Toymods » Tech & Conversions » 4AGE hose identification
bmak
4AGE hose identification Thu, 19 February 2004 11:20 Go to next message
on my RWD 4AGE there are some hoses on the throttle body that have been cut, not the water hoses but the 1's on the side.
what do these usually hook up to & what do they do
Thanx in advance
[Updated on: Thu, 19 February 2004 11:21]
bmak
Re: 4AGE hose identification Thu, 19 February 2004 11:49 Go to previous messageGo to next message
ive found out that its the air valve
what do the 3 hoses usually connect too.
Also got a question about the hose conection on top of the throttle body.
Its got 1 labeled (C) i assume thats canister
And 1 labeled (N) where does this connect too?
Thanx
HighRolla
Re: 4AGE hose identification Thu, 19 February 2004 12:46 Go to previous messageGo to next message
One of the one's on top of the throttle body connects to a/c idle up valve doesn't it? Can't remember other ones without looking and tracing them back.
IRA11Y
Club Member
Re: 4AGE hose identification Fri, 20 February 2004 06:16 Go to previous messageGo to next message
if your not running aircon block off the two at the top of the TB theyre for aircon idle control and charcoal cannister.
The two 10mm pipes out the bottom goto the coolant lines from the back of the water pump ( rwd pumps and lines) . they are the idle up temp lines
HighRolla
Re: 4AGE hose identification Fri, 20 February 2004 06:20 Go to previous messageGo to next message
The one on the side of the throttle body was the a/c idle up - not top sorry
bmak
Re: 4AGE hose identification Sun, 22 February 2004 11:58 Go to previous messageGo to next message
The 3 hoses at the side of the throttle body(rocker cover side) are not connected to anything, what do these normally conect to?
Thanx for the help so far
HighRolla
Re: 4AGE hose identification Sun, 22 February 2004 12:47 Go to previous messageGo to next message
Will take a pic and label them for you if I get a chance tommorow - I'll do my best in tracing the lines and finding out what they go to Confused . My 4age is in a standard AE82 and is a blue top (blue writing).
ae95
Re: 4AGE hose identification Sun, 22 February 2004 15:00 Go to previous messageGo to next message
Awaiting labelled pic.
My 4age doesnt want to idle when its cold.
thanks heaps highrolla
HighRolla
Re: 4AGE hose identification Mon, 23 February 2004 00:04 Go to previous messageGo to next message
Here are some pics. I've got to go out now so will describe later just thought I'd get them up for you to have a look. SOmebody else may have better idea than me anyway! Smile
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB1.JPG
Below pic shows the line to A/C idle up valve - this line lets in more air if a/c on so to bump up the revs at idle. Connection is below the one that's blanked off (maybe the one blanked off for p/steer or something my car doesn't have)
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB2.JPG
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB3.JPG
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB4.JPG
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB5.JPG
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB6.JPG
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/TB7.JPG
HighRolla
Re: 4AGE hose identification Mon, 23 February 2004 05:22 Go to previous messageGo to next message
1st and last pics are showing what the top hoses are doing. Furthest back is sucking? air from the charcoal cannister and the closer one is hooked up to the thing near the air filter? Hopefully somebody else can help with what this is does..
2nd pic showing the line to let air in a/c idle up (lower) top one blocked off.
3rd and 5th show the VTV and its hoses not sure what this is. 4th photo a bit random
You can also see the 2 coolant hoses attaching in the 3rd picture and in the 5th again. On the bottom that is. It seem like they both come or go to lines that are after the thermostat. I'm not sure whether these coolant lines serve the cold start injector, as the cold start injector is in the middle on the front of the intake plenum (is that what you call it?).
Also check this site:
http://www.mr2mk1club.com/repairsp59.html and scroll down to Removal and point number 2 shows the start of the hose removal.
ae95 I've heard guys here succesfully running the car without the cold start injector connected. Mine runs at 2000rpm for a few minutes with it connected, so I thought yours shouldn't really have too much trouble if that's not working properly. Maybe disconnect the electrical connector from the cold start injector - see if this makes any difference, if it doesn't then it may be wise to fix up something to do with that injector... providing the car is running well otherwise.
