Toymods » Tech & Conversions » Window Seals RA23
GIN51E
Berowra-Sydney
Window Seals RA23 Fri, 09 August 2002 12:30 Go to next message
I need a new seals that go on the back side windows where they meet with the door windows does anyone know where to get these and also how do u remove them?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Window Seals RA23 Fri, 09 August 2002 12:40 Go to previous message
You can get them from spectrum rubber in Mt Druiit or through Rare Spares. I think these are off some torana, but are a pretty good fit.
To replace them you really need to pull out the window, and down the bottom of the rubber strip is a little screw. Undo this, and now you can slide the rubber down & out. Be carefull, the edge of the chrome strip is sharp & can leave a nasty cut.
Slide the new rubber back in, & from memory there's not much left to attach with the screw but that rubber ain't coming out anyway.
Use a bit of lube to put the new one in, it's a tight fit.
Oh, that's right, I think they're about $25 each.
Previous Topic:custom make header
Next Topic:Curren with 3S-GE, what mods to do?
Current Time: Sat Oct 17 22:20:39 UTC 2026
Total time taken to generate the page: 0.0037989616394043 seconds
