Toymods » Tech & Conversions » Something about the 3sfe
4AGE
Something about the 3sfe Wed, 18 February 2004 01:23 Go to next message
Hey guys. Just a few things i'd like to know.
Theres a camry station wagon here. Its my cousins. She has a 3sfe in her car in manual. I heard these are quite scarse due to being the manual. Anyway she got some issues with her motor. Believe the oil pump is rooted and timing belt has been changed incorrectly.
Anyway being part of the 3s family. how possible would a 3sge be in her car? Bell housings? Wiring?
How about the actual availablily of these 3sfe motors? How are they? Expensive? Decent? I drove it before its not too bad for a 2 liter twincam.
The motor is in a really bad state. Just wanting to dig up a few opinions on what can happen. ATM i'm going down to the joint to yell the living hell out of a dodgy apprentice that changed the oil seals x 3 and timing belt.
Some help guys... PLease???
acv17
northside brisbane
Re: Something about the 3sfe Wed, 18 February 2004 03:22 Go to previous messageGo to next message
Anyone who's got a 3S-FE manual Camry usually doesn't know how to use it. There's this impression that they "Mum's and Grandma's cars". That's funny they've the same engine family as Celicas!!!
Anyway the 3S-FE is very common. And both compatible with auto and manual. (My brother has an auto and i have a manual - big difference. A manual Camry used effectively can make any "P plate Commodore driver at the lights look stupid - trust me i'm that person!) Personally i was going to turbo my Camry, however, ive had opinions on it and they say u r better off 3S-GE/GTE-ing it because the cost is almost the same.
A good thing about the 3S-FE's are that with regular servicing they can last, i've know up to 3500000klms, before reconditioning. But as for your cousin's i'd say that motor would cost a lot to fix up! Give that mechanic hell!!! You might have to get a another 3S-FE and YES 3S-GE's do fit, but for even more compatibility i'd use a Celica/Supra gearbox of that model engine.
Look at FWD Camry and Celica Manuals and the measurements will help you decide what fits!
[Updated on: Wed, 18 February 2004 03:23]
StuC
Re: Something about the 3sfe Wed, 18 February 2004 04:49 Go to previous messageGo to next message
heres the go, any 3sge will fit straight up, no mods needed. Thats gen1-3 as the mounts are all the same. As for the 3sgte ur gonna have to do a bit of work to get it to fit. As for power etc, if u wanna stay NA, go the norm 3sge, gettin 103kw, 117 and 137kw at the flywheel as standard. Gen 1 came in the celica and gen2 and 3 are out of mr2s. If the engines that stuffed u can pick up a gen1 for under 800bux easy. Check out http://www.toyospares.com.au
They're in melbourne so they can help u out.
good luck
dorikin
NE Melbourne
Re: Something about the 3sfe Sat, 17 April 2004 02:49 Go to previous messageGo to next message
StuC -
do you know if the same goes for the 2S camrys (SV11 and early SV21)?
would a 2S have all the same engine mounts as the 3SGE/GTE. and is the bell housing the same on them?
also having done the engine conversion, is the gearbox going to be tough enough?
would it be worth getting a gearbox from a ST162? what about drive shafts will they be strong enough?
there is the option to use a MR2 N/A or turbo box and swap the linkages around?
also i heard a rumour that the 4AGZE box is the same as a MR2 turbo box (bell housing aside), is this true?
if so can a 4AGZE box be used with a 3SGE bell housing for a tough complete package?
sorry about all the questions, but these isn't a lot of chat here about camry's, finding it difficult to find stuff out
dorikin
NE Melbourne
Re: Something about the 3sfe Sat, 17 April 2004 03:44 Go to previous messageGo to next message
just another thought, will all the accessories and brackets on the front of the engine (ps, ac, alternator) bolt onto the 3S from the 2S???
Re: Something about the 3sfe Sat, 17 April 2004 03:53 Go to previous messageGo to next message
Dori,
The 2S engine mounts will not bolt directly to the 3S. The 3S has a rib which as 2 mounting points ground away on the inlet side. You have to make an adaptor plate to alloy the standard mount to bolt to something.
The borgwarner box in the 2S camry will not handle the 3S at all. And the bellhousing on this box will fit the 3S, but it wont suit a W series box.
The 2S accessory brackets should fit the 3S but i'm not 100% sure.
dorikin
NE Melbourne
Re: Something about the 3sfe Sat, 17 April 2004 04:22 Go to previous messageGo to next message
cheers for the info. the plan is to stay FWD, was just toying with the idea of a 3SGE SV11 camry. but i'm really not interested in doing much fabrication, was hoping for a nut and bolt engine swap. its a shame that the blocks are so different!!!
people100
Rocklea qld
Re: Something about the 3sfe Sat, 17 April 2004 06:06 Go to previous messageGo to next message
Physically the 2s and 3s blocks are the same except for the mounting points arent they???...why not just put the 3s head on a 2s bottum end....making sure you rebuild it all as you go...
dorikin
NE Melbourne
Re: Something about the 3sfe Sat, 17 April 2004 06:46 Go to previous messageGo to next message
that's a good idea, but just more hassle... i like the idea of getting a second hand engine and just dropping it right in, not having the extra expense of gasket kits, parts, etc... does anyone have any photos of the two blocks to compare the differeces?
people100
Rocklea qld
Re: Something about the 3sfe Sat, 17 April 2004 07:10 Go to previous message
they are identical as far as i knew except the missing mounting point....being front wheel drive though the complete engine may be a straight swap...only mount point is a hassle when doing a rear wheel drive conversion as far as i knew....try google or something for more info.
Previous Topic:4AFC clutch info
Next Topic:Which fuel pump will fit?
Current Time: Sat Oct 17 03:45:54 UTC 2026
Total time taken to generate the page: 0.0055830478668213 seconds
