Toymods » Tech & Conversions » 4kc refusing to idle smoothly - valves different colours.
mightyrollaman
4kc refusing to idle smoothly - valves different colours. Thu, 12 February 2004 05:50 Go to next message
I have been striving for yonks to get my KE55 Corolla idling smoothly. Power delivery is smooth and plentiful (for a 4K!). After doing everything else within my power (which does not include timing as I don't have a light), I decided to pull the head off to see if it could tell me anything, as I was suspecting valve seat recession (?). Anyway, the exhaust valves are covered in a browny-orange material, whereas the inlet valves are black, like the rest of the combustion chamber. I have a spare head which is known to be A1 and its valves are all the smae black colour as the combustion chamber. The engine only has 170 thousand ks on it and doesn't use oil or blow smoke. Someone suggested timing chain but I wasn't sure as I've never come across a 4k with a worn timing chain before. Any ideas?
Re: 4kc refusing to idle smoothly - valves different colours. Thu, 12 February 2004 06:12 Go to previous messageGo to next message
how unsmoothly does it idle? that is usually due to
manifold or carb air leak.
poor idle mixtures.
poor timing
not enough vac advance.
that kind of thing..
i have seen 4K's run until the timing chain wore through the timing cover! they do wear, but very slowly. if it is a single row, replace with a double row from 3K.
the valve seats are hardened so you can use ULP, and recession is not really a problem.
maybe mixture is too rich? black soot is carbon, and the hotter exhaust valve will burn some of that off.. sounds normal..
so, how badly does it idle? maybe just up idle speed?
mightyrollaman
Re: 4kc refusing to idle smoothly - valves different colours. Thu, 12 February 2004 06:48 Go to previous messageGo to next message
Trust me, I investigated carby, idle, manifolds etc to the nth degree. Haven't done timing yet as I don't have a light. Feels smooth enough from inside but is constantly puffing out the exhaust as if all 4 cylinders are firing poorly. I know about the hardened valve seats but thought all seats wore out eventually.
[Updated on: Thu, 12 February 2004 06:51]
Re: 4kc refusing to idle smoothly - valves different colours. Thu, 12 February 2004 06:55 Go to previous messageGo to next message
timing light
K-mart
$50
$40 on a 20% off day
priceless Very Happy
heh heh, seriously, they are half decent, i'd be looking to timing before i ripped the head off.. and sure the valve seats will recess eventually... my poor little engine does 5-7K all day and hasn't had valve seat probs.
fwiw, i have about 20 deg static timing, with another 12-15deg vac advance... and then it idles smoothly at about 13-1500 Wink
mightyrollaman
Re: 4kc refusing to idle smoothly - valves different colours. Thu, 12 February 2004 07:15 Go to previous message
Thanks Stewart, I may just have to give that a go. It would be great if that is all it is. I'm just a stubborn diy junkie that relishes how far he can get with just his socket set. And what better engine is there to play that game with eh!
Previous Topic:TA22 springs into RA23?
Next Topic:3sgte rebuild parts
Current Time: Tue Oct 20 22:53:44 UTC 2026
Total time taken to generate the page: 0.0065240859985352 seconds
