ('91 holden ute) Sun, 15 February 2004 01:16 Go to previous messageGo to next message
i have put a vl crossmember into a vs,bolted straight in.also fitted manual steer vl rack,also fitted straight in,vb-vk racks are different to vl.pretty useless info on a toyota site ay
Grega
Re: 1jzgte 5 speed -> VN ('91 holden ute) Sun, 15 February 2004 04:14 Go to previous messageGo to next message
beerfart no such thing as useless information Smile
Skip
Re: 1jzgte 5 speed -> VN ('91 holden ute) Sun, 15 February 2004 23:55 Go to previous messageGo to next message
Grega: Just curious, remember they looked pretty similar thats all.
BTW the 308 ended in the VK model not the VH. However the later VK's had 304's Smile
Grega
Re: 1jzgte 5 speed -> VN ('91 holden ute) Mon, 16 February 2004 04:50 Go to previous message
so it ended in the VK Very Happy
Previous Topic:W-5X x-member compatibility?
Next Topic:ST162 Cricket noise inside dash
Current Time: Thu Oct 22 07:54:07 UTC 2026
Total time taken to generate the page: 0.0072970390319824 seconds
