Toymods » Tech & Conversions » ST162 Cricket noise inside dash
ovaltine
ST162 Cricket noise inside dash Thu, 12 February 2004 02:56 Go to next message
There's a cricket-like noise inside the dash of my ST162. Comes & goes, depending on engine rev/vibration. Doesn't do it without load, so I can't look for it while the car is sitting still. It sounds like a loose metal clip vibrating somewhere, but I just can't pinpoint it. Anyone had this problem before? Sad
levos1
E.W
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 03:34 Go to previous messageGo to next message
Mine made a similar noise,
Is it coming from the front passenger footwell??
I believe it is the airconditioning!!
Mine did it after the aircon had been running for a while. Try turning the aircon from low to full and back and it should stop. but will come back after a while.
clubagreenie
1st street on the right
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 04:12 Go to previous messageGo to next message
Cricket like bat and ball or cricket like insect?
Very Happy
ovaltine
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 06:50 Go to previous messageGo to next message
I'm not using the aircon and it's happening. I'll see what happens if I turn it on. It also seems to come from the driver side, not the passenger side.
ovaltine
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 06:53 Go to previous messageGo to next message
It's cricket like the insect. I'll try spraying with Baygon if nothing else works. Very Happy
CLG
Perth, Western Australia
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 07:10 Go to previous messageGo to next message
Yep, easy fix, install a cat!
Classique71
Colac, Victoria
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 07:45 Go to previous messageGo to next message
/start sillybuggers
yes - a cat will eat the cricket ..
Or you could ask the channel 9 commentry team to shout 10 different versions of " GOT HIM YES! " at the car , and it will end the cricket ..
Or leave it out in the rain .. that stops cricket too Smile
/end sillybuggers
wiso
Re: ST162 Cricket noise inside dash Thu, 12 February 2004 14:31 Go to previous messageGo to next message
leaves caught in the airboxes behind the dash? the fan hits it and annoys the fuck out of you, maybe, does it happen when you adjust fan speeds?
SCO-77K
Castle Hill, Sydney
Re: ST162 Cricket noise inside dash Fri, 13 February 2004 01:44 Go to previous messageGo to next message
could it be a cricket? Razz
ovaltine
Re: ST162 Cricket noise inside dash Mon, 16 February 2004 03:58 Go to previous message
I found the bl**dy thing! Turned out to be coming from the engine bay, not the dash. It was easy finding it when it was doing it at standstill -- I lowered the idle speed to get the car to vibrate. The cricket-noise was generated by a teflon sheath on a re-built power steering hose. The sheath had a rubber coating which rubbed against the brake tubing. Rubber vs metal + vibration = noise. I removed the sheath (which was not required anyway) and the noise went away! Very Happy
Previous Topic:1jzgte 5 speed -> VN ('91 holden ute)
Next Topic:AE-101 '95 Corolla Tape Deck wiring????
Current Time: Fri Oct 23 02:59:01 UTC 2026
Total time taken to generate the page: 0.0052511692047119 seconds
