Toymods » Tech & Conversions » Oil pipe for 3tgte
GEARS
VICTORIA
Oil pipe for 3tgte Thu, 19 February 2004 03:01 Go to next message
just wondering if anyone in the Melbourne area may
know of someone who may be able to make an oil drain
pipe for a 3tgte turbo i have one on the car but have been
told that i may have difficulty replacing it if i damage it
i have tried to find another one from a wreckers but they are
not easy to come by Crying or Very Sad
c2888
Re: Oil pipe for 3tgte Thu, 19 February 2004 06:30 Go to previous messageGo to next message
Is it a stock piece you are after?
because i'm in the same boat, although i don't have to original to copy, i just need one. wouldn't be too hard to fabricate one.
dodgydan
GEARS
VICTORIA
Re: Oil pipe for 3tgte Thu, 19 February 2004 06:47 Go to previous messageGo to next message
I did manage to find an original one but i thought
to have one made up just in case
YelloRolla
On your mum!
Re: Oil pipe for 3tgte Thu, 19 February 2004 09:34 Go to previous messageGo to next message
The original ones a prone to cracking (if you turbo is not properly supported by the factory bracket or a good imitiation of it).
Mine cracked and it was a good thing - get rid of it and replace it with a flexible item (Ortac hose) 19mm or 3/4" make/solder together a barbed fitting arrangement at each end add some hose clamps and voila - sleep well.
Making a solid type steel pipe replacement is perilous because they do not flex - where as the original is billowed steel to deal with the expansion and contraction of the manifold.
Re: Oil pipe for 3tgte Thu, 19 February 2004 22:05 Go to previous messageGo to next message
^ thats what i did.
GEARS
VICTORIA
Re: Oil pipe for 3tgte Thu, 19 February 2004 23:14 Go to previous messageGo to next message
What do you do with the small pipe that
comes off it
Re: Oil pipe for 3tgte Thu, 19 February 2004 23:33 Go to previous message
I think a picture explains best :
http://members.optusnet.com.au/helenfitz/stuff/Manifold3small.JPG
Also note JMR's fancy pipe work.
[Updated on: Thu, 19 February 2004 23:33]
Previous Topic:Tercel guru's look in
Next Topic:2T piston info
Current Time: Wed Oct 28 02:28:10 UTC 2026
Total time taken to generate the page: 0.0038440227508545 seconds
