Toymods » Tech & Conversions » bare matel resprays and panel work.
people100
Rocklea qld
bare matel resprays and panel work. Sun, 15 February 2004 07:11 Go to next message
I have some questions about it all. firstly on bare metal respray is it just paint or is undercoat used first. Secondly where panel work has been done is it undercoated around that area and thirdly how long can the car be bare metal before it starts rusting or can i just bare metal it a panel at a time and undercoat it so it doesnt rust. Only reason im asking this is i have found a little more rust then i would like in ta23 so it will have to go back to bare so i can remove it all.
Re: bare matel resprays and panel work. Sun, 15 February 2004 08:26 Go to previous messageGo to next message
I would be bare-metalling it and doing it a panel at a time. In theory you can leave it a while, moreso in favourable conditions, but any surface rust that forms that isn't treated correctly could turn up to spoil all your hard work.
celicaboy_2000
Lismore, NSW
Re: bare matel resprays and panel work. Sun, 15 February 2004 08:34 Go to previous messageGo to next message
Hey, On a bear metal respray they would usually etch prime it 1st then prime and then paint. After a repair they put primer over it. Also Dont think that the car is safe being primed and left for to long as primer is porous ??? Not 100% sure about that tho ???. Rust basically starts forming on the metal as soon as its bared.
Thankyou
Matthew
people100
Rocklea qld
Re: bare matel resprays and panel work. Sun, 15 February 2004 09:26 Go to previous messageGo to next message
so should i be doing it a panel at a time and then undercoating it or straight up painting it.
Re: bare matel resprays and panel work. Sun, 15 February 2004 10:02 Go to previous messageGo to next message
the former - clean each panel/section to metal, add filler/metal where needed, rust protect then apply etch primer
apply primer-filler (and sand/re-apply where needed) then paint the whole once you've done all of the above to all of the car.
you should store etched-primed material in a dry place until painting starts.
etch-primer takes longer (if left unpainted/primer-fillered) to start rusting than plain primer on top of bare metal - but will eventually start rusting
[Updated on: Sun, 15 February 2004 10:03]
twincam_ke20
Castlemaine Vic
Re: bare matel resprays and panel work. Sun, 15 February 2004 10:10 Go to previous message
when you do the finish coat, do all the back edges etc of where you cant get to, door jams too, then put it all back together, and spray it at once, other wise to a good painter you will notice that each panel will be different shades/strokes to each other.
Previous Topic:cooling/overheating query
Next Topic:Camry Suspension Question.
Current Time: Sun Oct 18 21:05:05 UTC 2026
Total time taken to generate the page: 0.0044410228729248 seconds
