Toymods » Tech & Conversions » 1g-gte ct12 exhaust blades
1JZ - JZA70
Chicago, IL
1g-gte ct12 exhaust blades Mon, 16 February 2004 22:20 Go to next message
Hello, I'm from the states and new to the forum. But there was a discussion that was raised about 1g-gte ct12 exhaust blades fitting inside a ct12a exhaust housing (the stock 1JZ twins).
Though ct12's are metal blades. shaft diameter of ct12 and ct12a are the same. if you slap in a ct12 into a ct12a, you don't have ceramic fins busting up all over the place, and you can boost higher. and it spools up around the same point as each other (ct12 turbine is smaller, so less mass to push, whereas ct12a turbine is larger, but less mass to push due to ceramics)
Does anyone know anything about this? I tried finding an earlier discussion that your forum might have had before, but didnt seem to find anything, thats why I am asking. Someone also told me to come to this forum, because it is a normal thing to be seen on the forums of a conversion like this. And if it is possible, could you boost more, how much? and would it be easy to do? Thank you very much.
CrAiGzEE
south of the big smoke
Re: 1g-gte ct12 exhaust blades Mon, 16 February 2004 23:05 Go to previous messageGo to next message
i dont think its the 1g exhaust wheels that are used im pretty sure it the startlet turbo exhaust wheels!
1JZ - JZA70
Chicago, IL
Re: 1g-gte ct12 exhaust blades Tue, 17 February 2004 03:09 Go to previous message
Yeah thats what people are telling me, that it's from the Startlet. But the housings need to be enlarged, how do you go about doing something like that? I was also told that the twins with steels in them would become greatly in-efficient. But I dont understand, because there have been people in the past boosting farther than 14.5 psi or 1 bar max (which is at the point where your suppose to blow the shit out of turbos) and have made more power. I dont know, if I can have someone elses info on this it would be great.
Previous Topic:Help with modifing my new AE86 sprinter (suggestions)
Next Topic:What type of Oil for compressors?
Current Time: Sat Oct 24 19:43:49 UTC 2026
Total time taken to generate the page: 0.005950927734375 seconds
