Toymods » Tech & Conversions » Need to borrow a tool (or buy one even)
bbaacchhyy
Need to borrow a tool (or buy one even) Tue, 17 February 2004 01:11 Go to next message
Hiya,
And before I get any smart ass answers, I need a mechanical tool, not a human being type knobhead ...oh bugger it.
Anyway, I ahve finally removed the auto from the Mk2 and along with a few swaer words, ended up with transfluid everywhere. Fark.
What I need now is a little hoosimegiggit or doflunky that will enable me to remove the flex plate and install the flywheel so I can fiot the 5 speed.
The tool I am talking about is one that bolts onto the back of the block and has some teeth on it to engage the flywheel/flexplate so the bolts can be done/undone without the engine spinning.
Acn someone please help ?
Willing to pay to borrow one + shipping costs, or are they cheap to buy ?
Michael B
CLG
Perth, Western Australia
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 01:22 Go to previous messageGo to next message
Cheaper option is to get a mate, one of the bellhousing bolts, and a large screwdriver. Install the bellhousing bolt - this will be used as a pivot point/stable area from which to rest the screwdriver while you use the end of the screwdriver to mesh with the teeth. Once locked up with the screwdriver by your mate, you can crack the flexplate bolts. Be sure to crack them all first before you take any out completely, to reduce the risk of breaking one of the bolt's off.
bbaacchhyy
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 01:31 Go to previous messageGo to next message
Thanks Clint, but um.. no thanks. That method is OK to get stuff off, but not to torque things back up.
Michael B
CLG
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 01:48 Go to previous messageGo to next message
can you not put a breaker bar on the crank pulley at the front, resting it against the body, locking the engine from spinning, while you torque the rear bolts for the flywheel up? I've never had a problem retorquing bolts using a technique like this.
ae86drift
sydney.au
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 02:08 Go to previous messageGo to next message
CLG wrote on Tue, 17 February 2004 12:48
this worked for my car
my car goes great since
bbaacchhyy
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 02:27 Go to previous messageGo to next message
7M's have a nasty habit of loosening their front pulletys and causing heaps of crank damage.
I may do that, but I am avoiding that method for that reason and would like to do it in a more 'professional manner'
Any mechanics out there - what do you use ?
Michael B
commander
Canada
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 02:54 Go to previous messageGo to next message
i guess build one.
mount it in place of the starter...
...me... man,,, jam a screwdriver in somewhere....
ed_ma61
Lost in the K hole
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 03:38 Go to previous messageGo to next message
rattle gun Nod
bbaacchhyy
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 04:48 Go to previous messageGo to next message
Ok, that will work to undo, but can I borrow your rattle gun, and if so, does your rattle gun have a torque setting ?
I'm rough at times, but not that bad........
It's like doing surgery with a pair of side cutters !!!!
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 05:22 Go to previous messageGo to next message
What CLG mentioned is the method i've seen most mechanics use also .. I've never had a problem with it.
CLG
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 05:53 Go to previous messageGo to next message
I think you'll find most mechanics simply rattle flywheels back on, they have a good understanding of the torques and pressures exerted by their guns anyway. New tools would be to the contrary though. As for loosening the crank pulley, won't this only occur if you're attempting to loosen the flywheel bolts, not torque up?
TokenBlackGuy
      wtf is jabber
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 07:09 Go to previous messageGo to next message
At my work the way CLG explained is the way we all do it! It works fine, and you can rattle run the bolts back up! No damage its all safe and good!!! Just try it... Cool
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 07:15 Go to previous messageGo to next message
Get a length of chain. Put a bolt thru one eye of the chain and then bolt it up to the flywheel using a pressure plate bolt. Using another chain eye a few link along, put a bellhousing bolt thru this and bolt it up to the back of the motor.
Tighten up your flywheel bolts. You will suddenly notice that chain doesn't stretch. Torque flywheel bolts to desired torque. Ideal for weaklings like myself, solo backyarders, and rattle gunless individuals.
TokenBlackGuy
      wtf is jabber
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 07:20 Go to previous messageGo to next message
gianttomato wrote on Tue, 17 February 2004 18:15
Thats a good one, i never herd of that lol, gonna write that one down!! Cool
Dabbid
Yowie Bay, Sydney
Re: Need to borrow a tool (or buy one even) Tue, 17 February 2004 07:36 Go to previous message
i'm a mechanic, have never done it any other way than the screwdriver method, for undoing anyway
if the flywheel bolts require a hi-torque setting, use a crowbar
Previous Topic:Which gasket to use?
Next Topic:Notchy W50
Current Time: Sat Oct 24 20:37:39 UTC 2026
Total time taken to generate the page: 0.0048990249633789 seconds
