Toymods » Tech & Conversions » water pump question
86racer
water pump question Sat, 10 August 2002 09:23 Go to next message
I would like to know how to remove water pump impeller(or rotor) inside the housing ...I figured you need some sort of special tool to get it out.. but I don't know where to source it ..
Any info would be appreciated ....
IRA11Y
Club Member
Re: water pump question Sat, 10 August 2002 22:00 Go to previous message
Its easier and cheaper just to replace the whole front housing about $40 usually. It is not recommended to just replace the impeller as you usually have to heat up the shaft to get it apart (its a heat press fit I believe) which means you destroy the seals trying to get it apart and you can also warp the housing.
Previous Topic:How much H.P. in a 18RGU wid 2 1/4 exhaust?
Next Topic:AE86/KE70
Current Time: Thu Nov 19 11:36:27 UTC 2026
Total time taken to generate the page: 0.0040102005004883 seconds
