Toymods » Tech & Conversions » need help quickly on 18rgeu rebuild
people100
Rocklea qld
need help quickly on 18rgeu rebuild Sat, 14 February 2004 21:40 Go to next message
Ive got a block for a 18rgu and i have put the 18rgeu 88270 head on it. Ive set the cams to the right position with the little notches straight up and the lopes are pointing opposite directions to each other. My question is number 1 piston should be just a tad before top dead centre shouldnt it. If its on top dead centre the valve seams to hit the piston. is that right. Where should the marks on the middle cog on the timing actually be situated. How do i tell if i have it set up right as i dont have a book.
Mr DOHC
Re: need help quickly on 18rgeu rebuild Sat, 14 February 2004 22:05 Go to previous messageGo to next message
the keys on the balance and the crank should be straight up, put on the crank and oil pump drive gear with the chain already on there,
then slide on the cam drive gear, tighten to 6.0-70.kg-m {44-50.6 ft-lb} then put on the front cover/head ect
people100
Rocklea qld
Re: need help quickly on 18rgeu rebuild Sat, 14 February 2004 22:08 Go to previous messageGo to next message
Thats when i ran into trouble. I had the keyway on the crank straight up and i cant turn the cams as the valves are hitting. what could be wrong.
RA28midge
Adelaide and Queenstown T...
Re: need help quickly on 18rgeu rebuild Sun, 15 February 2004 22:32 Go to previous messageGo to next message
Are you sure you have the right cams on each side? the lobes on No.1 should be sticking out away from each other at TDC.
people100
Rocklea qld
Re: need help quickly on 18rgeu rebuild Mon, 16 February 2004 09:45 Go to previous message
thansk for the help but ive solved the problem. was my silly fault.
Previous Topic:New Frankinstein turbo....
Next Topic:100kw 4age with TVIS manifold??
Current Time: Sun Nov 1 07:28:24 UTC 2026
Total time taken to generate the page: 0.004734992980957 seconds
