Toymods » Tech & Conversions » MA61 Digi Dash problem...
sa65
Surrey Hills, Melbourne
MA61 Digi Dash problem... Sun, 15 February 2004 13:45 Go to next message
Honestly officer, I was doing 0kph, see, even the speedo says I was only going 0kph...How could I possibly be speeding?
The digital dash on my supra seems to have given up somewhere...It works but it only reads 0 regardless of the speed of the car. Rest of the dash works fine AFAIK just the speedo...
Any ideas what it could be? Any possible quick fixes or am I gonna have to pull the whole dash out and get a crash course in automotive electronics on the fly?
Any suggestions appreciated...
Ben
CrAiGzEE
south of the big smoke
Re: MA61 Digi Dash problem... Sun, 15 February 2004 22:06 Go to previous messageGo to next message
check ya speedo cable as far as i know these dashs are mechanical
BlackSupra
Re: MA61 Digi Dash problem... Sun, 15 February 2004 22:07 Go to previous messageGo to next message
A few possibilities:
Speedo cable has come lose at the back of the dash
Speed sensor has died
Speedo gears have died
bbaacchhyy
Re: MA61 Digi Dash problem... Sun, 15 February 2004 22:16 Go to previous messageGo to next message
Try here
http://www.cygnusx1.net/supra/library/TSRM_MKII/be /BE_027.html
Look at the fault finding section for the Electronic guages.
I have something similar in mine, but it is intermittent, but with another dash installed it is fine, so it may be the speed sensor which I beleive is in the dash, but haven't found it yet.
One of the drivers to get the analogue dash installed !!!!
Michael B
BlackSupra
Re: MA61 Digi Dash problem... Sun, 15 February 2004 22:21 Go to previous messageGo to next message
The digi dash is all class Very Happy
Its all about reving well into the redline of ye old 5me Cool
Re: MA61 Digi Dash problem... Sun, 15 February 2004 23:09 Go to previous messageGo to next message
Almost certainly a loose or broken speedo cable. I had this happen to me a couple of times.
soaringmik
Re: MA61 Digi Dash problem... Mon, 16 February 2004 02:41 Go to previous messageGo to next message
I have the same problem in my GZ20 soarer, are these dash's similar?
Re: MA61 Digi Dash problem... Mon, 16 February 2004 03:48 Go to previous messageGo to next message
there's an "L" bend in the speedo cable - and this is almost always where the ma61/ra6x/sa6x cable breaks.
You'll also be happy to know these are hard to come by, and expensive as hell from toyota Razz
bbaacchhyy
Re: MA61 Digi Dash problem... Mon, 16 February 2004 04:31 Go to previous messageGo to next message
Hmmm, interesting.
I had (actually have) the problem of an intermittent '0' reading in my digi dash.
As part of the fault finding, I installed another dash and the speedo worked without any problem, so I am assuming that the speed sensor in my original dash is a bit corrupt.
But having begun the conversion from Auto to manual, I disconnected the so called 'speedo elbow' and will have a good look to make sure that this is connected properly and try running the original dash again just to eliminate the above discussed possibilities
Michael B
Re: MA61 Digi Dash problem... Mon, 16 February 2004 15:19 Go to previous messageGo to next message
Hmmm, neither of my Supra's had this L-bend you speak of...
bbaacchhyy
Re: MA61 Digi Dash problem... Mon, 16 February 2004 21:11 Go to previous messageGo to next message
Maybe it is just an auto part ?
My car was an auto (it is now sitting on the garage floor along with a shit load of oil Mad - I hate farking auto trans)
Re: MA61 Digi Dash problem... Mon, 16 February 2004 23:49 Go to previous messageGo to next message
Well both my Supras were originally auto, and no L-bend!
bbaacchhyy
Re: MA61 Digi Dash problem... Tue, 17 February 2004 00:31 Go to previous messageGo to next message
Hmmmm, the mystery deepens.
Maybe a year dependant ?
Mine is a 11/83 bodyshell with a 1/84 Aus compliance plate.
Maybe it is just the way of the world !!!
Re: MA61 Digi Dash problem... Tue, 17 February 2004 04:59 Go to previous messageGo to next message
Both mine were mid 84 build from memory, so that may be an explanation. Smile
Re: MA61 Digi Dash problem... Tue, 17 February 2004 07:02 Go to previous messageGo to next message
My 86 Cressida has the bent one.
But the 82(ish) parts car me and frank had, had the cast alloy elbow.
ie, it wasnt a bent pipe like my Cressidas, but a sort of 2 piece thingamajig
The plot gets deeper
Re: MA61 Digi Dash problem... Tue, 17 February 2004 07:03 Go to previous messageGo to next message
That said, my money is on a dodgy speedo cable as listed above
sa65
Re: MA61 Digi Dash problem... Sun, 22 February 2004 14:48 Go to previous message
Hi all,
Thanks for all the suggestions...I pulled the interior apart a couple of days ago and it was the speedo cable.
I jacked the car up on stands to see if the cable turned with the wheels turning while the dash was disconnected...Sure enough, it wasn't turning so i figured the problem was somewhere further along the cable...
Trace the cable back to the box, pull out the speedo gear to find some of the plastic teeth have worn away...problem diagnosed!
Funnily enough, I had a corona box lying around and substituted the said gear. They had the same amount of teeth and were visually the same so I put it in and it seems to work ok. End of problem, unless I get a speeding fine telling me otherwise Rolling Eyes
Thanks a lot people, I've said it plenty of times before but these forums are full of useful information and previous experience. Everyone seems nice enough too so putting forward problems is no daunting matter...
Ben
Previous Topic:MR2 Wiring Diagram
Next Topic:3sge
Current Time: Fri Nov 20 16:54:06 UTC 2026
Total time taken to generate the page: 0.0060958862304688 seconds
