Classifieds » Miscellaneous » CT26 Turbo and CT20
1UZ FTE
icon2.gif  CT26 Turbo and CT20 Fri, 09 August 2002 09:25 Go to next message
Have a ct26 Turbo off the 7mgte and single entry needs bearing and seals
Also have a ct20 highflowed with ct26 comp wheel/cover and machined exhaust housing can supply with standard comp wheel and cover + a standard exhaust housing and this one as well needs some bearings and seals, well it's close to needing them alittle bit of play
just make me an offer on either one as they are taking up space in the shed so someone may as well put them to good use
Rex_Kelway
Re: CT26 Turbo and CT20 Wed, 14 August 2002 05:58 Go to previous messageGo to next message
I dont suppose you have a rough idea as to what it would cost to put the CT26 back into working order?
Im looking for a suitable turbo for the 4AGTE, but really dont want to lay out much more than $200 all up when I can find an RB20 Ball bearing unit for $250.
[Updated on: Wed, 14 August 2002 06:13]
TE72_Turbo
Re: CT26 Turbo and CT20 Wed, 14 August 2002 07:51 Go to previous messageGo to next message
to buy a rebuild kit for a CT26 (retail) is $385.00. this includes the bearings, seals, & o-rings that you need.
you can put it together yourself, but you still need to budget another $120 or so to get it balanced once assembled.
Phil
Duff
Re: CT26 Turbo and CT20 Wed, 14 August 2002 22:57 Go to previous messageGo to next message
y dont you just pick one up from a wrecker their like $300-$350 depending on condition and no. of k's
GEE120
Re: CT26 Turbo and CT20 Thu, 15 August 2002 00:39 Go to previous messageGo to next message
GCG will do the rebuild for you for $440 and im pretty sure they balance them also.
TE72_Turbo
Re: CT26 Turbo and CT20 Thu, 15 August 2002 09:08 Go to previous messageGo to next message
thats a damn good price!
1UZ FTE
Re: CT26 Turbo and CT20 Thu, 15 August 2002 09:31 Go to previous message
Hi Guys
I was only looking for $150 for the CT26 as this is all i payed for it at the local wreckers
I haven't at all checked it or pulled it apart but from the outside it just looks like the bearings have failed
The CT20 highflowed i only want the same for as i realise both turbo require bearings and seals
thnaks
j
Previous Topic:HKS PFC f-con *For Sale*
Next Topic:% speed box to suit k series engines...engines also available.
Current Time: Mon Nov 23 06:15:26 UTC 2026
Total time taken to generate the page: 0.0045278072357178 seconds