Anyone that figures out what all the pipes exactly do it would be good to add to this post for future reference . good luck bmak
HighRolla
Re: 4AGE hose identification Mon, 23 February 2004 05:44 Go to previous messageGo to next message
I think those two coolant lines operate the auxillary air valve -not the cold start injector (the injector is seperate to all this). This makes minor adjustments to idle speed depending on engine temp. Just reading from the website in last post under Idle comments (have to go back to repairs index page).
natez
Re: 4AGE hose identification Mon, 23 February 2004 10:04 Go to previous messageGo to next message
so the one on the top, closest to the TPS goes to the charcoal canister...
HighRolla
Re: 4AGE hose identification Mon, 23 February 2004 10:32 Go to previous messageGo to next message
Yep that's it. Check last photo. Does anbody know if it would matter if you swapped them around (ones on the top that is)? I haven't touched them since I got the car which was 3 years ago so I assume they're correct.
natez
Re: 4AGE hose identification Mon, 23 February 2004 10:50 Go to previous messageGo to next message
cool... i needa connect that up, will do that tommorrow...
thanks for that...
Scorpion
Menai area of Sydney
Re: 4AGE hose identification Mon, 23 February 2004 11:12 Go to previous messageGo to next message
The two pipes with plastic caps over them (one bent & one straight)(in pictures 2 & 5) are for power steering idle-up if you have (a) power steering and (b) the model of steering rack that has an idle up switch on the top where the steering column universal joint is.
bmak
Re: 4AGE hose identification Mon, 23 February 2004 12:07 Go to previous messageGo to next message
Thanx for that
I'll run the (C) conection to the canister & the rest i have no need for.
highrolla: I would leave your hoses connected with the (C) going to the canister.
When i was checking the top 2 fittings they were ported to different areas of throttle body.
HighRolla
Re: 4AGE hose identification Mon, 23 February 2004 12:35 Go to previous messageGo to next message
No worries bmak Smile
Oh ok bmak I won't mess with them. You got the coolant lines sussed etc? Is the engine running or you in the middle of conversion (or near end maybe).
Scorpion
Re: 4AGE hose identification Mon, 23 February 2004 12:37 Go to previous messageGo to next message
Make sure you block any unused tubes on the throttlebody so you don't get any problems with fast cold idle etc.
ae95
Re: 4AGE hose identification Tue, 24 February 2004 08:03 Go to previous messageGo to next message
Im getting pretty confused. Confused
ill have to take a photo of my rwd throttle body (dunno if its the same as fwd) so someone can show me which pipes are which.
EDIT: I dont have a/c so i can block off the 2 top pipes?
[Updated on: Tue, 24 February 2004 08:19]
ae95
Re: 4AGE hose identification Tue, 24 February 2004 08:35 Go to previous messageGo to next message
http://home.iprimus.com.au/mchai/tb.jpg
ok, on my car i dont have a/c or p/s.
Theres no pipes coming out of no.1 and 2.
no. 3 and 4 go to some little device? can i block these off since i dont have a/c
The blue line represents the pipe that joins the 2 holes.
The red circled holes indicate the pipes which are blocked off on my car.
In this next pic, my car has this vacuum port blocked off for some reason. when it is taken off the car idles at about 3k. I have no idea what it does.
http://home.iprimus.com.au/mchai/tb2.jpg
everytime i start the car i have to hold the accelerator with my foot otherwise it wont idle. once it gets warm it idles.
cheers.
[Updated on: Tue, 24 February 2004 08:42]
HighRolla
Re: 4AGE hose identification Tue, 24 February 2004 09:13 Go to previous messageGo to next message
Referring to your labelling system...
In my car No.1 and 2 are blocked off (See pic 1). No.3 goes to funny thing mounted near air filter box (what is that f....n thing). No4 goes to charcoal cannister. Lowest red circled is to a/c idle up (if your's is same..see my pic 2), above that is blocked off ...maybe psteer that my car doesn't have. Then in mine there seems to be one above that that isn't blocked off Shocked or is that something else?? I don't know what that vacuum port is in your thottle body. I thought for idle there was a channel around the throttle "flap" that could be adjusted with the screw to change idle speed. Please correct me if this is bs. I haven't had much experience playing with em..just providing the pics and had a look where they go etc. Oh..I adjusted the A/c idle up about a month ago so the car didn't stall at lights when a/c on..that was sweet, had the car for 2 years before I knew it existed Embarassed
bmak
Re: 4AGE hose identification Tue, 24 February 2004 09:57 Go to previous messageGo to next message
its all sorted now
Thanx everyone
I'm putting the motor in my ke70. It should be ready to start tomorrow nite.
