Toymods » Tech & Conversions » JZA70 fuel pump.
HedgehogSandwich
UK
JZA70 fuel pump. Sat, 21 February 2004 14:12 Go to next message
After reading the below conversation.. i was wondering if the same thing applies to the JZA70? Anyone ever tried it?
http://www.toyotaimportsforum.co.uk/forum/showthre ad.php?s=&threadid=2943
I get bad power delivery in certain situations, and was thinking maybe this is the cause ?
adi
Re: JZA70 fuel pump. Sat, 21 February 2004 15:27 Go to previous messageGo to next message
fuel pumps are usually designed to run on 12V, which is why many have a resistor pack to reduce the 14V to 12V or less..
if the ECU controls the fuel pump voltage to 9V, then it it is also controlling the fuel flow/pressure. lower volts = lower flow/pressure.
remember that you will never use 100% of the fuel pumps output (in stock situation), and 95% of the time you are using nowhere near what it is pumping out, most fuel is being returned vias the pressure reg to the tank.
by reducing voltage to 9V, the pump lasts longer and the fuel rail flow is lower (and maybe pressure is also lower), and you don't heat up fuel in rail as much..
sure you can get more fuel flow by upping the voltage, but that will ONLY EVER be needed at WOT and high rpm. why flow 500hp worth of fuel at idle?? beats me....
i believe toyota did this for a good reason.. longevity.. and they are justified because the maximum fuel pump output is rarely needed...
anyhoo, if you are curious, measure the fuel pump voltage during normal driving... see how it fluctuates.
ps, i don't think it is a worthwhile mod. if you need more fuel flow, just get a bigger pump... the Walbro 255lph pumps can be had cheaplyu, and if you need really high flow, just get two.. i got a couple off've ebay for under $100, brand new
[Updated on: Sat, 21 February 2004 15:31]
HedgehogSandwich
UK
Re: JZA70 fuel pump. Sat, 21 February 2004 16:28 Go to previous message
cheers.. although i'm not thinking of it as a mod, i'm thinking of it as a test to see if my fuel pump is delivering what it should be..
If the fuel pump ecu/relay has a potential fault on the JZZ soarer with the resultit only ever delivers 9v, i was wondering if it also is a weak point on the JZA70 supra.. considering theyre both very identical cars.I just want to dismiss any possible faults.
Basically i just wanted to test it out, and see if anyone else has done it before i go shorting pins in the diagnostic and blowing my fuel pump or ECU Very Happy
[Updated on: Sat, 21 February 2004 16:30]
Previous Topic:SA63 with a 5M-E
Next Topic:Steel ~ What type to use for this application?
Current Time: Fri Nov 20 13:35:14 UTC 2026
Total time taken to generate the page: 0.046355009078979 seconds
