Toymods » Tech & Conversions » 1g-gte missing
Ribbo
Northern Beaches
1g-gte missing Thu, 12 February 2004 10:37 Go to next message
Ok well ive tried heaps of things and can't work out why the hell its doing it.
Comes on boost fine, revs perfect till it hits 5k rpm and starts what I feel to be missing. Its hard to explain it kinda goes on off on off with very fine jerks and the revs go up slower and power drops off. Im pretty sure its miss firing.
Ok ive recently taken all cooler pipes off and fixed a couple leaks, now idles lower, off a different motor ive user different speak leads, new speak plugs, different distributor cap and different coil. All to no evail.
What could it be?
I had it dyno'd and here are the graphs, as you can see it hits 5k and power goes flat.
http://members.optushome.com.au/gregmatt/dyno/
any ideas? its running pretty rich so I doubt its fueling. But maybe one of the injectors isn't performing well enough? could it still run rich like that?
Thanx heaps
Re: 1g-gte missing Thu, 12 February 2004 10:40 Go to previous messageGo to next message
Check your fuel filter, my old Starion started doing that when the fuel filter was all blocked up (I'd just bought it). Would get to about 5k and start spluttering and the revs would go up slow...just a thought.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1g-gte missing Thu, 12 February 2004 10:43 Go to previous messageGo to next message
Prolly one of these:
Fuel filter, regulator, spark plugs, spark leads, dizzy.
Smile
Ribbo
Northern Beaches
Re: 1g-gte missing Thu, 12 February 2004 10:51 Go to previous messageGo to next message
Ill try a new fuel filter see what that does..
But its running rich.. how could it be lack of fuel?
same thought behind regulator..
plugs ive changed, dizzy cap ive put a new one on, leads ive put different ones on
...Sad
its so annoying
Re: 1g-gte missing Thu, 12 February 2004 12:54 Go to previous messageGo to next message
All turbo cars are mapped rich, mine would do exactly as you describe and use heaps of fuel when it finally came through. Spark plugs are a definite possibility also.
Les
Re: 1g-gte missing Thu, 12 February 2004 13:13 Go to previous messageGo to next message
Ribbo wrote on Thu, 12 February 2004 21:51
...Sad
its so annoying
HOW rich man ?? when i put my fuel helper system in... it ran fcking rich and kept flooding and stalling...
have u changed the fuel pump or similar recently ??? also watch the spark plugs as they will burn out or get heaps ogf carbon deposited on it once it runs rich
hope that helps
TOY77
Re: 1g-gte missing Thu, 12 February 2004 19:47 Go to previous messageGo to next message
have you checked your rotor button, mine was cracked.
also my similar prob to this turned out to be a earth issue. the main earth bolt was a little loose so i got intermittant problems to the coil, igniter,computer... was very hard to find.
Stew
ddeane
PNG
Re: 1g-gte missing Fri, 13 February 2004 19:52 Go to previous messageGo to next message
Hi
May be a long shot but have you checked the engine diagnostics. The symtoms don't seem to sound right but it may be a loose plug to one of the knock sensors. The other option is the coolent tempature sensor may be faulty and the computer is still in cold mode. Your symtoms seem to point more towards this. If you think that this is likely have a look at the gallery - I think that I have got the diagnostics there. Otherwise drop me a line and I will look up the specification on the temp sensor for you.
Craig
Ribbo
Northern Beaches
Re: 1g-gte missing Fri, 13 February 2004 23:31 Go to previous messageGo to next message
thanx
yea im going to check the error codes, though I don't know how hehe
ive posted a post to work that out Smile
Snyper
Re: 1g-gte missing Mon, 16 February 2004 07:26 Go to previous messageGo to next message
I am getting the same problem with my 1ggte, I have got mine worked out to be something electrical,
if the headlights are on, or my thermo fan is running, it misses above 5500rpm, when these things are off it's fine, but my voltage on the battery is 14v so I dunno, I'll work it out soon, only time it annoys me at the moment is when I go down the strip cos the thermo is always on.
Brendon
Ribbo
Northern Beaches
Re: 1g-gte missing Mon, 16 February 2004 11:25 Go to previous messageGo to next message
Let me know what you find.
My thermo is always on, never ran it without it.
Nark
Cabramatta, NSW
Re: 1g-gte missing Mon, 16 February 2004 13:07 Go to previous messageGo to next message
Have you measured the voltage at the ECU?
I've long suspected that my ECU doesn't get enough power...
Re: 1g-gte missing Mon, 16 February 2004 15:25 Go to previous messageGo to next message
Quote:
1g-gte missing
Have you checked under the couch? I'm always losing stuff there.
OK I'm going to bed now.
Ribbo
Northern Beaches
Re: 1g-gte missing Mon, 16 February 2004 19:16 Go to previous messageGo to next message
well nice to see norbie is here to save the day, all my problems are solved Smile
What voltage at the ecu do you get Nark?
Im starting to wonder if it actually is missing or not, it seems to just be running a little rough on boost over 5k, what else other than missing could that be?
Cos I upped the boost a little and it didn't seem to be any worse, which I would of expected.
What does it feel like if the knock sensors retard the timing? does it just lose power?
gold28
Madrid - Spain
Re: 1g-gte missing Mon, 16 February 2004 23:30 Go to previous messageGo to next message
1G-GTE Found
You were close Norbie, it was under the coffee table. Very Happy
http://members.optusnet.com.au/~nez_tony/mypic37.jpg
Sorry, somebody had to say it.
Re: 1g-gte missing Mon, 16 February 2004 23:43 Go to previous messageGo to next message
ROTFL
That's brilliant! Laughing
ra23celica
Re: 1g-gte missing Tue, 17 February 2004 00:00 Go to previous messageGo to next message
I agree - that is brilliant, and now I know what to do with my spare 1G-GTE motor in the garage.