HighRolla
Re: 4AGE hose identification Tue, 24 February 2004 10:18 Go to previous messageGo to next message
Sounds exciting Cool ...let us know how it goes
Scorpion
Re: 4AGE hose identification Tue, 24 February 2004 12:03 Go to previous messageGo to next message
If you blow into the big thick pipe at the bottom, air will come out of the "vacuum port" (if it's not blocked). From what I can work out, this is a cold idle adjustment that is used to adjust your idle speed until the engine water heats up the idle valve under the throttle body. As the engine warms up, the vacuum port gradually closes. So I believe that what people are calling the A/C idle up is a combination of idle-ups and the device attached to the airbox allows filtered air to be fed through to the vacuum port and the amount of air (which decides your idle speed) is controlled by another adjustable valve in the vacuum line. I have tested this idea by having a cold engine with an unblocked idle valve, starting it up and it idles at about 3K, then gradually moving my finger across the vacuum port to slowly block it. As the port is blocked more and more the idle will drop. As the engine warms up, the volume of air through this port drops so there is less effect on the idle and when the engine is warm there is no air passing through the port. The water heated valve below the throttle body is referred to in some workshop manuals as the idle motor. The actual A/C idle up or any other idle up is connected through the top of the throttle body and increases the air flow into the plenum by bypasing the throttle butterfly and hence increases the revs slightly.
HighRolla
Re: 4AGE hose identification Tue, 24 February 2004 12:42 Go to previous messageGo to next message
I don't know if I'm quite with you on that - I know what I've shown as the A/c idle up (marked in red) works when the car is warm. Pic 1 of my pics shows the a/c idle up control valve in the top right (right of windscreen wiper motor). This takes air from the air box - follow the pipe from the valve (you will see). The air is then drawn in through the lowest one on TB (marked) taking air from the outlet of the valve. I know this for a fact as where it connects to the air filter box I disconnected it - with the a/c on you could feel the suction, and turning the A/c idle up valve changed the amount of air sucked and hence idle speed. This was all done on a warm motor. I don't know whether this would be different on later GE's as mine is one of the earlier ones. I'll have to read scorps' reply again. The water heater connections at bottom of TB operate the Auxillary AIr Valve..i don't know whether this is referred to as an idle speed motor - maybe the GE doesn't have one?? I've read about idle speed motors before though..thought all EFI cars have one
Quote:
Now as well as the above electronic controls there is also a purely mechanical device which operates as the engine warms up - the Auxiliary Air Valve. Thankfully its much simpler than it sounds -its just a waxstat valve that controls a small air bleed around the throttle plate. When cold it is open, so giving a lift in idle rpm. As it warms up (its fed by coolant), the wax capsule expands and progressively closes the valve to stop the air bleed and hence the rpm lift. It is physically located under the throttle body and is a simple bolt on unit.
Have a read hear - these guys seem to know what they're talking about
http://www.mr2mk1club.com/repairsp15.html
We're making a meal of this one aren't we
Scorpion
Re: 4AGE hose identification Tue, 24 February 2004 14:00 Go to previous messageGo to next message
To make my reply a little shorter ...
Anyone experiencing high or low idle speeds when the motor is cold needs to adjust the amount of air going through the auxilliary air valve ("vacuum port") by adjusting whatever is connected to that vacuum line.
ae95
Re: 4AGE hose identification Tue, 24 February 2004 15:53 Go to previous messageGo to next message
onyl thing i dont understand is which pipe you are referring to when you say "big thick pipe"
HighRolla
Re: 4AGE hose identification Tue, 24 February 2004 23:44 Go to previous messageGo to next message
He's talking about what I've shown as the vacuum line to A/c Idle up as it is thicker than the other ones (i think). BTW I think the auxilary air valve is independent of the top vacuum hoses from what I've read.
