Toymods » Tech & Conversions » 15sec 2TG
silver_sleeka74
Barossa Valley
15sec 2TG Thu, 19 February 2004 08:09 Go to next message
just wondering if anyone knows of an artical on what it takes to get a 15 second pass out of a 2TG in a TA22? cams,efi,3t internals ect
The Untouchable
Ballarat
Re: 15sec 2TG Thu, 19 February 2004 08:17 Go to previous messageGo to next message
id be interested in that too bro...
there is a thread on here called '13 sec n/a 2tg' or something like that, it discusses a bit on this kinda thing
Re: 15sec 2TG Thu, 19 February 2004 08:22 Go to previous messageGo to next message
RA45Celica used to have a TE27 that did 15's. It was even in Fast Fours when it was a decent magazine (circa 10-12 years ago). Ask him.
CelicaRA45
nth ringwood, Victoria
Re: 15sec 2TG Thu, 19 February 2004 09:00 Go to previous messageGo to next message
actully 14.8 the quarter only warren reids lotus elan beat me 14.75 in the quarter
Jonny2TG
Tasmania
Re: 15sec 2TG Thu, 19 February 2004 14:42 Go to previous messageGo to next message
With my car (TE37) I had a standard 1588cc 2T-G with low compression and did 17sec with the G-tech. I am guessing for 15sec you just need a 2T-G in good health, maybe mild cams. 3T bottom end would help, and light flywheel. It would not take much realy.
To do less than 14sec with a 2T-G you would realy have to start working over the motor. 2000cc, 45mm Webbers. Big cams, light flywheel. Good tyres. Everything dialed in right, high rpm.
wil8115
Seattle area, USA
Re: 15sec 2TG Fri, 05 March 2004 13:26 Go to previous messageGo to next message
3T/2TG hybrid (1941cc)
10.5:1 Wiseco 3T pistons(makes approx 10.66:1 with a TG head) 292 regrind cams
stock 40mm carbs rejetted
good state of tune with 110 octane race gas
in a TE31, stock diff, T50 trans 15.1 at 9? mph.
friend did it.
same day i did a 15.8 with nearly stock 18rg in a RA21.
hemi twofifteen turbo
Re: 15sec 2TG Fri, 05 March 2004 23:33 Go to previous messageGo to next message
what do you mean by nearly stock 18rg?
wil8115
Seattle area, USA
Re: 15sec 2TG Fri, 05 March 2004 23:43 Go to previous messageGo to next message
18RGU 88253 casting(big valve, dbl springs, big port, late RGU)
completely stock inside. just new head gasket, 12* inital timing, 92 pump gas, factory Ex mani 4-2, custom 2-1 to 2.25" exhaust all the way back, 40mm mikuni's jetted up 1 size, Converted to Eletronic dizzy, MSD-6AL, high output coil. Had way to much tire spin in 1st and most of 2nd gears. shifted when it stopped pulling hard. about 7500 'ish
Re: 15sec 2TG Sun, 07 March 2004 01:06 Go to previous messageGo to next message
thanks for that, i got an 18rg in my celica and it only pulls hard to 6700 or so b4 power dies... The timing chain is soo slack it rattles on startup until oil covers it (5 secs) Would changing the chain help much? where do you get them?
Thsnks. (springs are prob ok till 7300, just no power after 6300.
wil8115
Seattle area, USA
Re: 15sec 2TG Sun, 07 March 2004 02:17 Go to previous messageGo to next message
What casting do you have? big #s on front of head.
also what is the serial numbers, they are stamped into a small tab that sticks out on the valve cover surface front left on early heads and front right on later ones.
Are your carbs stock? any Ex? it helps
T APLUS 22
Re: 15sec 2TG Sun, 07 March 2004 07:24 Go to previous messageGo to next message
hemi twofifteen turbo wrote on Sun, 07 March 2004 12:06
I believe thats the oil operated chain tensioner waiting to be 'tensioned' When oil pressure builds up it causes the chain tensioner on the side to pull it out. I didn't think that was a problem as it was a design feature. My 2TGEU only does it on a very rare occasion. So If the engine is old - i wouldn't worry too much about it.
gmsta27
Fl
Re: 15sec 2TG Mon, 08 March 2004 01:29 Go to previous message
The cars are running out of air you might try changing the venturis in the carbs open them up and re size the jets to match the air flow. My car would run strong until 6500-7000 then plateau out on the power like it hit a flat spot. I eventually ended up taking out the large venturis and rejetted the carbs it will now pull all the way to 8000 If I stayed in it that long I usually shift out about 7500 when driving hard. Still runs on the bottom and around town doesn't do much for milage though. The carbs are 44mm mikunis and the engine is a 2tg. The ports have been matched and it is running a 304/288 cam set up with headers and a 2.25 in exhaust.
Greg
Previous Topic:another supra question
Next Topic:ke70 4stud to 5stud how?
Current Time: Thu Nov 19 00:31:37 UTC 2026
Total time taken to generate the page: 0.01343297958374 seconds