I'm no expert in these engines but it sound to be like you have pulled an error code and the ecu is not switching over to its optimum mapping. Its running on its 'safety settings' second map. Low boost, restricted rev's.
Pull the code from it if you can, and or try pulling the ecu fuse for 30 seconds and resetting the thing.
Let us know how you get on.
Mitch.
YelloRolla
On your mum!
Re: 1g-gte missing Tue, 17 February 2004 08:00 Go to previous messageGo to next message
When you tried defferent coils - were they new ones? and did you clean the spark plugs when you swapped coils?
I had endless amounts of nightmares with my car missing - Finally I bit the bullet and bought brand new coils (after swapping between some second hand ones) and finally after replacing the coils with new ones (oh and new ignitors coz I extra money to throw away Rolling Eyes) I took the car for a spin and it missed again - like nothing had changed.
After cleaning the plugs (AGAIN, and I had replaced them with new ones at least 4 times previous) it ran beautifully. I can only suggest that the plugs were fouled from the missing.
Like yourself, the missing in my engine was above 5K on boost. It is at this point that an ignition system has to work damn hard.
My remedy - new plugs and new coils. I will almost guarantee that the coils will be at the base of the problem.
Ribbo
Northern Beaches
Re: 1g-gte missing Tue, 17 February 2004 11:23 Go to previous messageGo to next message
I don't like the sounds of that Jason Sad
I don't feel like replacing the plugs again as I got the stupid expensive iridium ones that were in the book for the 1g-gte, maybe a very light clean with fine sand paper?
If it was the ignition system wouldn't it brake down more under more boost? I upped it and didn't seem to be any worse.
Its like a very small miss, it seems to get better sometimes, thats why im starting to think maybe its not a miss....
Gotta get the computer error readouts, don't know which pins though to short
YelloRolla
On your mum!
Re: 1g-gte missing Wed, 18 February 2004 00:24 Go to previous messageGo to next message
Another thing to consider Ribbo is whether there as any kind of coolant leak (either from the radiator cap or elsewhere)that may be spraying onto your ignition leads. I know that it is a long shot, but it will cause missing.
Maybe just clean the plugs with some carby cleaner and steel wool (rather than replacing them).
I seen you on Forest way yesterday. Looked like you were trying to Gee up a guy in a BMW Z3.
Re: 1g-gte missing Wed, 18 February 2004 00:46 Go to previous messageGo to next message
looking at your torque and AFR graphs...
the torque drops off remarkably at about 4800rpm.. looks 'not good' (tm)
comparign directly against AFR, everything seems hunky dory until 3500, when you go from a little bit rich to 'buckets and buckets of fuel' (tm) Wink
10.5 is pretty bloody rich, and also helps to explain the misfiring... as the AFR gets richer, it gets harder to ignite. also as boost increases it gets harder to ignite, so you have two things workign against you..
i honestly don't know if your AFR graph is "normal" for a stock ECU, but if i'd paid someone to do it, i'd be looking for a refund Wink .. or maybe it's just 'safely rich'?
Jason, what AFR's would you suggest?
YelloRolla
On your mum!
Re: 1g-gte missing Wed, 18 February 2004 00:54 Go to previous messageGo to next message
I'd suggest AFR's of 12.5 to 12.7 for max power. A weak spark signal will show up as being overly rich. No spark signal will often show as lean! (IE you cant get an AFR from unburnt fuel)
barned01
Re: 1g-gte missing Wed, 18 February 2004 01:56 Go to previous messageGo to next message
i read a report similar to your issue in a hot 4's magazine that they had an engine that started missing once they hit a certain amount of boost, they closed the spark plug gaps slightly and this fixed the issue.
i don't know much about this but i thought it might be useful to you.
just one thing you could try before getting new expensive spark plugs again.
don't close them too much cos it does sap power apparently.
sideshow
Re: 1g-gte missing Wed, 18 February 2004 02:06 Go to previous messageGo to next message
the plugs will fire ok unless u run over 20psi
at std boost u should not be blowing out the spark
10.5 air fuel is rich but its still sort of ok
nissans used to run that rich from factory too
especially up hi and on boost
its just safer to run rich up high
saves blowing up engines
did u check for codes dont fuk round with it till u get the codes out of it if no codes then go looking for other stuff
r u sure its a miss
what boost r u running do u have a boost gauge
if u r overboosting the ecu will try shut the engine down
so make sure u have an accurate boost gauge
if u get over 12psi it might hit boost cut
Ribbo
Northern Beaches
Re: 1g-gte missing Wed, 18 February 2004 12:38 Go to previous messageGo to next message
ok well codes were 24 and 42
42 is speedo, which is fine cos its not hooked up to computer.
24 on the other hand is intake temp sensor..
I reset the computer and went for another run and it now reads no errors...
problem is still there though
no problem making boost as I wound it up and hit 15psi once, which i wound back down cos i didn't mean to send it so high hehe
indian
south east - melbourne
Re: 1g-gte missing Mon, 22 March 2004 04:03 Go to previous message
mate just chek that ur ecu connections are fited in properly this can cause certain cars to run ok till certain rpm and miss like mad when they get to certain rpm and run like its detonating and misfiring sopull the ecu connections out put some wd 40 in there and put it back ad see if that helps happened to my nissan exa b4 always and thats was the only fix for it
Previous Topic:7M-GTE Check Engine Light
Next Topic:Corolla - 2-Pot Calipers ?!?
Current Time: Fri Nov 20 05:59:33 UTC 2026
Total time taken to generate the page: 0.0068771839141846 seconds