Scorpion
Re: 4AGE hose identification Wed, 25 February 2004 03:30 Go to previous messageGo to next message
Right on both counts HighRolla. Very Happy
ae95
Re: 4AGE hose identification Wed, 25 February 2004 05:12 Go to previous messageGo to next message
So where does this pipe connect to? Can anyone take a pic? Mine has been blocked off, so that would be why the car doesnt idle properly.
thanks guys
-Ian
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 05:27 Go to previous messageGo to next message
What? you don't have the 2 coolant pipes into your throttle body?? i inlet one outlet i assume
Is this what you're talking about:
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/tbAE95.jpg
Those pipe should be connected.
ae95
Re: 4AGE hose identification Wed, 25 February 2004 05:42 Go to previous messageGo to next message
im talking about the bottom red circled pipe, the one which is on an angle. isnt that the auxilary air valve? Confused
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 05:56 Go to previous messageGo to next message
On mine i'm pretty sure that's the a/c idle up (the one with angle on it), actually I'm sure of it just takes air in depending on whether a/c is on and how much the valve is open. The AAV is activated by the water temp and uses those 2 coolant hoses i showed in last post.
ae95
Re: 4AGE hose identification Wed, 25 February 2004 06:34 Go to previous messageGo to next message
ok i traced the hoses and they lead somewhere under the inlet manifold. What could go wrong with this? as my car idles at 3k constantly when i uncover the port. a faulty temp sensor of some sort?
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 06:43 Go to previous messageGo to next message
Are you talking about the coolant hoses now??
ae95
Re: 4AGE hose identification Wed, 25 February 2004 07:14 Go to previous messageGo to next message
lol yep
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 07:53 Go to previous messageGo to next message
too many hoses Very Happy . When you said you "uncover the port it idle at 3k" - does that mean that you took the coolant lines off and left it open? I'm hoping somebody else can help you cause I'm struggling Confused Maybe you need a new Auxillary air valve...
please read this from start to finish:
An extract from here says that when it's faulty idle speed usually increases so maybe this isn't the case or yours is a different case of same prob. But if you've got 5 min read the link above so you don't start tearing things off and jumping to conclusions.
Quote:
This feedback indicates that the Auxiliary Air Valve (AAV) is perhaps the biggest culprit for both hot and cold idle. This makes sense - it is a waxstat device - and the wax capsules do leak eventually - so the valve no longer opens and shuts when it should. The principle is similar to the thermostat in the cooling water system.. (The AAV is a bypass air channel around the throttle plate meant to lift cold idle rpm and be shut when hot.)
Given the age and mileage of all our cars this is quite plausible - loss of wax means it could be more open than it should be - hot or cold. This then means that both hot and cold idle revs are affected - upwards.
ae95
Re: 4AGE hose identification Wed, 25 February 2004 08:57 Go to previous messageGo to next message
im talking about the port inside the throttle body
Scorpion
Re: 4AGE hose identification Wed, 25 February 2004 11:37 Go to previous messageGo to next message
I'm probably confusing everyone by too much info and not enough access to motors to test what I'm saying. However, the port inside the body is for the idle air valve and is fully open when the engine is cold. As the engine warms up, this valve is closed off more and more as the temperature rises and the idle gradually drops from around 3000rpm to "normal". If you restrict the amount of air going into the thick inlet pipe on the bottom of the throttle body, you can reduce the fast idle from around 3000rpm to whatever figure you want.
I have looked at several cars over the last few months to try to understand how that air is regulated but nearly every car is different. From what I can see, vacuum valves are used to adjust the fast idle and idle ups such as A/C are linked to let additional air in when the idle needs to be increased due to load. That's why it looks like the thick pipe goes to the A/C idle up ... because it does but that's not all it's connected to.
This url has some interesting info on how the idle air valve works - from page 10 on for 4Axx engines and page 14 for 4AGE.
http://www.autoshop101.com/forms/h26.pdf
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 12:27 Go to previous messageGo to next message
Hate to keep the post going but on my 4AGE that lowest pipe that I've marked as A/c idle up which scorpion thinks is a combination (fast idle etc. ..if this is what you're saying) is connected to that valve near windscreen motor. before I adjusted it this valve was almost fully closed and would not suck any air in even when A/c was on. However when my car was cold it would still idle at above 2000rpm showing that it does not affect cold idle. I adjusted this valve so it was open somewhat and hence when I used my a/c the idle speed increases to compensate, before engine would stall with A/c on. This valve is electronically controlled and gets a signal from the ECU that the A/c is on..otherwise it is fully closed when A/c off. So I'm pretty convinced this is only A/c idle up not anything to do with cold idle adjustment.
