Toymods » Tech & Conversions » hydraulic clutch problem
Puffy
hydraulic clutch problem Sat, 14 February 2004 08:36 Go to next message
Hi everyone,
After doing a motor swap in the GT4 I needed to replace the clutch fluid I had drained. The pedal is to the floor at the moment so I poured new fluid into the container and thought it was now just a matter of pumping the clutch pedal with the bleed valve slightly open to get the fluid to circulate. I am manually pulling and pushing the pedal with no resistance at all. The fluid is not draining from the container down into the lines. Have I missed something here or anyone know what the problem could be.
Thanks,
Anhar Khamas
GT4 Group A
Re: hydraulic clutch problem Sat, 14 February 2004 11:02 Go to previous messageGo to next message
open bleed valve, push pedal down
close bleed valve, pull pedal up.
repeat
Re: hydraulic clutch problem Sat, 14 February 2004 15:41 Go to previous messageGo to next message
oldcorollas wrote on Sat, 14 February 2004 19:02
repeat
Ummmm, no
Pump pedal 10 or so times with valve closed
Hold foot on, release valve until foot reaches floor (its a 2 person job)
Close valve
Repeat until no air is in system
Puffy
Re: hydraulic clutch problem Sun, 15 February 2004 01:01 Go to previous messageGo to next message
Thanks for the advise guys.
Anhar Khamas
GT4 Group A
Re: hydraulic clutch problem Sun, 15 February 2004 03:21 Go to previous messageGo to next message
CrUZsida wrote on Sun, 15 February 2004 02:41
Ummmm, no
Close valve
Laughing , i must have been doing it wrong all these years... no point pumping the pedal if fluid is not going into the lines... once it starts in there, you can pump away, but pressurising the line by pumping lots can introduce bubbles... Rolling Eyes
one of the best methods is actually to use vacuum to draw fluid thru the entire line before pumping...
anyhoo, whatever floats your boat Very Happy
Soarer
Wollongong
Re: hydraulic clutch problem Sun, 15 February 2004 05:13 Go to previous messageGo to next message
I bled the clutch yesterday and used gravity to assist, since pumping the clutch wasn't helping. Basically open the valve, push the clutch in and leave it there for a few minutes. The fluid will slowly come out, and air pockets should remove themselves. This was actually more effective than pumping the pedal.
Puffy
Re: hydraulic clutch problem Sun, 15 February 2004 09:30 Go to previous messageGo to next message
Found what the problem is. I have nicked the line whilst removing the engine therefore losing pressure and fluid Rolling Eyes that would explain my problem.
Anhar Khamas
GT4 Group A
Re: hydraulic clutch problem Sun, 15 February 2004 22:42 Go to previous messageGo to next message
Puffy wrote on Sun, 15 February 2004 20:30
Anhar Khamas
GT4 Group A
...that would also explain the bloody mess everywhere!
Some people bleed brakes by just filling the fluid, opening the bleeders and leaving it sit for a few hours. Others use a pressure bleeder. Whatever excites you, really!
Skip
Re: hydraulic clutch problem Sun, 15 February 2004 23:45 Go to previous messageGo to next message
CrUZsida has the right method. You may find that your clutch feels fully pumped up. Then the next day you have lost it again. Just keep on trying to get the air out.
ae86drift
sydney.au
Re: hydraulic clutch problem Thu, 19 February 2004 05:47 Go to previous message
also thanks
Previous Topic:Lost electrical power
Next Topic:if anyone needs ecu codes
Current Time: Sun Oct 25 02:05:52 UTC 2026
Total time taken to generate the page: 0.072325944900513 seconds
