Toymods » Tech & Conversions » Wot gear box??????
Shaun
Nelson NZ
Wot gear box?????? Sun, 15 February 2004 02:47 Go to next message
I am currently fitting a 18rgeu into a rn30 toyota hilux which i think had a w50 column change box i dumped that and wondering wot other gearboxs have ppl used and wot gearbox was orginally mated to a 18rgeu. Also to ne1 with a slightly tricked up 18rgeu wot kinda speeds can these engines get up to with mods like cams,port n polish full rebuild etc.
Re: Wot gear box?????? Sun, 15 February 2004 02:48 Go to previous messageGo to next message
18R-GEU's originally came with a P51 or W50 gearbox. You can also use a W55/57/58, but I don't know if they come in column-shift varieties.
An 18R-G with appropriate cams, head work and valve springs will safely rev to 8000rpm.
Shaun
Nelson NZ
Re: Wot gear box?????? Sun, 15 February 2004 03:00 Go to previous messageGo to next message
Thanks so just have to find an approprite w50 then i wont have to change nething. Wot the top kph of a 18rg with that work done to it.
Re: Wot gear box?????? Sun, 15 February 2004 03:11 Go to previous messageGo to next message
Top speed depends on a lot of factors, you can't just say an 18R-G is capable of X km/h. FWIW I've seen 200 with my stock 18R-GEU in an RA23, although it probably would have gone further.
Re: Wot gear box?????? Sun, 15 February 2004 03:25 Go to previous message
The L50 you dumped is otherwise identical to the W50 you are looking for apart from the 1st gear ratio and the external shift levers.
W50 is the cheapest and easiest solution. Just get one from behind any 18R in an RA23->40 Celica and you'll be right.
The G52 is externally identical to a W5x box and has external levers for a column shift. You'd need the bellhousing from a 21R to make it work behind an 18R.
Previous Topic:4AFE engine query
Next Topic:my ma61 just dies?
Current Time: Sat Oct 10 15:28:09 UTC 2026
Total time taken to generate the page: 0.0056650638580322 seconds
