Toymods » Tech & Conversions » RT142 dash into ST141
Groana
Wenty
RT142 dash into ST141 Thu, 08 August 2002 13:20 Go to next message
i own a st141 corona and would like a tacho dash my mate has the rt142 with the 2.4l 22-re motor and on this motor the coil is easily visible on my motor however i cannot seem to find it so i am wondering how to go about wiring the tacho into the system.
[Updated on: Thu, 08 August 2002 13:22]
trent
Re: RT142 dash into ST141 Wed, 14 August 2002 15:02 Go to previous messageGo to next message
i did the same conversion on my st141 although i used the dash from the cs-x.
i dont have the car anymore and all my stuff is packed away as i just moved. from memory, there is a plug with a green connector on it that goes into the distributor. that is the wire you connect the tacho to. i just ran the wire along the top of the engine and into the same grommet as the speedo cable. if you have a gregory's manual there is a picture in one of the first few chapters that shows which wire to connect a tacho to.
the plugs are different so when you get the dash cut the plugs of the loom as well. the wires then need to be taken out of the old plugs (using a tiny screwdriver to lever them out) and put into the new plugs.
the non-tacho dash has 2 plugs and the tacho dash has 3 plugs.
you will also need an oil pressure sensor for the oil pressure gauge to work. i used the cs-x sensor so it screws straight in. i am not sure if the sensor from the 22r-e will fit.
i worked out what every wire did in both dashes from wiring diagrams and tracing the back of the dashes. you will need to splice an extra power wire and an extra earth wire (or two)as there are extra connections on the tacho dash.
the only problem i had was never being able to get the digital clock to work. i didn't really care though. a bit more effort would have seen it working.
if took about 1 hour to do that actual installation but many more working out where each wire would go. it was my first foray into auto electrics.
if you want the explaination of what all the wires do on both dashes i can dig it up for you.
email me at trentomatic@hotmail.comas i don't read these forums much.
also with regard to diffs. the st141 cs-x also came with rear disc brakes. i was quoted $150 for a complete siff around 3 years ago.
Mr_Fusion
Re: RT142 dash into ST141 Fri, 16 August 2002 12:16 Go to previous messageGo to next message
trent - quick question for you
where abouts was the quote for the rear diff setup?
im really interested and $150 sounds bloody good
trent
Re: RT142 dash into ST141 Sun, 25 August 2002 13:16 Go to previous message
i think it is called "matraville wreckers".
it is on beauchamp road, matraville.
when you find a diff just ring up on different days until you get a price you want. i paid $80 for the first dash i bought. then $30 for the second one. both from the same guy.
Previous Topic:How do you stop engine run on!
Next Topic:intercoolers
Current Time: Thu Oct 15 11:03:57 UTC 2026
Total time taken to generate the page: 0.0068128108978271 seconds
