Toymods » Tech & Conversions » Electrical Problem
Corolla Boy
icon4.gif  Electrical Problem Thu, 08 August 2002 12:19 Go to next message
Latly I have relised that when I have my indicator on the whole dash board light, radio light, interior light start to dim on and off (to the rythem of the indicator). What I mean is that when the indicator flashes on the lights dim, when it turns off the lights go bright again (This also happens even if the engine is at high revs). It's alomost like theres not enough electricity to go around, what could this be from?? (I measured the battery while the cars on it's 12.5 volts). Eye Spin
Celica_RA40
Re: Electrical Problem Thu, 08 August 2002 12:23 Go to previous messageGo to next message
If you are getting 12.5 volts while the car is running it suggests that there is a charging system problem. normally i think about 13.6 volts is put out while the car is running.
Re: Electrical Problem Thu, 08 August 2002 12:44 Go to previous messageGo to next message
First up, check your earths!
pedroenglish
icon14.gif  Re: Electrical Problem Fri, 09 August 2002 01:22 Go to previous messageGo to next message
You have resistance between the battery positive+12v and the takeoff point under the dash where the flasher unit gets power.
This is common with the other stuff being affected.
This is usually the ACC line, measure volts here compared with direct across battery, when indicator going. This voltage drop could be due to a bad connection, dirty fuses, or even bad ignition switch. The meter will show where power is being lost.
Pedro
ZZT231
melbourne.vic.au
Re: Electrical Problem Fri, 09 August 2002 02:59 Go to previous messageGo to next message
I had a similar problem with my MA61 But the dash would completely black out after a long drive with the lights on. I added another earth strap from the negative side of the battery to the body of the car my car behaves normally again... Hope that helps you...
Cheers.
SUPRAGTE
North Sydney
Re: Electrical Problem Sun, 11 August 2002 08:47 Go to previous message
If you are getting only 12.5 volts across the battery with the car running you definitely have a charging system problem with the alternator/regulator.
You should see 14.1 volts across the battery.
Fix that first, then see if the problem still exists, bet it doesn't Smile
Previous Topic:Boost Guage Problem
Next Topic:nitrous
Current Time: Thu Nov 19 18:48:28 UTC 2026
Total time taken to generate the page: 0.0057990550994873 seconds