Scorpion
Re: 4AGE hose identification Wed, 25 February 2004 12:56 Go to previous messageGo to next message
On reflection I think HighRolla is right. Sorry for all the pain but at least we've had a chance to thrash it through. Now I have to work out how people can reduce their cold idle from 3000 down to 1500 or so because this will all be ahead of me when I finally get to complet my conversion ... well my engine's actually. Very Happy
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 13:10 Go to previous messageGo to next message
Read end of p9 and start of p10 that's for the GE. It dicusses the type of valve then lists the engines that feature it. See on p9 the blowed up pic of the on/off control VSV. That's like the A/c valve located near the windscreen motor in my pic1. This is also the case for the line that runs from the top of the throttle body to that thing near air cleaner box. This is probably activated by demisters and other littler things hence the reason for the smaller pipe. The A/c drains quite a bit so requires a bigger pipe to gain more air. AAV looks after cold idle (coolant pipes).. i think.
Thought I had it Cool now confused again Confused - i've seen that pdf before, it confused me then now its confused me again. Information can be dangerous Evil or Very Mad
Your chance to talk now scorps. It's too hard trying to work out what these little jap geeks have designed "ahh mr. toyoda..we'll trick them with this one.. Laughing " jap to english translation
HighRolla
Re: 4AGE hose identification Wed, 25 February 2004 13:31 Go to previous messageGo to next message
Just saw your reply then Scorpion.. ihad been procrastinating over my reply for like 20mins. Yeah we haven't solved Ae95s prob. AE95 you're talking about the on on the "flap" now are you? I don't know anything about that..sorry
HighRolla
Re: 4AGE hose identification Thu, 26 February 2004 02:43 Go to previous messageGo to next message
If anyone cares..the vacuum hose on the top of the throttle body which goes to funny thing near air cleaner box is used for idle up of rear demister, lights, interior fan etc. I just tried this and it sucks in air whenever one of these is switched on (I took off the hose that is the inlet to the valve, connected to air cleaner box on little T branch and you could feel the suction). Sorry ae95 doesn't help your prob
ae95
Re: 4AGE hose identification Thu, 26 February 2004 04:57 Go to previous messageGo to next message
im not talking about the throttle body flap. im talking about the big hole in the throttle body( there are a few smaller holes)
The hole is on the bottom on the throttle body just before the flap.
Maybe i should just get a new engine... Very Happy
Altho i'd still like to know how it all works.
thanks guys for the help
-ian
[Updated on: Thu, 26 February 2004 04:58]
TopSecret72
Wollongong
January 2005
Re: 4AGE hose identification Tue, 19 July 2005 10:31 Go to previous messageGo to next message
I know how old this thread is but i'm currently doing the same job as this with my 4AGE.
There is the hose running from the throttle body to a small white/silver plastic box hanging of the airbox.
Then from this is another hose running to somewhere. Does anybody know where this one runs to?
sonwill
Lara, Vic
February 2005
Re: 4AGE hose identification Thu, 21 July 2005 08:25 Go to previous messageGo to next message
There are two pipes onmy 4age thorttle body that when you use the correct Power steering rack, they conenct up to. Not sure why the hell the p/s rack needs vacuume, but it does.
If you take one of these hoses off, the car will idle at like 3 grand.
The others on mine are the A/C and the CC,
TopSecret72
Wollongong
January 2005
Re: 4AGE hose identification Thu, 21 July 2005 12:51 Go to previous messageGo to next message
It's all sorted now, but thanks anyway.
ctan13
Malaysia
Re: 4AGE hose identification Wed, 28 September 2005 21:04 Go to previous message
HighRolla,
I'm currently investigating on some idle-up issues on my 16V redtop. That device with the green electrical connector with a hose running to it from the top of the TB (second hose from top) - is that the idle-up valve? The other hose that comes out of it, where is that connected to? I think I'm missing that valve as I can't locate it anywhere in the engine bay and my N-port is blocked - which results in rpm drops when any electrical load is applied.
Previous Topic:mr2 3sgte gearbox filler plug
Next Topic:Camry sv21 exhaust?
Current Time: Sat Nov 21 02:26:50 UTC 2026
Total time taken to generate the page: 0.011041164398193 seconds
