Toymods » Tech & Conversions » Fuel pump return line?
M.W.P.
Rocky Mountains, Canada
Fuel pump return line? Thu, 12 February 2004 14:22 Go to next message
Hi all,
The 21R (carb'ed) im putting in my corona has a mechanical pump (off the cam shaft) that has a tank return line.
The problem is the corona doesnt have a line running back to the fuel tank.
Can i just block it off, or will this damage the fuel pump?
Any other ways around this?
Thanks.
Re: Fuel pump return line? Fri, 13 February 2004 02:44 Go to previous messageGo to next message
You need to install a return line if you're using that pump. Otherwise you can swap the pump for one that doesn't need a return line. I think facet pumps fall into this category?
Skip
Re: Fuel pump return line? Fri, 13 February 2004 04:57 Go to previous messageGo to next message
You can always go electric.
M.W.P.
Re: Fuel pump return line? Fri, 13 February 2004 14:50 Go to previous messageGo to next message
Hmmm.
Im wondering if i can use the tank -> charcoal canistor emissions line for the return.
As far as i can tell, its just a pipe that leads back to the top of the tank.
Any comments on this?
T APLUS 22
Re: Fuel pump return line? Fri, 13 February 2004 20:14 Go to previous message
Well I can confirm that the fuel return line is simply one that runs to the top of the tank to return unused fuel.
I don't know the corona so I can't help any more.
Previous Topic:ke36 wagon 4age conversion
Next Topic:1ggte plug leads, TOPGUN part number
Current Time: Sun Oct 25 02:36:33 UTC 2026
Total time taken to generate the page: 0.028275012969971 seconds
