Classifieds » Cars For Sale & Wanted » FS: Turbo Corona FF&R Vol.8 No.5
turbocorona
Newcastle NSW
FS: Turbo Corona FF&R Vol.8 No.5 Thu, 08 August 2002 13:25 Go to next message
1975 RT104 Toyota Corona as featured in Fast Fours & Rotaries magazine Volume 8 No.5.
2 Litre 18-RC engine...
Hybrid Hi-flowed Garrett T3/4 Turbocharger custom designed and assembled by Dynamic Turbocharger systems, oversized compresser and turbine wheels cropped to reduce lag by 60%.
Ported and Polished housings.
Custom one-piece inlet/exhaust manifold channeled for external wastegate.
32mm external wastegate.
Balanced crankshaft.
40 thou over-sized pistons.
Shot-peened con-rods.
Ported/polished cylinder head.
Double valve springs.
Draw-through set-up using 1.75mm CD Stromberg Carburettor.
Pressure switch activated water/methanol injection.
Front-mount fuel cooler.
Carter electric fuel pump.
Twin thermos
Boot mounted battery
2 3/4 inch exhaust system
Lowered suspension
Celica 5-speed gearbox
Hornet Bonnet scoop
Formula Blue in colour
Fully re-trimmed Recaro-style interior
Momo wheel & knob
boost gauge
14 inch Bathurst Globe rims
Car has ran a personal best 1/4 mile time of 12 seconds
Engine/turbocharger require re-assembly and installation.
regretfull sale due to loss of licence
$2500.00 ono
email: edwarw@kooee.com.au
Billy_bong_y2k
Toowoomba
icon6.gif  Re: FS: Turbo Corona :- info Fri, 09 August 2002 07:45 Go to previous messageGo to next message
Hey how come the engine and turbo need re- installing.
Is there something wrong with it.
So Did you do the 18r conversion or it or was it all ready done. WAs there any big troubles in converting it into the corona.
And how did you find the celica gearbox on bolting up.
I used to have a 80 model corona sedan the xt130. want another so i can do it up.
What sort of bonnet scoupe do you have on it or. Just from the picture can see something there or is taht somethign in the back ground.
turbocorona
Newcastle NSW
Re: FS: Turbo Corona FF&R Vol.8 No.5 Fri, 09 August 2002 11:04 Go to previous messageGo to next message
turbocorona wrote on Thu, 08 August 2002 11:25 PM
Twin thermos
Lowered suspension
Hornet Bonnet scoop
Momo wheel & knob
boost gauge
$2500.00 ono
website with pics www.turbocorona.tk
http://www.turbocorona.tk
M.W.P.
Rocky Mountains, Canada
Re: FS: Turbo Corona :- info Fri, 09 August 2002 11:45 Go to previous messageGo to next message
Billy_bong_y2k wrote on Fri, 09 August 2002 5:15 PM
The RT Corona's all came with the R series engines... the RT104 came with the 18R, 18RC, or rarely 18RG.
[Updated on: Fri, 09 August 2002 11:46]
turbocorona
Newcastle NSW
Re: FS: Turbo Corona :- info Fri, 09 August 2002 12:13 Go to previous messageGo to next message
Thankyou for that, yes the RT104 did come as standard with the 18RC. The 18RG was present in the GT models of the Celica etc.
CHeck out my site... www.turbocorona.tkhttp://turbocorona.tk
M.W.P. wrote on Fri, 09 August 2002 9:45 PM
Billy_bong_y2k
Toowoomba
Re: yeah sorry Sat, 10 August 2002 02:18 Go to previous messageGo to next message
yeah sorry i got confused i was thinking of the celica engines
well 18rg i think i was refering to. well i nilly bought a ra40 celica and thats what it had in it. ANd dont relly know much about the other make of the coronas only the 80 which i have to learn real quick has always have little probles here and there all the time, like window thiny kepp poping th glass out and sliding down into the inside of teh door. Etc.
Well my corona had the xt130 which was the holden blue block cut down. Starfire engine. Fuck it ran well pitty about the rest of the just falling apart. WEAR AND TEAR from thrashing it all the time.
HEy i have hear of people putting a 2.6ltr izuzu engine in the old geminis and turbo'ing them and getting reasonable power how do you think it would go like in a corona. But would it be possible in doing in reguards to power to weigh ratio the DOT.
dept of transport) say any can can have. LIke would it be street legal if i did it. Engineers certificate etc.
turbocorona
Newcastle NSW
Re: yeah sorry Sat, 10 August 2002 06:21 Go to previous messageGo to next message
Mate the 18-rg and 18-RG are basically the same motor except for the cylinder heads naturally. In that era it was Toyota's identification codes, similar to the 2t engine ex TA22 celica. The 2t was the single cam and the 2t-g was the twin cam, either with injection or twin solex's, but i wont delve into that.
The corona was best suited with the 18r, principly due to the fact that it is the original motor so there is no need to modify engine mounts bellhousing adaptors etc etc.
As for transplanting other engines into it, i usually like to stick to a general rule. I always insert an engine that is from the same manufacturer as the original.
As for the allowable size....going off my engineers certificate..the calculation says weight of vehicle X 2.5. i.e 1086kg X 2.5= 2.7Litres in capacity. So yes you could legally fit an Isuzu engine into it, but the question remains, why would you want to??? The 18-R developed enough horsepower to propel the vehicle to a 12second 1/4 mile. With more engine mods, such as CC'd combustion chambers to reduce compression ratio and therefore more boost, im sure the thing would get a hell of alot closer to ten's without the cost of installing an isuzu donk.
Failing that install a 1J or 1G supercharged or turbocharged etc etc. I'd stick with the toyota running gear and stay clear of the isuzu stuff, but thats just my opinion.
Cheers Wayneohttp://turbocorona.tk
Billy_bong_y2k
Toowoomba
Re: FS: Turbo Corona :- info Sun, 11 August 2002 00:46 Go to previous messageGo to next message
OK thanks for that i dont really know much about the corona's as much as you seem to. REally that quick or qive or take from teh 18-r. Thats not bad. How mcuh had it cost you to turbo yours.
how much power does your car produce. How mcuh boost do you run it at.
how do you think the 1g-gte would go in a corona.
So is that how they work out on what cc you are limited to.
turbocorona
Newcastle NSW
Re: FS: Turbo Corona :- info Sun, 11 August 2002 05:59 Go to previous message
The car was originally built by the previous owner. I ran 16 PSI boost and i never actually ran it on the dyno. A friend had a TA22 Celica and installed the 1G it ran very well indeed. as for the ease of installation im unsure.
Previous Topic:76 RA23
Next Topic:F/S Starlet GT turbo 1993
Current Time: Sun Oct 25 16:09:51 UTC 2026
Total time taken to generate the page: 0.0044898986816406 seconds
