Toymods » Tech & Conversions » AE86 Surgy Setup
dorikin ichiban
Auckland, New Zealand
AE86 Surgy Setup Fri, 09 August 2002 00:23 Go to next message
Does anyone have pics of their surge setups in their 86.
I was thinking about doing something like this...
Fuel Tank -> VL Pump -> Surgy -> VL Pump
Hopefully I can mount all of this under the car next the fuel tank.
I'm keen to see how every else has theirs setup.
RobertoX
Re: AE86 Surgy Setup Fri, 09 August 2002 00:54 Go to previous messageGo to next message
Vl pump before the surge tank? Wouldn't it be better to use a generic type efi pump from something else... Not sure about this but is the Vl a riser type pump? Don't you need sometning else to feed it (through the surgie)?
floody
Re: AE86 Surgy Setup Fri, 09 August 2002 05:45 Go to previous messageGo to next message
Just an idea....If you are using a VL fuel pump, why not go and have a look at the vl and see how its all sequenced tank-pump-surge etc, then just replicate that setup with your bits? makes sense to me!!!!
cheers,
Floody
Grega
melbourne.victoria.austra...
Re: AE86 Surgy Setup Fri, 09 August 2002 08:24 Go to previous messageGo to next message
dudes, there is a low pressure lift pump in the tank in a VL (according to the manual) - then the pump you will have dorikan is the external type which then feeds the injectors.
a vl pump as a lift pump would be overkill, if cheap tho, could be used to fill the surge tank.
rob_RA40
c'town, NSW
Re: AE86 Surgy Setup Fri, 09 August 2002 09:08 Go to previous messageGo to next message
high pressure pumps that send fuel to the engine from the surge tank do not like to suck, so using one as a lift pump to send fuel to the surge tank is a bad idea
it should go
fuel tank -> low pressure lift pump -> surge tank -> high pressure pump -> engine -> surge tank -> fuel tank
dorikin ichiban
Re: AE86 Surgy Setup Fri, 09 August 2002 19:15 Go to previous messageGo to next message
THanks for that .
Are there any lower press high lift pumps you can recommend?
Hopefully all this will fit under the car by the fuel tank. I'm hoping I don't need to mount it in the boot with the battery. That sounds too dangerous
Karl_skewes
New Zealand
Re: AE86 Surgy Setup Sat, 10 August 2002 10:25 Go to previous messageGo to next message
John, dun be stupid. Look at Matts car, runs on Empty light, no surge noticeable. Just get the 7MGTE internal pump to fit in your AE86 fuel tank which you must fit one day.
And.... lemme know when you wanna wire up your trailer connector and car. Might as well do as much as we can, before paying anyone Razz.
Re: AE86 Surgy Setup Sat, 10 August 2002 11:50 Go to previous message
Well I guess if you want a big arse lift pump, you could always go grab a holley blue or similiar. If you've only got something small to feed, grab one of the 70s mazda ones.
Previous Topic:brake master cylinder enlarging
Next Topic:Thermo Switch
Current Time: Thu Nov 19 19:22:14 UTC 2026
Total time taken to generate the page: 0.0046210289001465 seconds
