Toymods » Tech & Conversions » [AE86] clutch issues
ae86drift
sydney.au
[AE86] clutch issues Thu, 19 February 2004 05:28 Go to next message
having a problem with the clutch attached to my t50 (ae86)
i recently replaced the clutch disc and plate and bearings (thrust and spigot) and noticed my slave cylinder was leaking
that was a month ago
noticed yesterday the fluid was almost totally EMPTY... christ!
so went and topped it up to full
now today sometimes when driving the clutch wont engage at all
pedal in
shift gears
*CRRRRRRRUNCH*
regardless of pedal
now i understand the slave is probably totally rooted by now since the fluid is gone
and im in the process of finding a new one (anyone got a JDM clutch slave for $$?)
any OTHER reasons why this may happen?
[Updated on: Thu, 19 February 2004 05:30]
Re: [AE86] clutch issues Thu, 19 February 2004 05:38 Go to previous messageGo to next message
Sounds like you have air in the system.
Bleed the clutch.
Don't know how? I posted how to do it a few days back, do a search
ae86drift
sydney.au
Re: [AE86] clutch issues Thu, 19 February 2004 05:41 Go to previous messageGo to next message
or click your profile
click on show all posts by this user
ctrl-f
search for clutch
found
Very Happy
Re: [AE86] clutch issues Thu, 19 February 2004 05:45 Go to previous messageGo to next message
w00t
Nice work dude
As for getting a new Slave Cylinder (if it comes to that), just take off yours, go into local automotive store, show it to them, and get them to match it to another RWD Toyota of the same year.
They rarely changed.
I have only seen 3 different slave cylinders from mid 70's to mid 80's
ae86drift
sydney.au
Re: [AE86] clutch issues Thu, 19 February 2004 05:52 Go to previous messageGo to next message
cool as
also
my pedal is hard as
and it was working
now not at all
would it still be the the fact it needs bleeding?
or somethign else?
ae86drift
sydney.au
Re: [AE86] clutch issues Thu, 19 February 2004 05:54 Go to previous messageGo to next message
well the t50 from the aus spec is the same but its upside down and wont fit i dont think
anyone?
IRA11Y
Club Member
Re: [AE86] clutch issues Thu, 19 February 2004 09:43 Go to previous messageGo to next message
what about off a tercel, are they on the other side???, call one of the NZ parts importers theyll have one or a toyota dealer in auckland will be able to supply the parts.
Castle hill toyota may also be able to help you
ae86drift
sydney.au
Re: [AE86] clutch issues Sat, 21 February 2004 14:28 Go to previous messageGo to next message
also, clutch fluid is leaking frm abive the pedal onto my foot occasionally
what would cause this?
Re: [AE86] clutch issues Sat, 21 February 2004 14:58 Go to previous messageGo to next message
A fucked clutch master cylinder.
Also could be the cause of an occasionally stiff pedal
Time for a new one
Re: [AE86] clutch issues Sat, 21 February 2004 15:40 Go to previous messageGo to next message
CrUZsida wrote on Sun, 22 February 2004 01:58
Time for a new one
uh huh,
this is a pretty common problem, and you should be able to get a new one pretty easily.. last one i got for an AE82 was about $100 new. don't bother getting re-sleeved or anything fancy, and remember to change the fluid every year or so (it's the water absorbed in the fluid that causes to internal corrosion in the bore)
ae86drift
sydney.au
Re: [AE86] clutch issues Sun, 22 February 2004 01:27 Go to previous messageGo to next message
coool. thanks for the grat feedback guys. i was concerned about the amount of fluid leaking down onto the firewall under the clutch master... so i figured it might be ucked
does anyone have the part number of a clutch master cylinder?
does an AUS ae86 one fit? i imagine it would
steve im looking at you. EPC boy.
The Wombat
Windy Wellington (NZ) but...
Re: [AE86] clutch issues Sun, 22 February 2004 01:42 Go to previous messageGo to next message
My clutch slave cylinder is weaping but i was told it was not an imediate problem by the people who service my car but it need s to be sorted out. could this also explain why my AE86 has quite a "HIGH" clutch. just some thoughts. Confused
JDM hachi
was adelaide now newcastle
Re: [AE86] clutch issues Sun, 22 February 2004 02:45 Go to previous messageGo to next message
the aussie master will bolt straight on, as for the leak, remember that brake fluid eats paint, lift up your carpet and see if the driver side floor will need a quick touch up to stop rust, ive been here before.
matty.
ae86drift
sydney.au
Re: [AE86] clutch issues Sun, 22 February 2004 03:11 Go to previous messageGo to next message
i ws wondering that, i was also wondering why my carpet was OK? doesn't it eat fabrics or is that only battery acid?
ill do all of that when i put the new master and slave
i think ill get some killrust spraypaint and go to town on the floor and firewall
best way to prep metal for paint after corrosion?
do i need to fish-oil it first? or after?
ae86drift
sydney.au
Re: [AE86] clutch issues Sun, 22 February 2004 04:12 Go to previous messageGo to next message
note the shitty slave shown below
http://garth.digitalfunk.net/ae86/slave/1.jpg
http://garth.digitalfunk.net/ae86/slave/2.jpg
http://garth.digitalfunk.net/ae86/slave/3.jpg
http://garth.digitalfunk.net/ae86/slave/4.jpg
Re: [AE86] clutch issues Sun, 22 February 2004 11:05 Go to previous messageGo to next message
Hmmm, looks like a mirror image of a standard slave cyl.
I think you'll find PBR does one off the shelf.
Take your car to a clutch/brake specialist.
They should be able to get you one with no problems
ae86drift
sydney.au
Re: [AE86] clutch issues Sun, 22 February 2004 11:18 Go to previous messageGo to next message
its okay
i got a w57 one from CLG
along with an ae86 master cylinder too
and directions on how to change em over!!!!
clint rocks my socks Very Happy
Very Happy
CLG
Perth, Western Australia
Re: [AE86] clutch issues Mon, 23 February 2004 01:23 Go to previous messageGo to next message
Yeah Baby, meet me on the dance floor with just your socks on, and we'll rock this joint! Twisted Evil Laughing Shocked Rolling Eyes
ae86drift
sydney.au
Re: [AE86] clutch issues Mon, 23 February 2004 06:17 Go to previous message
hohoho
didya send em yet??
Previous Topic:fuel pump and dizzy
Next Topic:3SGE to 3SGTE
Current Time: Mon Oct 19 17:51:06 UTC 2026
Total time taken to generate the page: 0.0079481601715088 seconds
