Toymods » Tech & Conversions » Help need info! 3SGTE group A vs ST model engines
Swoon
Brissy
Help need info! 3SGTE group A vs ST model engines Wed, 18 February 2004 03:14 Go to next message
Can anyone enlighten me on what the difference is between the group A motor and that of the ST205 and alike?
also whats the max boost that can be run out of the CT26 turbo?
James
-==L=a=N=c=E==-
Brisbane, Queensland
Re: Help need info! 3SGTE group A vs ST model engines Wed, 18 February 2004 08:21 Go to previous messageGo to next message
From the info that i ahve gotten.
Differences between the ST185A and the ST205 engines are here....
http://alltrac.net/specs/GT4Specs.htm
Those are just performance specs. Other suttle differences are that the ST205 has the 'CT20B' turbo, slightly different cams, different head, larger injectors, larger WTA intercooler etc. etc. etc.
As for maximum boost from a CT26, it is said that once you get past 14PSI your dropping outta the effiecieny band. So stick to anything below this.
Anyone else want to correct me if im wrong?
Classique71
Colac, Victoria
Re: Help need info! 3SGTE group A vs ST model engines Thu, 19 February 2004 01:40 Go to previous message
the ct26 on a 3sgte will push up to 18psi in stock trim using the group A or aftermarket ECU for fuel mapping, but thats really about it - as before - its dropping out ..
Highflowing is a better option - 18 psi on a highflow would be the equivelent of over 20psi easy - without the side effect of extra heat generation ..
50 - 52 trim to4e equivelent wheel is good for this - its the most popular upgrade ..
I know of Gt4's pushing out over 230KW at the wheels on highflowd ct26's - so they are the goods ..
As for motor differences - click that link .
Previous Topic:need help doing a compression test on my new girl
Next Topic:Font of Hatch Stickers?
Current Time: Fri Oct 23 15:36:45 UTC 2026
Total time taken to generate the page: 0.016395092010498 seconds
