Toymods » Tech & Conversions » KE70-4AGE throttle cable & radiator hose
bmak
KE70-4AGE throttle cable & radiator hose Tue, 17 February 2004 08:43 Go to next message
What do people usually use with the 4AGE in a KE70?
The 4a cable is too short & the k cable works but too long.
Is there a perfect fitting 1?
My bottom radiator hose is also too short to fit around the alternator, is there a specific hose for this?
Thanx
IRA11Y
Club Member
Re: KE70-4AGE throttle cable & radiator hose Tue, 17 February 2004 08:53 Go to previous messageGo to next message
Try a KE30 one it will be a little long but if you loop it around under the brake booster it seems to be a nice fit without loosing feel, failing that go buy one from toyota
bmak
Re: KE70-4AGE throttle cable & radiator hose Tue, 17 February 2004 09:01 Go to previous messageGo to next message
thanx for that.
I put on a ke30 type & i'll try what you said.
Any suggestion on the bottom hose?
BTW its a RWD motor
IRA11Y
Club Member
Re: KE70-4AGE throttle cable & radiator hose Tue, 17 February 2004 09:42 Go to previous messageGo to next message
180b
Grega
melbourne.victoria.austra...
Re: KE70-4AGE throttle cable & radiator hose Tue, 17 February 2004 18:46 Go to previous messageGo to next message
brad
ra65 accel cable. goes to my GRA carb perfect fit.
bottom hose with RWD water pump - datsun bluebird - you'll need to trim a bit off it though.
IRA11Y
Club Member
Re: KE70-4AGE throttle cable & radiator hose Wed, 18 February 2004 05:58 Go to previous messageGo to next message
the 180b and bluebird are the same hose
bmak
Re: KE70-4AGE throttle cable & radiator hose Wed, 18 February 2004 10:37 Go to previous messageGo to next message
Thanx
Re: KE70-4AGE throttle cable & radiator hose Wed, 18 February 2004 23:01 Go to previous message
What I do for cables is start with a KE30 one and shorten it to suit, although an RA65 one would come very close I'd imagine. Just hit the wreckers and find something the right length
Previous Topic:Ta 22 struts and Ra 65 discs
Next Topic:solex recondition kits? cost
Current Time: Thu Oct 22 07:48:06 UTC 2026
Total time taken to generate the page: 0.005763053894043 seconds
