Toymods » Tech & Conversions » MA70 front hubs onto TA22/RA23 struts?
Hodgie
MA70 front hubs onto TA22/RA23 struts? Fri, 20 February 2004 11:20 Go to next message
I'm looking to update the braking on the TA22 I'm doing up and I was thinking about using the braking setup off the MA70 Supra. Does anyone know if the front hubs can be grafted onto either TA22 or RA23 struts? Any and all suggestions welcome.
grphil
Re: MA70 front hubs onto TA22/RA23 struts? Fri, 20 February 2004 19:02 Go to previous messageGo to next message
They do not share the same bearing and I think have different spindles, MA70 Supra ones should be bigger, so I think it won't fit...
Grega
melbourne.victoria.austra...
Re: MA70 front hubs onto TA22/RA23 struts? Fri, 20 February 2004 21:49 Go to previous messageGo to next message
well the centre hole on the ta22 celica is 64mm, with the supras being 60mm (from DBA catalog)
its not just the hub that matters though dude you have to get a caliper and the right spacing to the disc (and a disc to suit) for this all to work.
Hodgie
Re: MA70 front hubs onto TA22/RA23 struts? Sat, 21 February 2004 12:04 Go to previous messageGo to next message
Damn. I was hoping that the entire hub, rotor, caliper setup could be transplanted from one strut to the other. I'm looking for a bolt up brake upgrade as I'm no mechanic and I'm on a pretty steep learning curve. I'd seen the thread about commodore parts on MA61 struts and in one of the diagrams it showed the whole braking system being held on by a bracket with two bolts at the bottom of the strut. I guess a bit more homework is in order Confused
Re: MA70 front hubs onto TA22/RA23 struts? Sat, 21 February 2004 17:01 Go to previous messageGo to next message
MA61 hubs are a direct bolt on for RA23 struts. Not as big as MA70 brakes but still a good upgrade!
people100
Rocklea qld
Re: MA70 front hubs onto TA22/RA23 struts? Sat, 21 February 2004 20:40 Go to previous messageGo to next message
How much difference is there between the ma61 and ra40 forn brake setup. Might be a good option there and they are easily found.
Hodgie
Re: MA70 front hubs onto TA22/RA23 struts? Sun, 22 February 2004 02:32 Go to previous messageGo to next message
Sweet. I'll look into the MA61 brake upgrade with the RA23 struts. Just to confirm, the RA23 struts are a direct bolt in for the TA22, aren't they? Anything has to be bigger than the TA22 brake setup Razz
Re: MA70 front hubs onto TA22/RA23 struts? Sun, 22 February 2004 03:25 Go to previous messageGo to next message
RA23 struts aren't quite a direct bolt in. Do a search, this has been discussed many times.
The RA6x/MA6x brakes are a significant upgrade over the RA23/28/40 brakes. The diameter is slightly larger but the big difference is they're ventilated rotors as opposed to solid. The caliper is also larger with more pad area. They will comfortably fit inside a 14" rim which is important to those of us who have 14" wheels and don't wish to upgrade!
rotorace
Re: MA70 front hubs onto TA22/RA23 struts? Sun, 22 February 2004 06:55 Go to previous messageGo to next message
For anyone interested, i have an article in ZOOM magazine, where they fit commodore rotors to RA40 struts, it goes on to say that its very easy to do, because they use similar wheel bearings. I checked the wheel bearing kits at work and the actual bearings are the same, its just the hub seals that are different
people100
Rocklea qld
Re: MA70 front hubs onto TA22/RA23 struts? Sun, 22 February 2004 07:17 Go to previous messageGo to next message
ra23 struts are a different length to the ta22 ones i think. might wanna check that out first.
Hodgie
Re: MA70 front hubs onto TA22/RA23 struts? Sun, 22 February 2004 11:29 Go to previous messageGo to next message
Norbie, is your website still up and running?
Re: MA70 front hubs onto TA22/RA23 struts? Sun, 22 February 2004 23:24 Go to previous messageGo to next message
Not at the moment... give it another day or two, hopefully it will be up by then!
Sam_Q
S.E suberbs, Vic
Re: MA70 front hubs onto TA22/RA23 struts? Thu, 26 February 2004 13:59 Go to previous messageGo to next message
which zoom was that rotorace? I want some serious brakes for my AE-86 sprinter, I am sure that the fitment of struts to an 86 wouldnt be all that different than to a Ta22. Also these hub seals what are they?
Re: MA70 front hubs onto TA22/RA23 struts? Thu, 26 February 2004 15:02 Go to previous messageGo to next message
FWIW my web site is back online... yay!
http://www.norbie.net/BrakeMods.htm
gold28
Madrid - Spain
Re: MA70 front hubs onto TA22/RA23 struts? Fri, 27 February 2004 02:54 Go to previous message
Hey rotorace, I'm really interested in this supposedly easy brake upgrade, Can you get me details of it or the zoom issue??
Previous Topic:4age into 86 questions
Next Topic:EFI fuel tank for 4AGE conversion
Current Time: Sun Oct 18 17:54:16 UTC 2026
Total time taken to generate the page: 0.14028000831604 seconds
