Toymods » Tech & Conversions » Too many headaches under the bonnet (18R-C)
mike1980ra40
Too many headaches under the bonnet (18R-C) Tue, 17 February 2004 11:23 Go to next message
Hello all, I am newbie to this forum and would like to say hi to
all. I am the (un)lucky owner of a November 1980 ra40 hatchback
celica. I have read a lot of posts here and people seem to have the same or similar faults I have.
I am regularly blowing the exhaust flange gasket and hot box gaskets.
Backing off the accelerator quickly from hi speed makes the car
snap crackle and pop like a fuel cut isn't working (not sure on that). flange bolts keep undoing themselves and flange gaskets keep turning into white powder.
at present my car in on ramps engine half dismantled.
I have extractors in the shed, motivator 2" 4,2,1.
which if can be used will go straight on to my existing exhaust; 2" pipe to a dynamax 16" ultra flow muffler.
while writing this post I got a call from a mech telling me my
inlet manifold carb face is warped so theres a few problems solved there.
questions I have is:
1. Is it really safe to put extractors on 18R-C's?
2. Will removal of the EGR system increase combustion temperature
therefore increasing the risk of a cracked head? if so is there
any way of keeping the combustion temp down, or would i be better
of setting up a cold air intake?
3. If extractors can be used without any risk would they benefit
from heat insulating bandage?
4. Is the Flashlube Lube system a good idea or not? any experiences? I have the little 500ml bottle that can be plumbed into the intake.
5 I have a spare g/box from a 1979 imp jap hatch does anyone know
what if any differances are between the local W50 and the imp W50?
if anyone has any questions comments or answers they'll be greatly appreciated. thanks in advance
M.W.P.
Rocky Mountains, Canada
Re: Too many headaches under the bonnet (18R-C) Tue, 17 February 2004 12:46 Go to previous messageGo to next message
Fresh air enters the hot exst and causes unburnt fuel to burn (go bang).
Its not a problem of too much fuel, its a problem of the air leaks.
2. Will removal of the EGR system increase combustion temperature therefore increasing the risk of a cracked head? if so is there any way of keeping the combustion temp down, or would i be better of setting up a cold air intake?
3. If extractors can be used without any risk would they benefit from heat insulating bandage?
5. I have a spare g/box from a 1979 imp jap hatch does anyone know what if any differances are between the local W50 and the imp W50?
1. No problem.
2. It shouldnt... many people remove the smog gear with no problems.
3. Maybe... bandage can cause problems like rust... better off getting them ceramic coated if you can afford it.
4. Yup, install away... then you can run ULP/PULP/ULP98 with confidence.
5. A W50 is a W50, no matter where its from... the only thing that can differ is the shifter position.
[Updated on: Tue, 17 February 2004 12:48]
mike1980ra40
Re: Too many headaches under the bonnet (18R-C) Tue, 17 February 2004 13:32 Go to previous messageGo to next message
hi mwp, thanks for the pointers Smile
seems to me that extractors will help eliminate the half the
problems.
however that raises another question. Does a simple conversion
to ULP require the fitting of a cat converter (for any legal
issues) i think i saw it in another post somewhere...
or is a cat not needed as I would be using a lead supplement?
I wasnt sure on the two w50's i have, both have slighty different
part numbers perhaps indicating one built locally and the other
built in japan.
cheers Smile
M.W.P.
Re: Too many headaches under the bonnet (18R-C) Tue, 17 February 2004 15:28 Go to previous messageGo to next message
mike1980ra40 wrote on Wed, 18 February 2004 00:02
AFAIK, it does Sad
Re: Too many headaches under the bonnet (18R-C) Wed, 18 February 2004 00:41 Go to previous messageGo to next message
No, it does not. Cat converters are only required if your car and/or engine were originally fitted with one.
mike1980ra40
Re: Too many headaches under the bonnet (18R-C) Wed, 18 February 2004 10:20 Go to previous message
Norbie wrote on Wed, 18 February 2004 11:41
Thanks norbie that answer makes sense. I was a tad concerned about
that. once my leeka is back on the road I'll take some shots of
what I have done relating to my origianl post and put a page on my
site for all to see. IE cold intake on an ra40 without major mods.
cheers Smile
Previous Topic:anyone can help with modify RA23 for drifting purpose
Next Topic:1G-GTE Error Code 25
Current Time: Sun Oct 18 20:04:53 UTC 2026
Total time taken to generate the page: 0.0090539455413818 seconds
