Toymods » Tech & Conversions » Distributor and Rotor Continuity
Distributor and Rotor Continuity Thu, 19 February 2004 13:41 Go to next message
We are thinking the uz isnt starting coz the distributors/rotors are stuffed.
Can you measure the continuity of a distributor?
We tried 2 ways
1) Disconnect the coil lead and any other lead at the dizzy
Put a multimeter (analogue) on each connection, and turn the motor over, looking for a defletion in the needle.
There was no deflection
2) Remove the dizzy cap and test continuity between the outside lead outputs and the inside lead output (ie, the bit the rotor comes in contact with.
Once again, on the flat surface there was no continuity
My question is can you test dizzys like this? If they are continuous, what kind of resistance should I expect
EDIT: The Rotor is also giving us a headache, We have no continuity from the centre to the curve bit. We have continuity to the top of the curved bit, but not the outside
Is that normal?
[Updated on: Thu, 19 February 2004 14:22]
Re: Distributor and Rotor Continuity Thu, 19 February 2004 15:12 Go to previous messageGo to next message
what exactly are you trying to test?
lead continuity?
cap continuity?
rotor continuity?
leads should have maybe 2K to 10Kohm resistance each
cap has usually aluminium post that goes from inside (where the spark jumps to from the rotor) to the outside (where the lead connects) should be virtually no resistance between inside and outside
rotor usually has a single piece of metal on top so there should be continuity unless it has got oxidation on it (which will happen normally during operation)
try light sanding with 1200 grit paper on the rotor on the outside...should be virtually no resistance between the bit where the carbon centre post of dizzy touches, to the outside curved bit.
testing from centre lead to any other lead is pointless since there is a gap of about 1mm between rotor and post in the dizzy cap.
lemme know how you go.
ps, you have ignitor/s? checked them? are the reluctor pickups the right way round? are your coil/s good?
Re: Distributor and Rotor Continuity Thu, 19 February 2004 15:21 Go to previous messageGo to next message
Thanks Stewart
oldcorollas wrote on Thu, 19 February 2004 23:12
lead continuity?
cap continuity?
rotor continuity?
Cap and Rotor only, will test leads later
Hmmm, well there seems to be 2 materials there. The ali post, and something attached to the ali post where the cutout is.
There is no resistance to the ali post, but no circuit to the attached thing (not sure what it is, graphite maybe?
rotor usually has a single piece of metal on top so there should be continuity unless it has got oxidation on it (which will happen normally during operation}
Did that, no continuity to the outside of the curve (ie, the edge of it)
Ahhh, we were wondering whether there was gap or not
Thanks for clearing that up
No, I don't have ignitors, and I havent touched the pickups (as far as I know anyway)
And I have no idea if the coils are good.
Thats tomoro's test
Re: Distributor and Rotor Continuity Thu, 19 February 2004 16:17 Go to previous messageGo to next message
CrUZsida wrote on Fri, 20 February 2004 02:21
you mean the centre post? yup, is graphite, and there is usually a spring between it and the ali bit that the lead plugs into. there may be resistance there but some continuity would be expected (maybe a K or two?)
weird.. should be metal there....can you get a pic?
no wuckers.
good luck! i hate ignition issues Sad
sideshow
Re: Distributor and Rotor Continuity Thu, 19 February 2004 21:29 Go to previous messageGo to next message
if u dont have ignitors then how will u get spark
what model engine and ecu do u have
and is it std wiring and ecu
or aftermarket
Re: Distributor and Rotor Continuity Fri, 20 February 2004 00:32 Go to previous messageGo to next message
sideshow wrote on Fri, 20 February 2004 05:29
or aftermarket
1UZ, Aftermarket, Delco
Re: Distributor and Rotor Continuity Fri, 20 February 2004 01:00 Go to previous message
Ok, let me clear this up a bit Stewart
On this pic of the dizzy cap, I have continuity between the lead post, and point B, but no continuity between the lead post and point A (ie, no continuity between A and B, and that little pad on mine is still attached)
http://oz-enet.com.au/~peewee/dizzycap.jpg
Now to the rotor.
I have continuity between A and B, but not between A and C
http://oz-enet.com.au/~peewee/rotorarm.jpg
These are not 1uz stuff, I just found random pics off the net
Hope this helps
New parts are $40 each for dizzy caps, and $67 each for rotor arms, but I'd have to wait for them to come in from overeast
Previous Topic:Ignitions
Next Topic:Tercel guru's look in
Current Time: Mon Oct 26 22:01:36 UTC 2026
Total time taken to generate the page: 0.13869714736938 seconds
