Toymods » Tech & Conversions » DIY Panhard Rod alignment?
T APLUS 22
DIY Panhard Rod alignment? Sun, 15 February 2004 04:57 Go to next message
Got a whiteline Panhard rod to put on my TA22. How can I get the best alignment for the rear axel? Should I roll or dive the car forward then jack it up with jack under diff, then get the bar to go on as easy as it can. ie, extend to length where it slides on smoothly?
Should there be any weight in the car when the rod's length is determined?
If it is considered that you can't do it without proper measuring tools then where is it recommended to get it done professionally?
Thankyou.
Re: DIY Panhard Rod alignment? Sun, 15 February 2004 05:15 Go to previous messageGo to next message
i think the car should be at the ride height when driving, as this is when you want the axle to be centrally aligned... maybe with 1/2 to full tank of fuel?
ideally the panhard rod will be near horizontal at this ride height to minimise lateral deflection during bump and rebound.
umm, maybe put the front on ramps, and the back with stands under the axle (so suspension is compressed and car is level)
you'll be wanting to check the the axle is laterally located at the correct position (maybe with reference to chassis rails?).
please feel free to coreect me if i am wrong Wink just wanted to get the ball rolling..
Grega
melbourne.victoria.austra...
Re: DIY Panhard Rod alignment? Sun, 15 February 2004 09:19 Go to previous messageGo to next message
have it flat on a 4 post hoist. measure the rim clearance to the outside of the guard, and, should be all good.
i'd have it with at least 1/2 tank of fuel.
Re: DIY Panhard Rod alignment? Sun, 15 February 2004 22:45 Go to previous message
Grega wrote on Sun, 15 February 2004 20:19
Even better, with your own fat arse also in the drivers seat, if you like to be pedantic!
Previous Topic:AE-101 '95 Corolla Tape Deck wiring????
Next Topic:AE86 suspen. WHITELINE
Current Time: Mon Oct 19 15:49:50 UTC 2026
Total time taken to generate the page: 0.0052261352539062 seconds
