Toymods » Tech & Conversions » AE86 4AGE Wiring
Green_Comet
Victoria, Melbourne
icon2.gif  AE86 4AGE Wiring Thu, 19 February 2004 06:29 Go to next message
Hey everyone,
well im just about to put a 4age bigport in my sprinter, and i need a little advice on the wiring. Confused
I have an uncut engine loom out of an ae82 twincam, which has 10pin and 18pin sockets for the ecu, and the 14pin plug which was cut off the dash loom.
How do i go about wiring up the 14pin plug into the engine loom?
I have been reading the pin out identifications and i know what most the 7 wires on it are for, but im still sorta lost especially when it comes to wiring..
Does anyone know how i can wire it up?
any help is much appreciated. Very Happy
Ryan
[Updated on: Thu, 19 February 2004 06:32]
Re: AE86 4AGE Wiring Thu, 19 February 2004 07:50 Go to previous messageGo to next message
That 14 pin plug doesn't really wire into the engine loom, thats why it isn't part of it..
It's for power, circuit open relay, and things like AC and gauges etc.. Most the wires are not used.
shinybluesteel
melbourne
Re: AE86 4AGE Wiring Thu, 19 February 2004 10:04 Go to previous messageGo to next message
joel, how hard is it to wire up a, for example, 100kw loom assuming i have the e,ectrical manual and an uncut loom, easy or piss easy?
Green_Comet
Victoria, Melbourne
Re: AE86 4AGE Wiring Thu, 19 February 2004 10:29 Go to previous messageGo to next message
when u say power does that mean, constant power for lets say memory? or just acc power?
Is the circuit open relay the little black box that came with the ecu?
What is it used for? i dont have the plug for it..
I hate wiring its making me stressed, as i have a perfectly good engine but little idea of how to wire it up! Confused
How much do u think a sparky would charge me to hook it all up?
sideshow
Re: AE86 4AGE Wiring Thu, 19 February 2004 10:40 Go to previous messageGo to next message
if u send me the loom ill connect relyas in the correct spot
ill wire all of it up
there will be 3 or 4 wires for u to do
one to battery
one to ignition signal
and one to start signal
and one to earth
if u send me the engine loom from the ae86 (the part with temp oil and start wires)
ill connect them up too
pm me for a price
[Updated on: Thu, 19 February 2004 10:40]
Green_Comet
Victoria, Melbourne
Re: AE86 4AGE Wiring Thu, 19 February 2004 10:50 Go to previous messageGo to next message
well me and a couple friends are gonna try and have a go at it, and if worst comes to worst ill send it to u....
I though one of the sparkys at my old mans work was gonna help me out but he didnt follow through. Mad
ryan
natez
Re: AE86 4AGE Wiring Thu, 19 February 2004 14:14 Go to previous messageGo to next message
hey ryan...
its not that hard... its not piss easy, but its easyier than what you are thinking....
you need to know these wires Start signal, which is te black and white wires coming out of the ignition switch
and the ON signal which is the black and yellow wire....
its hard to explain over the net, mines still not completly covered in tape yet so if you want to look at mine give me a call and you can come over and have a look.. i can tell you which exact wires go where as i've just finished mine started up nicely... on the second go...
45aken
NSW.south coast.Drifting
Re: AE86 4AGE Wiring Sat, 21 February 2004 01:44 Go to previous messageGo to next message
if you could send me a photo of the finished loom it would be greatly appreciated!
sleepeyone@hotmail.com
natez
Re: AE86 4AGE Wiring Sat, 21 February 2004 03:01 Go to previous messageGo to next message
this is what i did to get a proper 100kw wiring diagram
i went to the local libary, that has got the corrolla ae92 models, in the back there is a wiring diagram for the 4age, i photocopied that, that tells you which wires go where and exactly were they go...., its quite easy to read....
you won't be able to tell jack all from a photo of the wiring as, wiring does go into the cabin and you can tell which is which by a photo
Re: AE86 4AGE Wiring Sat, 21 February 2004 04:36 Go to previous messageGo to next message
wiring is actually really simple, since all you have to do is connect a wire here and a wire there.
you need to sit down with the wiring diagram for the motor, and one for the car, and work out what needs to go where..
do it all logically and methodically and write everything down.
if you 'have a go' then get a sparky to sort out your mess, it will cost you 3 or 4 times as much, since it is easy to do from the beginning, but hard to work out what someone else has done Wink
if you are concerned, i'd be PMing Sideshow Wink at least he has done it before and knows what goes where Very Happy
shinybluesteel
melbourne
Re: AE86 4AGE Wiring Sat, 21 February 2004 12:11 Go to previous messageGo to next message
once again, for all your technical info needs
http://www.toymods.org.au/cgi-bin/photo/index.cgi? mode=view&album=/TechDocs/4age_book
and
http://www.toymods.org.au/cgi-bin/photo/index.cgi? mode=view&album=/TechDocs/ae86_book
commander
Canada
Re: AE86 4AGE Wiring Sun, 22 February 2004 04:15 Go to previous message
i'll have a go. ( inaccurate then accurate data )
I have everything here. Checking now.
piss easy huh ? looks like about 50 connectors there.
i have the chevy nova " chilton's "
and i'll run down what's here... it's prolly close.
gives specs for
1992 VIN code 5 ... ( close enough )
engine controls
oh.... you don't really need these ones....
which ones,,,, checking ....
engine controls ignition
blk/red 4 rpm signal input c2
blk/yel 3 ignition firing output c2
blk/red 1 ignition on signal C1
"" 7 C1
here
ecm ident
c1 12 cavaties
c2 26
c3 16
igniter ident
c1 6
c2 2
so we want ...
never mind
ooohhh i found it....
ha ha ha ha
as to the above.... the computers are different... moving on...
the 14 one right ?
don't worry man i've got it all.
labelled 14p
______0__OOOOOOOOOOO__0_______
E01 | =10 | STA | VF | NSW
E02 | =20 | IGT | E1 | S/TH
S/TH G-R
STA cluth start relay ? yup B
IGT from igniter ( coil ) not sure B
NSW from ignition switch ST1 B-W auto?
E01 BR
E02 BR
=10 L ( what ucken color is "L" lavender ?)
=20 Y
VF R-W
E1 BR
anyway.... i certainly do have the data .
6-98 chiltons chevy nova #8422
__________________________________________________ ______-
oh fuck did i fuck that up...
i'm lookin' at the wrong end....
from here on it's accurate
______ooooooo_______
L3 L1 VC VS THA BAT +B
ECT L2 E21 STP SPD / +B1
this shows the plug (male) pinouts
the bump (to secure) is on top....
/ is enpty
L3 from ect computer (MAP?) Y-R
L2 "" Y-G
L1 "" Y-L
VC L-R
VS Y-L
THA Y
BAT from "stop" fuse R-L
ECT from cruiz control input P ( also ect comp )
E21 BR water thermo sensor / throttle position
STP G-W to ECT computer
SPD V-W to speed sensor ..
+B
+B1
so what's this ect computer
and again.... i got mixed up ... it happens....
no worries
so putting it all together ....
one to battery (BAT)
one to ignition signal (STP?)
and one to earth
o.k.
so now i'm confused.
what plugs into the 14 plug, and what plugs into the 14 socket on the computer? Nothing ? i does not get used....
clarify
[Updated on: Sun, 22 February 2004 04:44]
Previous Topic:Suspension
Next Topic:Chaser digi dash
Current Time: Fri Nov 20 08:25:34 UTC 2026
Total time taken to generate the page: 0.0053369998931885 seconds
