Toymods » Tech & Conversions » Fuel mixture Display for $15
midnight
Fuel mixture Display for $15 Fri, 20 February 2004 00:07 Go to next message
Hey kids. Just thought i'd show you how I made my fuel mixture guage.....
So I wanted a Fuel Mixture Display guage and opened my wallet and out fell $15 and a button...
This could be seen as a problem so an old guage lying around my house gave me an idea...
so off to jaycar I went and purchased the KC5195 Fuel MIxture Display Kit for $14.95
The first step was to gut the guage, some crappy VAC thing, when I ripped the internals out it came to me that the board would be too big
http://www.whitey-ford.com/imagestore/board.jpg
so I cut the board where the red line indicates...
After drilling holes in the now sanded guage face I glued the leds in and connected all the anodes, the cathodes were connected with wires to the underside of the board where the green spots indicate.
http://www.whitey-ford.com/imagestore/insideg.jpg
I mounted the board so that the trimpot could be adjusted thru the old bulb hole, that way I wont have crack open the guage if it needs calibration,
http://www.whitey-ford.com/imagestore/backg.jpg
1 minute in photoshop later I'd printed out a face insert and glued it on...
reassembled the guage and voila...
http://www.whitey-ford.com/imagestore/faceg.jpg
Re: Fuel mixture Display for $15 Fri, 20 February 2004 01:08 Go to previous messageGo to next message
Thats pretty cool
Mine is still sitting on my room, all soldered up, but not doing anything
TokenBlackGuy
      wtf is jabber
Re: Fuel mixture Display for $15 Fri, 20 February 2004 01:28 Go to previous messageGo to next message
Now that is the foshilzzle ma nizzle of the gajizzle gagues!!
gold28
Madrid - Spain
Re: Fuel mixture Display for $15 Fri, 20 February 2004 02:08 Go to previous messageGo to next message
Gotta be better than the knight rider special that Jaycar suggest
Grega
melbourne.victoria.austra...
Re: Fuel mixture Display for $15 Fri, 20 February 2004 02:13 Go to previous messageGo to next message
i'll stick with my autometer and haltech
Scorpion
Menai area of Sydney
Re: Fuel mixture Display for $15 Fri, 20 February 2004 02:51 Go to previous messageGo to next message
Have you installed the gauge in your car yet ?
If so, how effective is it ?
Do the leds light up smoothly or is it hard to get a stable reading.
Compliments on the project by the way, I thought it was a good idea. I had in mind eventually to do an LED bar to display the fuel mixture but I like the re-use of the old gauge.
adamb131
Re: Fuel mixture Display for $15 Fri, 20 February 2004 03:15 Go to previous messageGo to next message
Looks good... very handy tool for the $$$.
What are the increments of the leds...??? what figures do they represent??? Do you think the Jaycar kit could be adapted to an LCD Display???
midnight
Re: Fuel mixture Display for $15 Fri, 20 February 2004 03:55 Go to previous messageGo to next message
jay car has another kit that has a segment led display, its $63 tho...
I havent put it in the car yet because the oxgen sensor is way to hard to get to, as soon as I figure out the ecu wiring ill put it in...
midnight
Re: Fuel mixture Display for $15 Fri, 20 February 2004 04:22 Go to previous messageGo to next message
I wasnt quite happy with the face so I printed onto some tracing paper and put it behind the glass...
its real schmick now...
http://www.whitey-ford.com/imagestore/facecg2.jpg
Toobs
Re: Fuel mixture Display for $15 Fri, 20 February 2004 05:22 Go to previous messageGo to next message
There is a nice LCD panel meter you can use... They are Lascar meters distributed locally through Electus Distribution (Jaycar wholesale)
http://www1.electusdistribution.com.au/products_uploaded/productLarge_5349.jpg
Full Boost / Autospeed have an article on this product here
[Updated on: Fri, 20 February 2004 05:26]
Toobs
Re: Fuel mixture Display for $15 Fri, 20 February 2004 05:30 Go to previous messageGo to next message
By the way "Julian Edgar" wrote both the Autospeed article and the KC5195 article.
Re: Fuel mixture Display for $15 Fri, 20 February 2004 07:04 Go to previous messageGo to next message
adamb131 wrote on Fri, 20 February 2004 11:15
There are 10 LEDs on the display.
An o2 sensor will generate voltage ranging from 0.0v - 1.0v
The LED that is lit up is the voltage the o2 sensor is putting out.
hiaaa
Re: Fuel mixture Display for $15 Fri, 20 February 2004 09:05 Go to previous messageGo to next message
Does it work with the Toyota o2 sensor (single wire)??
Re: Fuel mixture Display for $15 Fri, 20 February 2004 10:10 Go to previous messageGo to next message
Yes
CrAiGzEE
south of the big smoke
Re: Fuel mixture Display for $15 Fri, 20 February 2004 13:04 Go to previous messageGo to next message
i was talking to my resident jaycar nerd and he said these things aint that good and ya car will lean out and blow way b4 this guages shows that
im guessing u get what u pay for
Re: Fuel mixture Display for $15 Fri, 20 February 2004 21:44 Go to previous messageGo to next message
These things sure AREN'T accurate - simply because a normal oxy sensor can't produce an accurate signal anywhere away from 14.7:1. The LED kits are great to make sure your sensor is working etc., but NEVER tune an engine with any kind of balls with one... The more expensive one is a bit better if used with the recommended sensor, but still only an approximate guide.
sideshow
Re: Fuel mixture Display for $15 Fri, 20 February 2004 22:10 Go to previous messageGo to next message
mrshin is right
these are more wank factor than accurate
i have seen these work and all they do is goto rich when throttle is on full and lean when throttle is off
the autometer ones just bounce all over the shop
id rather spend 50 bucks on a dyno run to find air/fuel
Re: Fuel mixture Display for $15 Sat, 21 February 2004 03:47 Go to previous messageGo to next message
midnight's gauge/sensor is only narrow-band. so its only going to helpful during cruise mode.
plus if you piggy back the sensor wiring, does it affect the signal going to the ECU?
fwiw, techedge sells Wide band kits...
<http://www.techedge.com.au/>
plus if anyone's keen, i've got the PCB and parts for a DIY WB kit from here:<http://www.diy-wb.com/info.htm>
but it needs an expensive O2 sensor:
<http://www.aces.edu/~gparmer/efi/temp/wb/guide.htm l#sensor>
midnight
Re: Fuel mixture Display for $15 Sat, 21 February 2004 09:10 Go to previous message
yeah I decided not to install it... to much rice factor... its just a row of lights that moves when u give it gas...
the EGOs signal is voltage based so If you wire in the guage in parallel it will not alter the voltage, only the current so it should be fine
Previous Topic:ST185 GT4 - Cruise Control?
Next Topic:my clutch and custom stuff for an r154?
Current Time: Fri Nov 20 14:37:00 UTC 2026
Total time taken to generate the page: 0.0089871883392334 seconds
