Toymods » Tech & Conversions » Diff between 3sgte gens in ST185 & ST205?
no_tofu_speed
Jab what?!!?!
Diff between 3sgte gens in ST185 & ST205? Tue, 17 February 2004 01:47 Go to next message
Just curious about the differences between the 3sgte generations (3rd and 4th? - unsure) engines in the ST185 & ST205?
To work out if it is worth going to the extra trouble in paying more and sourcing an ST205 version etc etc.
AE82TwinCam
Canberra, ACT
Re: Diff between 3sgte gens in ST185 & ST205? Tue, 17 February 2004 02:19 Go to previous messageGo to next message
from what I've picked up from various posts is that the 3rd Gen 3s-gte out of the st205's has far more potential for power in stock form. They have bigger stock injectors (550cc I think) and a better head design, they also possess a better matched turbo (don't know the extact model turbo).
Hope this helps a bit
-Andrew
Senor_2
Re: Diff between 3sgte gens in ST185 & ST205? Tue, 17 February 2004 02:24 Go to previous messageGo to next message
There are quite a few changes between the ST185 (2nd gen) and ST205 (3rd gen) motors, the 3rd gen uses a different turbo (CT20B), more boost, lower compression, different cams, larger throttle body, bigger injectors, different intercooler, ummm thats all i can remember at this stage.... i think the gearbox ratios are different as well....
The 3rd gen would be the better motor, making more power, being stronger, and a better starting point for more power Evil or Very Mad
But they are harder to find and more expensive.... if u do find any 3rd gen (pref MR2) half cuts lemme know!!
Classique71
Colac, Victoria
Re: Diff between 3sgte gens in ST185 & ST205? Tue, 17 February 2004 11:35 Go to previous messageGo to next message
bottom end is basically the same - though compression is lower
205 has much better head design - runs map , instead of afm , no TVIS , bigger injectors ( as noted ) a better intercooling system thatn the air to air setup on the 185 etc ..
cams are sligtly more wild on the intake side - but identical on exhuast
throttle body went from a 55mm item to a 65 i think ..
Turbos a fair bit better in design though a ct26 can still turn out comparable numbers when highflowed
thats about i know off the top of my head at this hour of the night
no_tofu_speed
Jab what?!!?!
Re: Diff between 3sgte gens in ST185 & ST205? Wed, 18 February 2004 15:44 Go to previous message
Appreciated greatly that info!!!!!!!!!!!!
Previous Topic:Plenum size
Next Topic:Toyota corona bodykit styles
Current Time: Tue Oct 20 23:02:47 UTC 2026
Total time taken to generate the page: 0.0054671764373779 seconds
