Toymods » Tech & Conversions » Surge tank/efi questions
matt_84
Ipswich
Surge tank/efi questions Sun, 22 February 2004 02:18 Go to next message
G'day all,
Does anyone have any pics or specs on their surge tank they used for their 1ggte conversion into an old school celica, ie. what size attachments, and how many, capacity etc. Also, has anyone got any pics of their actual fueling setup, this will be my first engine conversion, and haven't found much info on the actual fueling side of things for this conversion.
Cheers, Matt
Andy_H
Westleigh, Sydney
Re: Surge tank/efi questions Sun, 22 February 2004 02:37 Go to previous messageGo to next message
i have a ra28, i bought a pre pump and an efi pump and a surge tank. all you do is run a line from the tank to the pre pump and from that to the surge tank.
from teh surge tank run a line through the efi pump to the engine. them run a return from the motor to the surge and a return from the surge to the fuel tank.
i'm pretty sure i used 3/8 fittings.
i'll email you a diagram i just made
Re: Surge tank/efi questions Sun, 22 February 2004 03:23 Go to previous messageGo to next message
If you have an RA23, I've found a surge tank isn't necessary at all. If you have an RA28 I'd suggest you don't dick around with surge tanks and multiple pumps; just get your tank modified to take an in-tank pump. Much neater and easier!
matt_84
Ipswich
Re: Surge tank/efi questions Sun, 22 February 2004 07:13 Go to previous messageGo to next message
Cost wise, which would be better? I'm assuming that i'd need to take the car/tank somewhere to get a intank pump fitted?
T APLUS 22
Re: Surge tank/efi questions Sun, 22 February 2004 08:07 Go to previous messageGo to next message
well installing the Surge tank and pre-pump took me around 30mins in actual labor. Considering hte TA22 fuel tank hasn't got an in-tank pump, this was much easier then getting someone to modify my main tank.
matt_84
Ipswich
Re: Surge tank/efi questions Sun, 22 February 2004 08:27 Go to previous messageGo to next message
Thanks for the info, cheers for the suggestion norbie, but i'll probably use a pre pump, surge tank etc. Seems to be the easiest way in my situation. Right now, i'm just sorting out my parts list, have everything ready before I take her off the road.
commander
Canada
Re: Surge tank/efi questions Mon, 23 February 2004 06:25 Go to previous messageGo to next message
hate to but in, but
so don't
i hate starting new threads... hijack a old thread... recycle
i have a extremely large fuel filter, i suppose that could "double" as a form of surge tank.
the fuel filter is off a bus, a real bus.
still smell the diesel....
better not f'n drip on me...
coach ...
not bus ,,,
coach...
is it coach or bus there ,,,
has water draining plug...
coach guard
p/n 09-05-1033
MCI proprietary ( my bro works there )
i'll spec out a replacement filter...can't use a diesel soaked filter. it's about a 1 L filter.
anyway....looks expensive, maybe my bro can steal .. wewrr ummm
find a extra new filter too.
so there ya go.... possibly fit a super large filter off a truck of bus ?
i know iknow.... i smoke ...more than you would imagine.
clancey
Re: Surge tank/efi questions Mon, 23 February 2004 06:30 Go to previous messageGo to next message
Commander, Where have you mounted the filter/pump? What car as well?
[Updated on: Mon, 23 February 2004 06:31]
commander
Canada
Re: Surge tank/efi questions Tue, 24 February 2004 02:56 Go to previous message
not yet.
just getting all the parts together for a smooth conversion.
i've been thinking about it..
oh yeah i have the N.A. nova ae82 4ac carb.
and it seems to me a cheap pump by the tank in the rear,
then have the filter under the bonnet (ya'll call it that right )
,and another high pressure pump to feed the injectors.
just use your head a bit.
once installed, i would have to burn through a L of petrol
before any lag, and that, can't see it happening.
the suggested method is to use a over-flow type system, where over-flow is fed back into the filter, but this seems unnecessary for most cars.
thinking.... have the large 1 L fuel filter feeding the second
high pressure pump
done and done
Previous Topic:Some more SW20/21 questions
Next Topic:Where can i get my AirConditioner Re-gassed in Sydney??
Current Time: Fri Oct 16 00:03:36 UTC 2026
Total time taken to generate the page: 0.022290945053101 seconds
