Toymods » Tech & Conversions » 2JZ-GTE VVTi
Stephen2
Melbourne, VIC
2JZ-GTE VVTi Wed, 18 February 2004 05:14 Go to next message
Guys,
Can you let me know what model Aristo/something else I think the VVTi 2JZ-GTE comes from?
What are your thoughts on the VVTi in a turbo engine?
Is it vastly superior to the previous 2JZ model?
Thanks!
Stephen
Re: 2JZ-GTE VVTi Wed, 18 February 2004 05:19 Go to previous messageGo to next message
The 2JZ was updated across the board in 97/98 from memory, so any 2JZ built after then will be VVTi. You can find them in Supras, Crowns, Aristos, Soarers, and probably others as well.
Soarer
Wollongong
Re: 2JZ-GTE VVTi Wed, 18 February 2004 06:28 Go to previous messageGo to next message
No 2JZ-GTE in the Soarer, just the slow arsed GE Sad
Re: 2JZ-GTE VVTi Wed, 18 February 2004 07:40 Go to previous messageGo to next message
Sorry I didn't see the "T" (must be getting old), so you'll only find them in the Supra and Aristo.
Re: 2JZ-GTE VVTi Wed, 18 February 2004 08:20 Go to previous messageGo to next message
according to best figures, the 2jz-gte vvti makes 30 more bhp peak power, and 15 more lb-ft of torque (interestingly, at the same 3600rpm as the non-vvti version)
I've never actually seen a side-by-side unmodified dyno graph of each - but my insincts say the vvti is your better option, as long as you're not planning on going super nuts on the modding
Celia-Sue
Re: 2JZ-GTE VVTi Wed, 18 February 2004 09:46 Go to previous messageGo to next message
From memory, the VVTi 2JZ's I've seen advertised are a LOT more expensive. For that sort of extra money, you might be better off spending it on an earlier 2J. Maybe some stage one cams or something?
Stephen2
Melbourne, VIC
Re: 2JZ-GTE VVTi Thu, 19 February 2004 00:09 Go to previous messageGo to next message
I have to agree with the cost vs. return argument.
Are the advantages produced by variable timing lost completely when you heavily modify the engine?
New turbos, good computer, new cams etc..?
Isn't it probable that the VVTi would allow you to bring the revs up quicker from idle, thus bringing boost on that bit earlier?
Wondering on any thoughts about VVTi in a Turbo car...
Re: 2JZ-GTE VVTi Thu, 19 February 2004 01:30 Go to previous messageGo to next message
You will still reap the benefits of VVTi with a modified engine, but there are two catches:
1. You will NEED high-end engine management (eg Motec) to run the VVTi.
2. You'll have to find someone who knows how to tune it.
Re: 2JZ-GTE VVTi Thu, 19 February 2004 01:45 Go to previous messageGo to next message
Norbie wrote on Thu, 19 February 2004 12:30
Another catch.
It may be physically impossible to run a large duration, high lift cam AND VVTi.
Secrutioner
Gold Coast
Re: 2JZ-GTE VVTi Mon, 23 February 2004 08:51 Go to previous messageGo to next message
i read bout a supra in hpi that was vvti. had a hks t51r spl on it. was used to race against ferraris and lambourginis... nuff said i rekon.....
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 2JZ-GTE VVTi Tue, 24 February 2004 08:07 Go to previous messageGo to next message
Norbie wrote on Wed, 18 February 2004 16:19
Is there an actual date of changeover or was it a more gradual thing?
Re: 2JZ-GTE VVTi Wed, 25 February 2004 05:44 Go to previous messageGo to next message
Yes there is an actual date, for the Supras anyway; I assume it would be the same across the board. Can't recall what the date is though...
Nark
Cabramatta, NSW
icon2.gif  Re: 2JZ-GTE VVTi Wed, 25 February 2004 05:55 Go to previous messageGo to next message
I've done a bit of reading and it seems that the 2JZ-GEs turned VVTi in '98 but at an earlier date than the 2JZ-GTEs. Not sure if the 2JZ-GTE turned VVTi in late '98 or early '99.
deesonet
Toowoomba
Re: 2JZ-GTE VVTi Wed, 25 February 2004 10:14 Go to previous messageGo to next message
It was August 96 when the 1JZ went to VVTi but not sure of the 2JZ version.
Has anyone seen any technical data on the VVTi function. I want to know the electrical signals that trigger the cam positioning.
ae86drift
sydney.au
Re: 2JZ-GTE VVTi Wed, 25 February 2004 10:16 Go to previous message
gianttomato wrote on Thu, 19 February 2004 12:45
Another catch.
it is impossible
the vvti with the 20v 4age is proven a bitch with high lift long duration cams, almost not worth it at all to run vvti
most people dont
Previous Topic:Timming
Next Topic:4agze air/con
Current Time: Thu Oct 15 10:42:28 UTC 2026
Total time taken to generate the page: 0.0060429573059082 seconds
