Toymods » Tech & Conversions » 2TG/3T hybred what pistons
roadrunner
Hornsby, Sydney
2TG/3T hybred what pistons Fri, 13 February 2004 11:39 Go to next message
i have a 2t3t hybred using a 260 2TG head. because of excess blow by i have removed the head to start rebuilding it but noticed it has 3T pistons in it which look a little flatter (lower comp) than the 2TG ones that i remember.
Can i use 2TG pistons safely?
Will it up my compression?
or am i just seeing things that may not be true?
thank you Roadrunner.
Jonny2TG
Tasmania
Re: 2TG/3T hybred what pistons Fri, 13 February 2004 12:16 Go to previous messageGo to next message
Search this forum a bit more, it has been covered many times.
3T pistons must be used together with a 3T crank.
2T and 2T-G pistons must be used with a 2T crank.
Generaly, when going from standard 2TG pistons to generic 3T pistons and crank, the compression will be increased a bit, from about 8.8:1 standard, to about 10 or 10.5:1.
Using the 3T setup, the cheapest is to use regular 3T-C pistons with the exhuast releif cut a bit deeper. You can get these in 86mm new.
2T-G pistons had different compression depending on the year and other things. Older ones were about 9.8:1, latter ones where 8.8:1, some where 8.4:1, some 8.3:1 I think. A standard 3T will have a compression of about 9 to one. Using this bottom end with a 2T-G head increases the compression because the 2TG head chamber is slightly smaller, 62 vs 68cc I think.
Evil_Foetus
Ballarat, Victoria
Re: 2TG/3T hybred what pistons Fri, 13 February 2004 13:25 Go to previous messageGo to next message
yep thats right
talk to the untouchable hes doing the 2t/3t at the moment Very Happy
roadrunner
Hornsby, Sydney
Re: 2TG/3T hybred what pistons Sat, 14 February 2004 03:25 Go to previous message
thank you. thats very helpful
Previous Topic:Urgent help needed: Throttle linkages for 18R-GU
Next Topic:ae86 headlights
Current Time: Mon Oct 19 17:52:50 UTC 2026
Total time taken to generate the page: 0.060570955276489 seconds
