Toymods » Tech & Conversions » Knocking from motor???????
ta2272
Knocking from motor??????? Sun, 22 February 2004 08:45 Go to next message
when your out of car or in the garage the engine had an obvouis knocking noise, i think i have done a bottom end bearing, just wondering how long it will ast if it is a bearing and will it do any damage(especially to the head)
jason
thanks alot also could it be something in the head like a cam is loose , the motor is a 2tg,
ChuckLandwehr
Re: Knocking from motor??????? Sun, 22 February 2004 11:30 Go to previous messageGo to next message
Time for an engine strip down lad! cause if the noise is that noticeable, it could let go at any time. If it is a big end bearing, you dont want it to let go! Pistons bouncing off valves or conrods through sides of block, ouch!!!!
Get a pro to check it out, might be something simple!
regards Chuck.
ta2272
Re: Knocking from motor??????? Sun, 22 February 2004 22:06 Go to previous message
i hope so
jason
Previous Topic:Deglazing brakes - what grit sandpaper?
Next Topic:7M-GTE - Changing Valve Stem Seals
Current Time: Fri Nov 20 18:09:32 UTC 2026
Total time taken to generate the page: 0.016052961349487 seconds
