Toymods » Tech & Conversions » 7M-GTE - Changing Valve Stem Seals
Danners
Central Coast, NSW
icon5.gif  7M-GTE - Changing Valve Stem Seals Sat, 21 February 2004 22:42 Go to next message
Hi guys,
I'm a bit of a procrastinator and think its about time i change the valve stem seals in the poor old Soarer. My question is - does anyone know if the head needs to be removed from the block to fit them or can they be installed without "too much" hassle??
My car is going in for its dental checkup soon and as I already have the seals I thought the mechanic could put them in for me while its in the shop, i'd prefer to save a bit of dosh on the labour if possible and do it myself if the head needs to be taken off (add labour cost here!)
Any info would be appreciated gents
Dan Very Happy
celicaboy_2000
Lismore, NSW
Re: 7M-GTE - Changing Valve Stem Seals Sun, 22 February 2004 00:08 Go to previous messageGo to next message
Hey, You dont need to remove the head but you will need a special tool to keep the valves closed. Ummmm yeah thats all I think.
Thankyou
Matthew
bbaacchhyy
Re: 7M-GTE - Changing Valve Stem Seals Sun, 22 February 2004 21:26 Go to previous message
I can't say that I have done it on a 7M engine (mine need doing as well), but I have done it on a 18R-G and also a 265 Hemi.
You need a you beaut spring compressor (I have one from Snap-On and it is brilliant). If you have sufficient access to the springs, then you can use this. The only drama is then keeping the valves in the right position, and here is the dodgy part.
Whjat you do is get some nice NEW and clean nylon rope (that will fit through the spark plug hole), make sure the piston that you want to do is at the bottom of the bore, feed in as much rope as you can, wind the piston back up slowly by hand to close to TDC as possbile (without applying too much pressure), and this will hold the valves in place. Replace the valve stem seals, and replace the spings etc and repeat for each cylinder.
Michael B
Previous Topic:Knocking from motor???????
Next Topic:MR2 Wiring Diagram
Current Time: Fri Nov 20 17:52:00 UTC 2026
Total time taken to generate the page: 0.0052201747894287 seconds
